Closed Thread
Old 04-09-2014, 10:22 AM   #1
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
APR Presents the 2.0 TSI K04 Turbocharger System Version 3.0!
APR’s Engineering Teams have finished final testing of new version 3.0 K04 Turbocharger software for the 2.0 TSI/TFSI EA888 Gen 1 engine. The new ECU Upgrade improves upon power deliver on top of what was previously a tremendous upgrade over stock! Amidst addressing all previous concerns, additional motorsport features were added to further enhance your driving experience. Updates are now available at APR dealers and are offered as a FREE update for APR ECU Upgrade customers!
  • Please call to check file availability before booking an appointment! This is very important!
  • An OEM Bosch 3-Bar Map sensor, found here is REQUIRED to run this software. This is also very important!
  • Currently the software is available for North American CCT and CBF engines with CCZ and CAW rest of world engines under beta testing.
APR is pleased to present the 2.0 TSI EA888 Gen 1 K04 Turbocharger System!
[Product page link removed per golfmk6 rules]
For the budget minded individual, APR is pleased to offer software and hardware utilizing an APR proprietary customized version of the factory Borg Warner K04-64 turbocharger. Originally equipped on VAG’s high output models, such as the Golf R and S3, the APR K04 Turbocharger System offers a substantial leap in power and torque all with excellent response in a reliable and stealthy, compact design. Expect lightning fast response, smooth daily driving and power that transform the vehicle into a new class of enjoyment.
The APR K04 Turbocharger System features many upgrades over the 2.0T’s factory equipped IHI turbocharger, making it an excellent upgrade. The integrated turbofold design features a cast stainless steel exhaust manifold and turbine housing, integrated into one single unit. This design aids in turbocharger spool while the stainless steel construction is capable of withstanding higher exhaust gas temperature for longer periods of time than lesser materials, such as cast iron. The CNC-machined, billet aluminum compressor wheel and higher flow exhaust turbine wheel expand the turbo’s efficiency range, allowing for higher output across a wider RPM range.
True to APR’s mantra of Performance without Compromise the days of shredding tires on front wheel drive vehicles are rapidly disappearing thanks to the new Gold Standard in ECU torque management calibration strategies only APR can deliver. Compressor surge is avoided to increase the reliability of the system without limiting the area under the curve typically experienced during a top speed acceleration run. APR’s endless pursuit of perfection has resulted in the most comprehensive 2.0 TSI K04 turbocharger system and tuning package in the world.
Using 93-octane fuel, the APR K04 Turbocharger System produces an astonishing 360 horsepower and 382 ft-lbs of torque. Unlike the factory turbocharger, power stays strong and doesn’t dramatically taper towards the vehicle’s new 7,100 RPM redline. Switching to APR’s 100 octane race fuel mode, peak power and torque climb further to 375 horsepower and 408 ft-lbs of torque. APR’s calibration experts have safely maximized the full power potential of the turbocharger unit, while keeping reliability at the forefront of their calibration strategies.
APR K04 Turbocharger System Components
Turbocharger
At the heart of the K04 Turbocharger System is an APR proprietary customized version of the factory Borg Warner K04-64 turbocharger originally equipped on VAG’s high-output models, such as the Golf R and S3. The turbocharger features a CNC-machined, billet compressor wheel and stainless steel exhaust turbofold.
Each turbocharger unit is machined, assembled and clocked in house at APR with the necessary brackets to ensure proper wastegate fitment and orientation. Each wastegate is then calibrated for precise operation and control to ensure seamless integration with the expertly recalibrated OEM engine management system.
Integrated DV Adapter
One of the greatest benefits to the APR K04 turbocharger system is its simple, yet elegant design. APR's CNC-machined direct compressor recirculation port on the OEM compressor cover significantly reduces engine bay clutter and saves the end user from the hidden costs of purchasing extra throttle body pipes, hoses, clamps and DV mounts for recirculating boost pressure. The compact design also removes extra charge piping volume to allow for faster boost response and less locations for boost leaks. Furthermore, charge air pressure is directed directly at the compressor wheel which helps keep the turbo spooled upon lifting the throttle, minimizing turbo lag.
