Old 12-01-2013, 10:52 AM   #1
Zoomx
Drives: Golf 6 R20
max temp limit on oil ???
What is the max temp limit on oil on my Golf R?
Running APR Satge 2+
Zoomx is offline   Reply With Quote
Old 12-01-2013, 11:09 AM   #2
nitroscope8
Drives: 2013 GLI autobahn w/nav
Depends. Flash point is determined by how much fuel is diluted in. Oil temp is about 20 degrees warmer than coolant temp. If you are seeing oil temps over 300 all the time then there is a problem.
What temperature are you running?
2013 GLI autobahn w/nav 2010 Tiggy 4mo
vdub master tech. PM me if you need help with anything.
SB STG3 drop in for sale. 700mi. PM ME
nitroscope8 is offline   Reply With Quote
Old 12-01-2013, 11:15 AM   #3
Zoomx
Drives: Golf 6 R20
220 is the highest I've seen.
I will upgrade to Stage 3, so it was more if I also have to think about the oil cooler
Old 12-01-2013, 07:20 PM   #4
fasteddy
fasteddy's Avatar
Drives: Toy
My coolant is usually 200 F and my oil runs about 235-240F
2012 CSG GTI 6MT // APR 1 - R8 Coil Packs - UniBrace UB/XB - DG Springs - p3 Gauge - S3 Shifter - TDI Knob - OEM Front Lip - LED Tails - LED Interior - Michelin Pilot A/S 3
fasteddy is offline   Reply With Quote
Old 12-10-2013, 10:18 AM   #5
TAZZ
TAZZ's Avatar
Drives: 2011 .:R, DSG 2Doors
OP was asking about the R. GTIs have higher running oil temps than Rs in similar conditions.
Typically an R would see between 194-212F depending on how /where its driven and what type of oil it has, with an occasional 220+ if you're tracking or thrashing it reaaally hard. Since I switched to Motul 300V 5W30, I noticed a fair drop in temp and rarely go above 200F
DM Custom 2+ / Upsolute DSG Reflash / Autotech HPFP / RS4 HPRV / Scorpion Catless Resonated TBE / APR Carbonio / GFB DV+ / CTS TOP / CTS TBP / HG Pulley / Sprintbooster / HPA Haldex Competition Controller / Alcon Advantage Extreme BBK / FONDMETAL 9RR Wheels
336 awhp / 357 awtq - Build
TAZZ is offline   Reply With Quote
