Old 02-16-2014, 06:48 AM   #1
LightningRhod
LightningRhod's Avatar
Drives: 2011 CW GTI DSG
LightningRhod's quest to 200k.....and beyond
Starting this journal for archiving purposes and to share with the community. From the get go, the plan was to keep this car for the long haul until it dies or becomes too much of a liability to repair. This is my first European car, so it's also a test in long term reliability as well.
Here is my history. The car is dual purpose, so it serves as my daily driver and the occasional track day. Oil changes and intake filter cleaning are done every 5k miles. I use Mobil1 0w-40, but the OEM Castrol oil is used when at the dealer (10k, 20k, 30k carefree maintenance). Cabin filter is changed around every 10k (or whenever it starts to smell funny). Mileage at which aftermarket mods were installed are approximate. All installs done by me unless otherwise noted.
Car purchased 2010 Nov (Autobahn DSG)
GTIstock by ichibankakkoii, on Flickr
2011 June, 10442 miles
- 10k service done at dealer
2011 October, 20400 miles
- Wastegate rattle issue analyzed
- 20k service done at dealer
- Low coolant light went off. Brought it to the dealer to pressure test it. No leaks found. Have not had a problem with water pump or low coolant since then.
2011 November, 21925 miles
- Wastegate retaining slip installed per TSB121107
- DSG update 37G2 applied to mechatronic unit
2011 December, ~23000 miles
- AWE boost gauge installed
2012 February, ~28000 miles
- Neuspeed P-flo intake installed
- Enkei PF-01/Dunlop Star Specs purchased and installed
DSC_0191 by ichibankakkoii, on Flickr
2012 March, 30745 miles
- My first track day at Sonoma
DSC_0676 by ichibankakkoii, on Flickr
- 30k maintenance done at dealer
- Carefree brake fluid flush done
- Driver Gear (manual 4-door) springs installed (installed by a reputable member in San Jose on the MKV forums). Went with the manual springs because I wanted the drop just a tad lower in the front.
DSC_0381 by ichibankakkoii, on Flickr
2012 April, ~33000 miles
- APR Stage 1 installed
2012 May, ~37000 miles
- Ultimate Racing downpipe (metal 200 cell cat, resonated) installed
- APR Stage 2 installed
2012 July, ~40000 miles
- 40k maintenance (oil, plugs, fuel filter, cabin filter) done by me.
- Unibrace UB installed
2012 August, ~43000 miles
- Unibrace XB installed
XB1 by ichibankakkoii, on Flickr
2012 September, ~45000 miles
- 2nd track day at Sonoma (sorry no pics for this one)
2012 December, 50316 miles
- DSG service done at dealer
- Started experiencing DSG chatter at low speeds (like at a drive thru). Asked dealer to check it out, could not reproduce. After some research on the forums, it seems to be normal thing that happens with DSG as they age.
2013 March, ~57000 miles
- Continental DWS tires purchased and installed on stock wheels
2013 April, 60148 miles
- Error code P2015 popped up. Intake manifold replaced under warranty.
- Started hearing a metallic noise when turning the wheel lock to lock at low speeds. Dealer found exhaust hangar loose and heat shield for steering rack bent down. They ended up fixing this for me for free
- Started experiencing a rubbing noise when pulling up the parking brake. Dealer found no mechanical problems with it, but did hear the noise. They would have had to charge me extra to pull everything out to lube the parts to get rid of the noise. I said "No thank you". Honestly, haven't heard it since.
- Found damage on the front bumper (small paint chip, like somebody dropped a tool on it). I expected them to just paint chip it, but they offered to re-spray my whole bumper. Win for me .
2013 May, ~63000 miles
- Audi R8 red coilpacks installed
2013 December, ~78000 miles
- 3rd track day at Laguna Seca
A64F9404 by ichibankakkoii, on Flickr
2014 February, ~83000 miles
- OEM SPM BBK installed w/Stoptech Street Performance pads.
- ATE Super Blue DOT4 fluid
- Spark plug change (NGK BKR7EIX Iridium IX)
DSC_0382 by ichibankakkoii, on Flickr
2014 April, ~90k miles
- OSIR CF lip installed
2014 July, ~100k miles
- DSG fluid change
- Battery tested, low charge identified. Dealer recommended replacing the battery.
- Dealer tech also broke my battery cover and installed it incorrectly......freaking idiots. They offered to take care of me with a new battery cover and re-inspection of the DSG transmission, but I was in the middle of a move back to the Bay Area.
- Damage to passenger side headlight. Piece of metal bounced off the road and put a hole in it. All the lights still work, but I should really replace the unit.
20141005_182311 by ichibankakkoii, on Flickr
2014 October, ~111k miles
- Replaced passenger side headlight
- Battery was spewing battery acid and smelled terrible. Replaced the battery with a Duralast Platinum (H6 AGM)
Just a shot of the nice new headlight, as well as half of the custom Colgan bra that I have on.
20141007_160755 by ichibankakkoii, on Flickr
2014 November, ~112k miles
- Car threw code "P0302: Cylinder 2 misfire". Was going to try to change out coilpack #2 with the stock unit I still have, but the CEL turned off after 2 days by itself. It then turned back on a week later and stayed on. Need to troubleshoot.
