super steve
I was at don vally VW on thursday and apparently there was no recall to install the check valve yet.
anyone else had better luck?
when it rains try holding the rear washer for 10 seconds. (just because it makes a big mess)
On my car when i let go of the washer, the washer keeps coming out for another 3 seconds like i am holding the stalk.
Even if I haven't used the rear washer recently, mine pees a bit when I corner hard or hit a bump. I'm not an anal retentive sort about whether my car is clean or not (in fact, haven't even washed it since I got it) so whatever. If they release a TSB, I'll get it taken care of at the first service.Rain is expected tomorrow. I'll give it a test.
92 10 03 (2023248) May 11, 2010 – Rear Washer Nozzle Drips after Use
Model: 2010 Golf, GTI
There is a TSB for it. Quote the TSB # to your dealer to make sure they will fix it.
That's right off the VW ServiceNet Technical Bulletins List.
To get it fixed the rear hatch spoiler needs to be removed and there is a whole procedure on how to properly clean and prep the area for the adhesive to reinstall the spoiler. Your dealer will require those items as well besides the parts listed in the TSB to install the non-return valve.