Turbo Outlet and Turbo Muffler Removal
The OEM k04 turbocharger features a turbo muffler designed to reduce turbocharger sound, but does so at the cost of ultimate performance. APR removes the turbo muffler not only to enhance the sound of the turbocharger, but to also provide a smooth airflow path across the previously baffled muffler section. A clean and simple CNC flange developed by APR's Mechanical Engineers is bolted directly to the compressor cover in place of the OEM turbo muffler. A long mounting surface provides an excellent slip-proof surface for mounting the included APR EZ-Flow silicone discharge hose and an o-ring between the flanges ensures a life of leak-proof operation.
PCV Blockoff Plate
The K04 turbocharger was originally designed for an EA113 2.0T engine, and as such, includes items not present on the EA888 2.0T engine. The compressor cover features a port used in the EA113’s PCV system, but on the EA888’s this same port is located higher up on the intake tubing. APR has provided a gasket-sealed laser-cut port cover to block off this part to ensure no unmetered air enters into the system. The design is clean and simple and never requires maintenance.
Engine Management
The factory Bosch MED 17 engine management system is responsible for proper operation of the engine during constantly changing environmental and load conditions. With built in compensational data for environmental variables and varying load conditions, the factory ECU is far more complex and intelligent than units found in other vehicle makes and marques.
With the significant amount of changes included in the APR K04 Turbocharger System, APR’s Engineers spent months calibrating the engine management system, including hundreds of hours of in-house chassis dyno development. Drivability, gear changes, cruising and part throttle operation were tuned to operate smoothly as if intended by the OEM through proper torque management. Further development was performed putting the vehicle through performance evaluation and durability testing at the drag strip and road course. APR’s Electrical Engineers built new coding functions, strategies and routines into the ECU to control conditions normally unseen at factory power levels. Thanks to APR’s incredible proprietary calibration suite, data logging software and full access to the coding structure of the ECU, appropriate and intelligent changes are made to ensure flawless drivability and excellent performance without compromise.
Engine Calibration:
APR’s Calibration Engineers restructured the engine’s volumetric efficiency (VE) model to correctly determine the ECU’s calculated load and deliver proper torque management. Thanks to APR’s patented boost control coding and the addition of a 3-Bar MAP sensor, the ECU is able to perform closed loop boost control well beyond relatively low limits dictated by the factory MAP sensor. This directly translates to safer and more predictable operation while additionally producing more power and torque across the entire power band.
Additionally, through the properly reconstructed VE model, accurate open loop fueling is achieved, translating to insignificant fuel trim adjustments. Closed loop fueling is calibrated to control lambda perfectly under all operating conditions. Furthermore, compensations, such as ones related to intake air temperature, exhaust temperature, and altitude, are adjusted to handle the larger variances compared to the factory, low-output setup.
APR’s Calibration Engineers have optimized cam timing, ignition timing, engine load and lambda to provide tremendous leaps in power while retaining the OEM knock control strategy. The result is safely achieved power, optimized for various fuel grades found around the world from low-quality pump fuel, all the way to high-quality, oxygenated race fuels.
Compressor Surge Avoidance:
To aid in turbocharger reliability and longevity, APR’s engineers carefully studied the turbocharger’s compressor maps to avoid regions where compressor surge may be experienced. The K04 turbocharger has fantastic response characteristics and is able to produce incredibly high pressure at low airflow levels, but in doing so, the turbocharger runs into issues of compressor surge. In the area between 3000-4000 RPM, APR’s Calibration Experts have elected to limit boost pressure. During testing, with the limits removed, APR’s engineers were able to easily achieve over 400 ft-lbs of torque with 93 octane fuel, but doing so could result in damaging the turbo’s reliability. Back-to-back testing was conducted with and without the limitation and despite the reduction in torque in this range, APR’s engineers were unable to record a measureable difference in accelerative performance.
Torque Management and Traction Control:
Torque management plays a big role in how the vehicle feels and performs, especially during moments of low gear, rapid acceleration. Typically front wheel drive vehicles suffer from excessive wheel spin during these moments due to the massive torque on tap from the K04 Turbocharger System. Some drivers can find themselves in situations where they are fighting against wheel spin and traction control when they are simply interested in going forward as quickly as possible. This is further compounded by the fact that the factory traction control (ASR) system was designed for vehicles producing far less power and torque, resulting in overcompensated ASR interventions.
