Old 11-12-2014, 03:36 PM   #43
LightningRhod
LightningRhod's Avatar
Drives: 2011 CW GTI DSG
Originally Posted by smrtypants44 View Post
Thats pretty normal. There is still a record of the code inside the computer. I find that if its not a recurring issue it will turn off the light after a couple days.
It actually turned back on today. I'm willing to bet that it will turn off in the next couple of days. I should probably just clear the code all together. Car hasn't been struggling or chuggling from what I can tell.
Old 11-13-2014, 04:10 PM   #44
TWM Performance
TWM Performance's Avatar
Drives: Mk5 R32
Great thread! Seems to be really reliable so far. Keep on troopin'
Renato
Team TWM Performance
TWM Performance is offline   Reply With Quote
Old 11-13-2014, 06:02 PM   #45
LightningRhod
Renato
Thanks! I'm really hoping this thing will last beyond 200k
Old 11-17-2014, 07:55 PM   #46
LightningRhod
CEL turned back on several days ago and is still on. This morning when I turned the car on, the CEL was blinking then turned solid and stayed on. Will need to scan and troubleshoot (change out all coils and plugs possibly).
Old 01-15-2015, 06:09 PM   #47
LightningRhod
UPDATE on my CEL....
Changed out my coils and plugs, cleaned the MAF, and cleared the codes. It would be ok for a day, then turn back on the next day. NOW if I clear it, the CEL will turn on during the second start up (after driving several miles on the first startup).
The codes that are being thrown are always the following:
P301 - Cylinder 1 misfire
P302 - Cylinder 2 misfire
A random misfire code will also pop up with it.
At cold start, it is very apparent that there the cylinders are misfiring as I can hear "stutters" in the exhaust rumble. I've essentially already ruled out electrical issues (coils, plugs, MAF), so I'm willing to be that its air/fuel related.
Made an appointment at 034 Motorsports to do a carbon cleaning on Jan 29th. Before then, I'm going to take it to Winn VW to check out the fuel injectors to see if those are faulty. I believe VW extended the warranty on this part to 120k miles, to which I'm currently at 116k miles.
Old 01-15-2015, 06:12 PM   #48
LightningRhod
I should also add that once the car is warmed up, the audible misfires go away. I have full power with no hesitations when on the gas.
Old 02-02-2015, 02:52 PM   #49
LightningRhod
Looks like I finally solved my misfire problem. Got a carbon cleaning last week and the rough idle at cold start is gone. It's been a few days and no check engine light has come back on yet. Here are some pics.
Valves before:
IMG_5878 by ichibankakkoii, on Flickr
Valves after:
IMG_5880 by ichibankakkoii, on Flickr
More carbon build up shots on the port dividers:
IMG_5876 by ichibankakkoii, on Flickr
IMG_5877 by ichibankakkoii, on Flickr
Old 04-01-2015, 07:33 PM   #50
APRMK6GTi
APRMK6GTi's Avatar
do you plan on replacing your shocks? or are they still holding up with DG springs?
Nor Cal VW Drivers Club
Old 04-09-2015, 09:26 PM   #51
LightningRhod
I actually have my Bilsteins on hand, just haven't had the time to install them.
But yeah, my stock shocks are freakin' BLOWN lol.
Old 04-09-2015, 09:31 PM   #52
LightningRhod
Good opportunity to update since I'm here....
Car is sitting at 122k miles and nothing new to report. It's kind of boring when I have nothing to fix on the car.............lol.
Old 04-09-2015, 10:52 PM   #53
APRMK6GTi
APRMK6GTi's Avatar
thats a good thing!
Old 04-10-2015, 07:56 AM   #54
Seriously, don't jinx yourself. I'm at 108k and my commute is about to get longer. Hoping to make 300k eventually.
Old 04-10-2015, 10:53 AM   #55
APRMK6GTi
APRMK6GTi's Avatar
gotta love seeing other GTIs reaching these high mileage without too much problems..ive only owned Japanese cars in the past and GTI was the only car that gave me problems(water pump, radiator) but thankfully warranty covered them all.
Old 04-10-2015, 11:03 AM   #56
timneedscoffee10
timneedscoffee10's Avatar
Drives: 2011 VW GTI w Sunroof
Awesome build thread -- glad to see someone else in this for the long haul! I'm just creeping up on 100k myself, and plan to keep her until it's just not feasible to keep her running anymore.
To celebrate an aggressive first 100,000 miles, I'm starting to mod back towards daily driving comfort - trying to strike a balance between aggressive performance and 25,000 miles a year.
sub'd
