Old 10-30-2017, 11:01 AM   #365
Injen1us
Injen1us's Avatar
Drives: MK6 gti
So I took the car out to Streets of Willow this Sunday and had an absolute blast. Definitely drove the car to it's limits for the first time (I'll explain in a bit). Came out of the session with some big take aways.
First the video of my fastest lap. A respectable 1:38.41
https://youtu.be/5ny_IAteM3s
Now some thoughts:
Car has too much power and is too light to expect the Michelin PSS tires to hold up in turns in low gears. I basically had to stay out of second. In the am it was only about 60F so I thought maybe as the day warmed up. But I was only able to improve a half second later and I attribute that mostly to having alot more of the track to myself. My power to weight is a huge advantage in a straight line but is difficult to lay down on circuit
Now SoW was just recently resurfaced and everyone is talking about how greasy it is. But more than that I think the biggest factor to my lack of grip is a reduced contact patch in the rear due to my weight distribution being probably 70/30 favoring the front. This is evident with how many times I got sideways from my back slipping out... Yes you read that right.
Going forward I'm looking first at rcomp tires. These will go on my team dynamics while the PSS go back on the enkeis.
Secondly I. Looking at going with some Racingline bushings and light weight LCAs.
An LSD needs to happen as well... That's obvious. Because of the cost of the job verses how much I track (3 times a year or so) this is one that may not happen over the winter.
Last thought:
When out with some mk7rs. One stock tune the other stg2. Absolute monsters on the track. They always had grip and we're about 4-5 seconds faster than me. That platform is really amazing
2800lb k04'd daily driver
Radical Edward
Old 10-30-2017, 09:23 PM   #366
Injen1us
Injen1us's Avatar
Drives: MK6 gti
A couple photos from my track session at Streets of Willow.
Again such fun.
Name:  resize track 1.jpg
Name:  resize track 2.jpg
Radical Edward
Old 10-31-2017, 01:11 AM   #367
deep.mit
deep.mit's Avatar
Drives: 2013 GTI 6MT 2dr
^ Awesome pics!
Yeah, at your power level, LSD definitely makes a lot of sense. Will be a good equalizer against the AWD Rs
My Build Thread
Instagram
deep.mit is offline   Reply With Quote
Old 01-04-2018, 01:12 AM   #368
Wessley
Wessley's Avatar
Drives: 2012 GTI Autobahn 6MT
The Jealous Admirer...
I thought this car looked familiar. We met in Big Bear at OBB. I was parked off on the street where you drive into the event. It's about damn time I found this build thread.
Build Thread
2012 GTI Autobahn 6MT 2-Door | ST Coilovers | Stratified Tuned | Spec Stage 2 Clutch | Enkei Tuning TS-10 | Michelin PSS 235/40/18 | Eibach F&R Sway Bars | Beluga Catback | Eurojet Catless Downpipe | Diode Dynamics Demon Eyes | BFI Shift Knob | Dark Cherry Euro Tails | Lamin-X |
Wessley is offline   Reply With Quote
Old 01-04-2018, 01:18 AM   #369
Injen1us
Injen1us's Avatar
Drives: MK6 gti
Oh yea bro i remember! Welcome to the thread!
I have been meaning to update it too!
Radical Edward
Old 01-04-2018, 01:31 AM   #370
Injen1us
Injen1us's Avatar
Drives: MK6 gti
The LCA install is super easy. Since I didnt have a 24mm hex bolt to replace the stretch bolt holding in the axle I kept my OEM ball joints in (they are in great shape anyways). WIthout that you could do a lower control arm swap in 30 min.
What is more difficult is swapping it with high durameter VWR bushing.
I put the front bushing in myself with a homemade press and some grease; getting it into the car is too easy; slips right in. The aft bushing is much more challenging. A heavy duty set of channel locks is necessary.
ALOT... ALOT of caution is needed when threading these bolts. This is probably true with Whiteline, Superpro as well. Since you need force holding that bushing housing in place its easy to get the wrong angle on the thread. Those female threads on the subframe (and chassis) are super easy to cross thread and ruin.
Also use new bolts. These are stretch bolts; so i bought new subframe bolts but need to put in new bushing to chassis bolts as well.
While under there I installed tyrolsport deadset kit on just the LCA bushings as i was running out of time and needed the car. The rest of the kit will go on before i get an alignment.
The car drives beautifully. Its amazing how much this does for steering precision and response. No noticeable increase in NVH from the stronger bushings either. Grip feels much better in the turns and the LCAs are about 1.5lbs lighter per
Radical Edward
Old 01-04-2018, 06:25 PM   #371
deep.mit
deep.mit's Avatar
May I ask why did you decide to replace the control arms? Weight? Or did the OEMs crack?
My Build Thread
Instagram
Old 01-04-2018, 06:56 PM   #372
Injen1us
Injen1us's Avatar
Drives: MK6 gti
Its ALOT easier getting a new bushing out of a new control arm to install poly bushings than out of an old control arm.
Weight and price are the other bits. Each one of these are about 2lbs lighter than factory. Not much but I take anything I can get.
I got these from rock Auto for 180 bucks
Radical Edward
Old 01-05-2018, 02:57 PM   #373
deep.mit
deep.mit's Avatar
Ok, makes sense. Keep learning new stuff while following your build. Have a great 2018!
My Build Thread
Instagram
Old 01-05-2018, 03:04 PM   #374
Injen1us
Injen1us's Avatar
Drives: MK6 gti
You too man! I gotta make my way up to the Bay soon
Radical Edward