APR’s Calibration Engineers set out to perfect torque management and traction control by minimizing wheel spin as much as possible without neutering the driving experience. A multi-step approach was taken to achieve appropriate control. With ASR enabled, forward movement wheel spin will trigger appropriate torque intervention levels to minimize spin without hurting forward acceleration. On top of this, the torque management system is fine tuned to deliver only as much torque as the tires can take. In normal conditions the tires will only slightly break loose under full acceleration, resulting maximum acceleration. In higher traction situations, or with ASR disabled, all of the system’s torque is directly on tap!
While the end goal is similar, APR’s torque management system differs greatly from archaic “boost-by-gear” strategies. “Boost-by-gear” strategies rely on a static limitation of boost in an effort to minimize wheel spin, but to work properly they must be dialed in for every situation. The same boost levels in different weather conditions, such as a hot summer day and a cold winter month, can produce vastly different torque levels. Since APR’s torque management system relies on the engine management’s phenomenal torque reporting abilities, it is able to adjust to every environmental situation it encounters. To achieve a targeted torque level, the ECU applies the appropriate changes to mass airflow and ignition.
Acceleration Enhancements:
Through further calibration changes APR’s Calibration Engineers were able to increase the acceleration rate of the vehicle. Ignition delays are reduced resulting in a more responsive pedal without altering overall throttle sensitivity and resolution. Drivability was greatly improved by reducing the throttle lag commonly noticed at slow speeds and while reapplying throttle after decelerating. APR’s Motorsport Rev Limiter allows power to climb all the way to redline without dropping off several hundreds of RPM earlier. Lastly, APR’s tried and tested Motorsport Launch Limiter allows the driver to focus on launching the vehicle, rather than controlling the engine speed.
Part-Throttle Drivability:
Beyond wide-open throttle performance, APR’s Calibration Engineers spent countless hours optimizing vehicle drivability under daily, part-throttle, driving. The vehicle fully retains its impressive daily driver status and simply has more power on tap should the driver request more with his or her right foot!
APR EMCS and APR Mobile:
APR’s EMCS program-switching technology and APR Mobile put control of the ECU in the operator's hand to access modes for standard pump fuel, high-output race fuel and even reduced-output valet modes to protect the vehicle against improper use by other individuals. This technology is patented by APR and is found nowhere else in the world. It’s Performance Without Compromise only APR can deliver!
Manifold Absolute Pressure Sensor
To provide closed-loop boost control at absolute pressure levels above 2.5 bar, APR’s K04 Turbocharger System features an OEM Bosch 3 bar MAP sensor.
Altering the ECU to understand the engine is equipped with a 3 bar MAP sensor is a trivial task. The sensor and proper calibration settings come standard on many factory VAG vehicles, but even these vehicles only provide proper closed loop boost control up to 2.5 bar absolute.
APR’s electrical engineers went many steps beyond the norm and recoded the factory ECU to deliver closed-loop boost control up to 3-bar absolute. This ability, combined with proper torque management, results in safe, reliable, and predictable performance at higher power levels without the need for clumsy and archaic external boost controlling devices.
Silicone Hose
A wire-reinforced, multi-ply silicone hose provide an unrestricted path for airflow exiting the turbocharger. The hose is engineered to properly connect the turbo’s outlet to the factory charge piping system.
APR’s Easy-Flow Silicone Hose design features stepped mounting surfaces for smooth transitions from one pipe to another. Traditional designs simply sit on top of each other, often resulting in a disruptive airflow path. By using the stepped design, hoses fit properly without airflow restrictions, resulting in the most ideal path for moving air through the turbocharger and into the engine.
Gaskets and Hardware
APR doesn’t cut corners even with the most mundane details of the kit. Every nut, bolt, stud, washer, clamp, and gasket necessary for the install is included with the kit.
Dyno Testing
Horsepower and torque were measured in APR’s in-house, Soundmaster dyno cell, using a Dynapack all-wheel dynamometer. Multiple stock and modified runs were conducted and the SAEJ1349 corrected results were averaged together to represent the differences between a stock and APR K04 2.0 TSI. Crank power figures were estimated based on VAG’s factory advertised results.
Click through the tabs below to view output using various fuel grades, power measured at all four wheels, estimated at the crank, and the absolute gain over stock.
