View Poll Results: POLE ON DEM PACKS.
Since purchasing them, Iíve had zero failures. 265 95.32%
Iíve had 1 or more failures confirmed as the coilpacks and nothing else. Please explain in post. 13 4.68%
Voters: 278. You may not vote on this poll
Old 01-28-2015, 10:24 PM   #57
willnando
willnando's Avatar
Drives: MK6 GTI (Evee) B7 S4 (Sonya)
Had a little bit of stuttering and got the R8 coils. They eliminated the issue.
Now a few thousand miles in I've noticed a little stuttering and loss of power.
Could it be the coils?
Loss of power Im thinking some sort of leak somewhere..
willnando is offline   Reply With Quote
Old 01-28-2015, 10:33 PM   #58
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
i put new r8's in about 2-3 weeks ago and my car is sputtering now. dafuq? (during cold starts)
Old 01-28-2015, 10:52 PM   #59
willnando
willnando's Avatar
Mine has only done it while accelerating ...
Old 01-28-2015, 11:08 PM   #60
Gap your plugs to .032
Old 01-29-2015, 02:05 AM   #61
Winoman
Drives: '12 GTI St3 /'01 S4 St3 /'03 330ZHP
Approx 30K with the R8 coilpacks - all stage 3 - no issues...
2012 4-dr CSG Autobahn 6 spd / APR ST 3 (GT2871R) / Carbonio CAI / S3 FMIC / NSP TBP & TOP / R8 clpcks / GFB DV+ / NST RSR clutch / Wavetrack LSD / SPM st/tr CBE / BSH Pnd mnt / Koni clvrs / Spro fr ball jts & contr arms ALK / 034 Str Mts, fr & rear SB endl & catch can / H & R 24" rear SB / UB / Stern rsb / Tyrolsp fr sf ddst kit / DG SS / P3 Gauge / Euro switch / Dep Drk Chry Tls / Sndaktor del / 18" Neuspeed RS12
Winoman is offline   Reply With Quote
Old 01-30-2015, 03:32 AM   #62
GTI_likeurmom
GolfMK6 Elite
Drives: Veyron 16.4
i re-gapped my plugs, they seemed to be a little loose when i took them out so that could have contributed to the sputtering. i'll see what happens the when i drive to work in the morning.
Old 01-30-2015, 03:52 AM   #63
barnes93cb
barnes93cb's Avatar
Drives: '11 BMP 2Dr DSG GTI
Ive probably got 15k on my R8 coils since I went stage 2. No issues. Car is at 47k miles on stock spark plugs too. Im about to do the plugs as maintenance. But I have yet to notice any issues.
APR Stage 2 / CTS Intake / Twintercooler / Godspeed Downpipe / MagnaFlow Catback / H&R Springs
APR Stage 2/ Lowered Build Thread
Instagram: barnes93_vw
barnes93cb is offline   Reply With Quote
Old 01-30-2015, 03:57 AM   #64
GTI_likeurmom
GolfMK6 Elite
Drives: Veyron 16.4
how do i test the coil to see if its bad? i would assume just guessing that its bad isnt a fair assessment to its reliability.
Old 01-30-2015, 07:15 AM   #65
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
Black without sleeve failed when I went K04. reds are fine.
SOLD -> MK7 R
Old 01-30-2015, 03:01 PM   #66
McFuzz
McFuzz's Avatar
Had mine on for maybe... 5K miles? Not a single problem.
McFuzz is offline   Reply With Quote
Old 01-31-2015, 04:25 PM   #67
GTI_likeurmom
GolfMK6 Elite
Drives: Veyron 16.4
i finally got a code during the sputtering...
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AP HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0020
Revision: AAH18--- Serial number:
Coding: 0403010A18070160
Shop #: WSC 01357 011 00200
VCID: 74C913E717E3B7817A8-8021
4 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 98080 km
Time Indication: 0
Date: 2015.01.28
Time: 14:30:30
Freeze Frame:
RPM: 2749 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 31.0*C
Temperature: 12.0*C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 98080 km
Time Indication: 0
Date: 2015.01.28
Time: 14:30:34
Freeze Frame:
RPM: 919 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 32.0*C
Temperature: 12.0*C
Voltage: 14.351 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 98080 km
Time Indication: 0
Date: 2015.01.28
Time: 14:30:34
Freeze Frame:
RPM: 919 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 32.0*C
Temperature: 12.0*C
Voltage: 14.351 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 98080 km
Time Indication: 0
Date: 2015.01.28
Time: 14:30:34
Freeze Frame:
RPM: 919 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 32.0*C
Temperature: 12.0*C
Voltage: 14.351 V
Old 03-22-2015, 06:57 PM   #68
ralphykid67
ralphykid67's Avatar
Drives: 2012 CW 4DR-MT
Just had what appeared to be a misfire today. Running R8 coilpacks for about 15k now, untuned but did have 2 misfire's prior to that on stock coils.
I've yet to run the code for today's occurrence but it was a rough idle on start up and flashing cell. Rough idle about 10 seconds long.
How long will the code be available to view? Might not get to it this week.
ralphykid67 is offline   Reply With Quote
Old 03-22-2015, 07:08 PM   #69
Taiso0019
Taiso0019's Avatar
Drives: 2016 Accord Sport
Well previous owner threw them on around 302 on the odometer, along with Stage 1 (eternal thanks to you, previous owner!). The captain is nearly at 23000, only 1k of those being driven by me. But so far so good.
Super stock...
2016 Accord Sport - Current
Stock mostly...
2013 GTI DSG TR - Past
Taiso0019 is offline   Reply With Quote
Old 03-22-2015, 07:30 PM   #70
Modshack
Modshack's Avatar
Have you checked your plugs? Doesn't matter what CP's you are running if the gaps are wonky and plugs worn..
