Old 04-06-2014, 09:15 PM   #43
ssilver88
ssilver88's Avatar
Drives: 2012 2DR CSG GTI
Color matched side markers
Milage at time: 22.2k
Luckily I was able to leave the bulbs out without triggering a bulb out warning
Before
After
ssilver88 is offline   Reply With Quote
Old 04-07-2014, 03:38 PM   #44
Pmanpop
Pmanpop's Avatar
Drives: 2011 Vw GTI
Ssilver, you did the side markers yourself with those rattle cans from post #41?
Came out really nice
Old 04-07-2014, 04:02 PM   #45
ssilver88
ssilver88's Avatar
Yes I did. I am going to redo them though because I did not sand the primer perfectly smooth so there are some imperfections
Old 04-07-2014, 06:04 PM   #46
Pmanpop
Pmanpop's Avatar
Drives: 2011 Vw GTI
Sick. I definitly want to do this especially since its DIY. Whats the site you got the cans from? Thanks
Old 04-07-2014, 06:54 PM   #47
ssilver88
ssilver88's Avatar
The paint is from Automotivetouchup.com
I got the primer from autozone. It is just a sandable primer.
The only color you really need to get from Automotivetouchup.com is your car color. The gloss sealer and primer you can get elsewhere.
Old 04-07-2014, 07:01 PM   #48
graveshb
graveshb's Avatar
Drives: '11 135i
Looks phenomenal man, definitely convinced me to get around to it sooner than later.
graveshb is offline   Reply With Quote
Old 04-07-2014, 07:08 PM   #49
ssilver88
ssilver88's Avatar
Thanks guys
Now I have to go install my coils
EDIT: Coilovers going on tomorrow
Old 04-15-2014, 09:59 PM   #50
ssilver88
ssilver88's Avatar
Coilovers FINALLY on!!!
Mileage at time: 22.3k
Sitting at 25" FTG all the way around. So far i'm happy with them
Before:
After:
Old 04-16-2014, 12:52 PM   #51
ssilver88
ssilver88's Avatar
Just installed my Neuspeed Torque Arm Insert
Old 04-16-2014, 04:26 PM   #52
POPSMK6
POPSMK6's Avatar
Drives: 2012 GTI 6M, 2006 Passat (SOLD)
How hard was the install? Any tips.
POPSMK6 is offline   Reply With Quote
Old 04-16-2014, 04:34 PM   #53
ssilver88
ssilver88's Avatar
It was pretty easy. The toughest part for me was figuring out which way the screw turned. Opposite of a normal screw by the way. So for a while I was tightening it instead of taking it out. After that the insert itself is a pretty tight fit so you really have to jam it in there. Then I just screwed it in and the washer helped press it into place.
So far I've noticed wheel hop is non existent and gear changes are a little firmer. It's been great so far with barley any increased vibration (some on start up, in reverse and low rpm). One of the best mods you can do.
Old 04-16-2014, 05:32 PM   #54
POPSMK6
POPSMK6's Avatar
So to loosen the screw, go opposite? When screwing it back on, does it line up or do I need to worry about trying to line the screw up catching the dogbone?
Old 04-16-2014, 05:41 PM   #55
ssilver88
ssilver88's Avatar
Yeah instead of turning it right (clockwise) to tighten it its the opposite. So turn clockwise to loosen and counterclockwise to tighten. I didn't have a problem aligning it. It just stayed in place but if it does move it is really easy to move back
Old 04-28-2014, 03:03 PM   #56
ssilver88
ssilver88's Avatar
Just ordered Stoptech pads, USP SS lines and Motul fluid