91 Octane | 93 Octane | 100 Octane - Measured Front Wheel Horespower
91 Octane | 93 Octane | 100 Octane - Estimated Crank Horsepower
91 Octane | 93 Octane | 100 Octane - Gain over Stock
Calibration Report
Output:
200 HP & 207 FT-LBS of Torque - Stock as Rated by VAG
221 HP & 220 FT-LBS of Torque - Stock as Measured by APR
346 HP & 360 FT-LBS of Torque - APR K04 with 91 AKI or 95 RON fuel
360 HP & 382 FT-LBS of Torque - APR K04 with 93 AKI or 98 RON fuel
375 HP & 408 FT-LBS of Torque - APR K04 with 100 AKI or 104 RON fuel
Max Gains over Stock (based on APR's CCTA/CBFA measured output):
+133 HP @ 6,700 RPM & +143 TQ @ 4,400 RPM - APR K04 with 91 AKI or 95 RON fuel
+144 HP @ 6,700 RPM & +164 TQ @ 4,400 RPM - APR K04 with 93 AKI or 98 RON fuel
+166 HP @ 4,450 RPM & +191 TQ @ 4,450 RPM - APR K04 with 100 AKI or 104 RON fuel
Requirements and Recommendations
Intake System
APR's software is designed to utilize the factory mass airflow (MAF) sensor and housing. The Carbonio Stage I and II Intake System is highly recommended and required to meet the advertised power output.
Exhaust System
The APR Downpipe Exhaust System is required if the vehicle is not currently equipped with the APR Turboback Exhaust System. APR Recommends the APR Catback Exhaust System for maximum performance.
Intercooler System
The APR Intercooler System is required to meet the advertised power figures.
Transmission
The K04 Turbocharger System greatly increases torque over the factory output levels and as such, an upgraded clutch may be necessary to transmit power to the ground. APR highly recommends upgrading the factory clutch to one that suits the operator's intended driving style.
Exhaust Valve Springs
APR has discovered some engines experience exhaust valve float at high RPM at the advertised horsepower levels due to excessive exhaust backpressure caused by K04’s relatively small turbine wheel. In such cases, APR recommends upgrading the factory valve springs. However, upon request, lower output software capable of producing 321 horsepower and 310 ft-lbs of torque on 93 octane is available.
Tires
APR recommends Michelin PSS and PS2 tires as well as BFGoodrich Rivals and GForce Sport Comp 2 tires.
Fluids
APR recommends Motul Fluids and Lubricants.
Application Guides
Vehicles
Audi A3 (MK2)
Audi Q3
Audi TT (MK2)
Volkswagen Beetle
Volkswagen CC
Volkswagen Eos
Volkswagen Golf / GTI (MK5 / MK6)
Volkswagen Jetta / GLI / Bora / Vento / Sigitar (MK5 / MK6)
Volkswagen Passat / Magaton (B6)
Volkswagen Scirocco
Volkswagen Tiguan
Seat Altea
Seat Leon (MK2)
Seat Toledo (MK2)
Skoda Octavia / VRS (MK2)
Skoda Superb (B6)
Skoda Yeti
Engines
CAWA 2.0T EA888 Gen 1 Transverse (Pending: Beta Testing)
CAWB 2.0T EA888 Gen 1 Transverse (Pending: Beta Testing)
CBFA 2.0T EA888 Gen 1 Transverse
CCTA 2.0T EA888 Gen 1 Transverse
CCTB 2.0T EA888 Gen 1 Transverse
CCZA 2.0T EA888 Gen 1 Transverse (Pending: Beta Testing)
CCZB 2.0T EA888 Gen 1 Transverse (Pending: Beta Testing)
CCZC 2.0T EA888 Gen 1 Transverse (Pending: Beta Testing)
CCZD 2.0T EA888 Gen 1 Transverse (Pending: Beta Testing)
Transmissions
6 Speed Manual
S-Tronic
DSG
Tiptronic
Drivetrains
Drivetrain
Front Wheel Drive
All Wheel Drive
APR K04 Turbocharger System - Includes Software
Part Number: T2100016
Price: [price removed per golfmk6 rules]
SALE: [price removed per golfmk6 rules]
APR’s K04 Turbocharger System includes APR software, but for customers without APR’s Turbocharger System, who are looking to optimize their driving experience with the best engine management strategy available, APR’s K04 software is available separately. This software requires an OEM Bosch 3-bar map sensor and an OEM Borg Warner K04-64 turbocharger with no modifications to the turbo other than the required fitment aspects. All other requirements and recommendations above should be followed to ensure compatibility.
