Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Marketplace > Vendors Classifieds > Interior Parts
Old 01-27-2014, 10:03 AM   #1
Frank@KMD
GolfMK6 Official Vendor
Frank@KMD's Avatar
Drives: Anything with 4 wheels
Send a message via AIM to Frank@KMD
***KMDTuning P3cars Digital Vent Gauge***
Presents:
P3Cars Vent Integrated Digital Interface!
(MK6 US GTI version shown)
Also Available White and Red LED option!
And Golf R White and Blue!
Track Pack now available!!
Product Information
Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior.
Reads boost and all data directly from the diagnostics port for fast plug and play install.
Plug and Play install
Quick plug and play install with zero cutting required. All power, ground, and data points come directly from the diagnostics port connector.
Boost/Vacuum Display
High resolution boost/vacuum via diag port for FAST install. Optionally read boost via boost tap (not included).
Multiple Gauge Displays
Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
Peak Recall & Run Record
Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
Universal Aux Inputs
Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
On the Fly Configuration Menu
Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
Email or PM for pricing!
(gauge only)
*Pre-installed in OEM vent (+$80.00)
To order:
Please PM or Email Frank@KMDTuning
Frank@KMD is offline   Reply With Quote
Old 01-27-2014, 12:59 PM   #2
kern417
Drives: '09 Jetta
oh wow that's even better than their black friday/christmas sale pricing. now i wish i would have waited ): awesome deal for a great product.
do a burnout.
Old 01-27-2014, 02:24 PM   #3
Squashdaddy
Squashdaddy's Avatar
Drives: 6MT 2011 GTI
Is it recommended to get a boost tap for these even though it reads off the OBDII port? Is a boost tap more accurate?
Old 01-27-2014, 02:34 PM   #4
Frank@KMD
Frank@KMD's Avatar
No boost tap needed. Connects directly to the OBD port.
This will pull accurate readings from the ECU.
Old 01-27-2014, 02:41 PM   #5
NYCSuits
NYCSuits's Avatar
Is this an open ended sale for now or is there an end date?
Old 01-27-2014, 02:41 PM   #6
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
its a good price. someone on here is trying to sell a used one for even more than this.
2015 Subaru Forester XT
LastHumansGarage
Old 01-27-2014, 02:56 PM   #7
Me007gold
great price, think I may have to make an order.
Me007gold is offline   Reply With Quote
Old 01-27-2014, 03:30 PM   #8
Frank@KMD
Frank@KMD's Avatar
SALE is open as of now with no end date..
Old 01-27-2014, 03:44 PM   #9
Frank@KMD
Frank@KMD's Avatar
let me know how i can help!
Old 01-27-2014, 04:14 PM   #10
Squashdaddy
Is a boost tap more accurate than the OBDII?
Old 01-27-2014, 04:58 PM   #11
kern417
Drives: '09 Jetta
the readings from the OBD = what your ecu reads = what you're tune is running off of. everywhere every dealer says it's not necessary.
do a burnout.
Old 01-29-2014, 10:31 AM   #12
Frank@KMD
Frank@KMD's Avatar
Wednesday Bump Day!
Old 01-29-2014, 10:33 AM   #13
MBorVW
MBorVW's Avatar
Drives: 2015 VW GTI 4dr SE DSG
These are fantastic!
Also: 2012 Tiguan LE 2wd
MBorVW is offline   Reply With Quote
Old 01-29-2014, 09:11 PM   #14
Frank@KMD
Frank@KMD's Avatar
Bump
