Old 12-06-2013, 01:35 AM   #1
jy7347
Drives: 2012 golf R
APR Stage 1+ without upgraded HPFP?
if i were to do an APR stage 1+, have anyone done it without aftermarket HPFP? does it make a huge difference?
my R right now is all stock, im just curious about this.
jy7347 is offline   Reply With Quote
Old 12-06-2013, 01:43 AM   #2
Bozz
Bozz's Avatar
Without an HPFP, you're just Stage 1.
Old 12-06-2013, 01:43 AM   #3
Bozz
Bozz's Avatar
If you're talking APR that is. If you're talking UM or Revo or some other, then that's different...
Old 12-06-2013, 01:53 AM   #4
McQueen77
Probably better in the long run. Mine has been fine so far with stock HPFP
Old 12-06-2013, 03:33 AM   #5
thedude4bides
thedude4bides's Avatar
Drives: '12 Golf R
The HPFP is probably my favorite power mod. It really fattens out the power band. If I were you, then I'd start at stage 1 and then get the hpfp when you are bored with it.
Old 12-06-2013, 08:18 AM   #6
TAZZ
TAZZ's Avatar
Drives: 2011 .:R, DSG 2Doors
The "+" tune is calibrated for a higher requested fuel rail pressure. If you are on stock HPFP then your actual pressure will be way below the requested across the rev band, your will be running too lean and your AFR will be off... just flash the right tune for the right hardware man.
DM Custom 2+ / Upsolute DSG Reflash / Autotech HPFP / RS4 HPRV / Scorpion Catless Resonated TBE / APR Carbonio / GFB DV+ / CTS TOP / CTS TBP / HG Pulley / Sprintbooster / HPA Haldex Competition Controller / Alcon Advantage Extreme BBK / FONDMETAL 9RR Wheels
336 awhp / 357 awtq - Build
TAZZ is offline   Reply With Quote
Old 12-06-2013, 10:17 AM   #7
thedude4bides
Drives: '12 Golf R
Yes, but make sure you get the HPFP
Old 12-07-2013, 11:12 AM   #8
dallen13
Drives: 2010 CSG 4dr GTI DSG
And throw in the intake as well. From apr claims it's a huge difference maker.
dallen13 is offline   Reply With Quote
Old 12-09-2013, 12:34 PM   #9
g19aby
Drives: golf mk6 gt tdi
I had the Revo map put on the car and its the best thing I've had done it. Its so much smoother and the power when you need it. Very Happy with mine.
g19aby is offline   Reply With Quote