Software Only
Existing APR Software Customers - [price removed per golfmk6 rules]
New APR Software Customers - [price removed per golfmk6 rules]
Motul Oil, Coolant and Oil Filter
Part of the APR Turbocharger System install process requires removal of the OEM Turbocharger. During this process, oil and coolant must be drained and should be replaced to offer superior performance and protection. The APR Turbocharger Systems are now complete turn-key solutions, including everything you need down to the oil, coolant and oil filter. During checkout you'll be given the option between Motul Specific 502.00, 505.00 & 505.01 5W40 or Motul Power 300V engine oil as well as Motul Inugel Optimal Ultra Coolant and an OEM oil filter. The Premium Motul lubricant package is included at a much lower than retail price point and the costs are listed below.
Motul Specific Lubricant Install Package
5 Liters of Motul Specific 505.01, 502.00 & 505.00 SAE 5w40 Oil, Oil Filter & 4 Liters of Inugel Optimal Ultra (Concentrated) - Organic
Part Number: MO00003
Motul 300V Lubricant Install Package
6 Liters of Motul 300V Power 5W40, Oil Filter & 4 Liters of Inugel Optimal Ultra (Concentrated) - Organic
Part Number: MO00007
Arin@APR is offline
Old 04-09-2014, 10:27 AM   #2
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
Good job!
Very excited to get this on my CCZ ROW car soon!
SOLD -> MK7 R
xHeartcoreboyx is offline
Old 04-09-2014, 10:28 AM   #3
Arin@APR
Arin@APR's Avatar
Originally Posted by xHeartcoreboyx View Post
Good job!
Jamie's testing on ROW cars with varying fuels from bad 95 ron to the 100 ron good stuff and making adjustments such that you'll get all the goods from excellent fuel, and remain safe on the bad stuff.
Arin@APR is offline
Old 04-09-2014, 10:30 AM   #4
The Wiry Irishman
Drives: 2012 k04 GTI
So what exactly is the Launch Limiter?
Its hard to get excited about your "big" turbo when I work with jet engines.
The Wiry Irishman is offline
Old 04-09-2014, 10:30 AM   #5
A3SBQ
A3SBQ's Avatar
Drives: Audi A3 SB 2.0tfsi/TSI quattro DSG
wohooooo
A3SBQ is offline
Old 04-09-2014, 10:40 AM   #6
Arin@APR
Arin@APR's Avatar
When you rev up at the line, it will go to 3300 RPM and built a few PSI. Any more and it roasts the tires.
Arin@APR is offline
Old 04-09-2014, 10:44 AM   #7
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Holy.....crap......
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
grambles423 is offline
Old 04-09-2014, 10:44 AM   #8
lol gli
lol gli's Avatar
Drives: 2012 gli with some Chinese exhaust
2012 CFBA GLI 6MT box code good to go sean/arin?
just want to make sure before heading over
lol gli is offline
Old 04-09-2014, 10:45 AM   #9
shdwblugti
GolfMK6 Elite
shdwblugti's Avatar
Drives: 2016 non DSGhey R
Can you explain the 3 Bar sensor.
I am not familiar with it
shdwblugti is offline
Old 04-09-2014, 10:47 AM   #10
xHeartcoreboyx
Sounds great! So, its better to wait for the official file, right?
Is it a matter of days or weeks?
SOLD -> MK7 R
Old 04-09-2014, 10:47 AM   #11
sean@apr
Drives: Q7 TDI
Have no idea... PM me your VIN or use Vagcom/APR Mobile to get your boxcode.
sean@apr is offline
Old 04-09-2014, 10:47 AM   #12
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
In 4 reviews
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Mustache rash is offline
Old 04-09-2014, 10:48 AM   #13
lilfleck
Drives: '11 GTI Autobahn, DSG
Huge difference in torque and power for low output and high output file! Wow.. makes me think though, I would like to switch to low output in the winter when roads are frozen and traction blows.
lilfleck is offline
Old 04-09-2014, 10:48 AM   #14
GunKata
MILFn00dzHunter.com
GunKata's Avatar
It happened. It... happened.
Contacting dealer right MEOW.
Everybody knows GunKata > *.*
No GunKata, no care.
Chicago Car Network
I can haz 350z racecar?
GunKata is offline
Closed Thread
box code whining, boxcode blackhole, shouldnt have bought gli