2015 January, ~117k miles
- Track Day #4 @ Laguna Seca
- Carbon cleaning done. CEL and rough idle solved.
- Car paid off
Feel free to ask any questions.
Old 02-16-2014, 07:15 AM   #2
Krog29
Krog29's Avatar
Drives: '11 UG GTI/DSG
Just got a '11 UG GTI in November with 31,000. About to get uni stage 1 and dsg stage 1 done on Friday. How is the DSG holding up for you?
Krog29 is offline   Reply With Quote
Old 02-16-2014, 07:20 AM   #3
LightningRhod
The DSG has been bulletproof so far, especially with the 3 track days under my belt. I've never had a problem with its performance or reliability.
Old 02-16-2014, 07:26 AM   #4
Krog29
Krog29's Avatar
Awesome! I always have been worried about auto trannys before since I've had them shred on previous vehicles. I can't wait to see the difference the 2 tunes will make to the car. Also getting rid of the 18" OEM wheels and getting 17" Neospeed RSe05.
Old 02-16-2014, 08:12 AM   #5
iGTI
iGTI's Avatar
Glad to see dealer taken care of you, it pays to have a good relationship with service advisor and master tech, so far I have shared some good experiences as well(knock on wood).
This year I have to go the legendary Laguna Seca, I only know it from Gran Turismo and it seems like fun challenging track.
Good luck on your GTI
S3 16'
STG 1+ Sold
Old 02-16-2014, 09:52 AM   #6
Baosa
Baosa's Avatar
Drives: 2012 CSG GTI 6Spd
Good stuff! Have 40k on the car now, also hoping to drive this car to the ground. Good to see it's still running strong tuned.
APR Stage 2 v2.4 | Golf R IC | Billy Boat DP | Neuspeed TBP/TOP | GFB DV+ | Fluidampr | Michelin PSS | RSR/ECS Bleeder Block | 034 Pendulum/Engine/Transmission Mounts | Vibra-technics Subframe | | TyrolSport Deadset F/R | SPM RSB/FSB | U.R. Mid Brace | KMD Lower Front/Rear Stress Bars |
Baosa is offline   Reply With Quote
Old 02-16-2014, 11:11 AM   #7
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
interesting.. me and a lot of people have mentioned a strange noise when backing up with the steering wheel cranked. most likely some CV noise, but no harm in checking for any heat shield interference..
2015 Subaru Forester XT - Satge 1
www.lasthumansgarage.com
Old 02-16-2014, 02:51 PM   #8
maxtdi
GolfMK6 Elite
maxtdi's Avatar
Dang you're close to 100k Impressive. Did you ever get a carbon cleaning?
Old 02-16-2014, 11:24 PM   #9
Tkulhanc134
Tkulhanc134's Avatar
Drives: MK7 GTI DSG
Nice progress! Similar plans to mine, got the car almost 2 yrs and still stage 0. Gonna start autoxing and hpde within a month, planning on dumping it prob 2018, by then i might afford audi s4 price ranged cars, subd.
2012 GTI 6MT-APR Stage 1 => 2015 GTI DSG
Tkulhanc134 is offline   Reply With Quote
Old 02-17-2014, 12:26 AM   #10
LightningRhod
Let me know if you're planning on going out to Laguna Seca. I'm planning on going back out there in the summer with the NCRC.
It would be worth a quick look and would be easy enough to fix if the heat shield is indeed a problem.
I actually have not had a carbon cleaning yet. It probably would be a good idea to do it though.
Old 02-17-2014, 06:57 AM   #11
LightningRhod
So this happened last weekend. Hit a horrible pothole and found a bend in my track wheels:
20140213_095214 by ichibankakkoii, on Flickr
20140213_095122 by ichibankakkoii, on Flickr
20140213_095151 by ichibankakkoii, on Flickr
20140213_095239 by ichibankakkoii, on Flickr
Fixing the wheel at a repair shop would be easy enough to correct the damage. However, since this set is primarily used for tracking, should I just replace the wheel? Wouldn't want to track a wheel that has had its structural integrity jeopardized. FWIW, it looks like the damage is just on the lip on the rim. The bent wheel holds air just fine (drove on it for 2 days until I swapped them out for the stockers).
Old 02-17-2014, 09:18 AM   #12
D Griff
GolfMK6 Elite
D Griff's Avatar
Drives: POORVETTE
Cool track pics man, glad to hear the car is going strong after that many miles!
www dot dat forum doe dot com
D Griff is offline   Reply With Quote
Old 02-18-2014, 06:17 PM   #13
APRMK6GTi
APRMK6GTi's Avatar
must be some crazy pothole, the PF01 are pretty strong...a bent lip shouldnt affect the integrity that much...a good shop to go to is memoryfab...contact dave he'll help you out.
Nor Cal VW Drivers Club
Old 02-19-2014, 03:43 AM   #14
LightningRhod
Where is memoryfab located?
And yeah, that pothole was nasty. Stupid city of Hayward not maintaining their roads
