Old 07-11-2010, 03:40 PM   #1
04yllwTJ
04yllwTJ's Avatar
Drives: CG MKVI GTI
APR TBE fitment issues?
I installed my APR TBE a couple of months ago but since I was out to sea soon after I haven't had much chance to deal with this - the passenger side tip sticks out 1/2" to 1" farther than the driver's side. I got it on a lift the other day and made some adjustments, so it's a bit better now but still irritating. It's not super noticeable, but after spending that kind of money on an exhaust I'd prefer it to be close to perfect. I'm thinking I may have to take the piece that supports the driver's side rear rubber mount and bend it to the rear a bit. Any other ideas? Anyone else have similar issues? I'm thinking it's probably just slight manufacturing differences, on the car and exhaust. It probably doesn't help that we did it in a 1 car garage with jackstands.
Here are a couple of pics to try and show what I'm talking about.
ugh... needs a wash too
2010 CSG 3 door, BSH intake, APR TBE, APR Stage 2, Forge short shift kit, VAG-COM
2004 solar yellow TJ, 33's, winch, trail damage etc
2005 Suzuki LTZ400
04yllwTJ is offline   Reply With Quote
Old 07-11-2010, 03:42 PM   #2
DawnsKayBug
DawnsKayBug's Avatar
Drives: Nürburgringed
Thsi has been brought up before and ARIN told them what to do to fix it.
DawnsKayBug is offline   Reply With Quote
Old 07-11-2010, 04:03 PM   #3
happydude
happydude's Avatar
Drives: GTI
I noticed that on mine after it was installed though haven't taken any action to correct it.
happydude is offline   Reply With Quote
Old 07-11-2010, 07:04 PM   #4
GeeTeeEee
Drives: MKVI GTI
This is the only thing holding me back from buying the exhaust. Well this and the fact that the muffler sits below the diffuser.
GeeTeeEee is offline   Reply With Quote
Old 07-11-2010, 09:53 PM   #5
roastpuff
roastpuff's Avatar
Drives: Mk6 GTI
Whoa, whoa - when did you go Stage 2? Nice!
Old 07-11-2010, 10:48 PM   #6
MkVi_Ian
MkVi_Ian's Avatar
Drives: Deep Blk. Metallic MkVI GTI 2dr 6sp
this is how mine is too. but not as noticeable but still annoying
6 speed/APR TBE/APR stage 2/BSH stage1&2 intake/Koni Coilovers/H&R Wheel Spacers/Forge Short shifter/forge DV adaptor/New South Boost Gauge/
BFI Torque Arm insert/blacked out emblems and sidemarkers/tinted windows 10 in back and 35 in front/tinted headlights and taillights/rear wiper delete
MkVi_Ian is offline   Reply With Quote
Old 07-11-2010, 11:04 PM   #7
04yllwTJ
04yllwTJ's Avatar
Drives: CG MKVI GTI
Whoops. You wouldn't happen to have a link would you? I skimmed through all of his posts and couldn't find anything.
2005 Suzuki LTZ400
Old 07-12-2010, 12:17 AM   #8
whalesalad
whalesalad's Avatar
Drives: 2010 Candy White GTI, Manual
Apparently this issue has something to do with using an MKV downpipe on an MKVI, because one of them bends slightly and the other is straight.
But... a turboback includes a downpipe so maybe this information has no use to you
EVE • APR Stage II / BSH RACE / B&B 3" / DG S6 / B&G RS2 / MOTUL / VMR
facebook twitter wheelflip
whalesalad is offline   Reply With Quote
Old 07-12-2010, 12:32 AM   #9
TONY
TONY's Avatar
Drives: NINJA MKVI GTI
not sure that wasnt how mine was when i installed it but thats probably because i had my apr dp cut before i got the cat
- [ APR STAGE II+ ] [ APR TURBO-BACK EXHAUST ] [ CARBONIO INTAKE STAGE I & II ] - - [ APR 2.0 TSI INTERCOOLER ] [ FORGE BOV ADAPTER ] [ H&R SUPERSPORTS ] - - [ 30 % TINTS ] [ APR FRONT/REAR SWAY BARS ] [ ALPHARDS ] -
TONY is offline   Reply With Quote
Old 07-14-2010, 12:59 PM   #10
04yllwTJ
04yllwTJ's Avatar
Drives: CG MKVI GTI
Bump.
Anyone else have any ideas? Arin?
2005 Suzuki LTZ400
Old 07-15-2010, 11:29 AM   #11
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
Originally Posted by 04yllwTJ View Post
Bump.
The Issue:
The issue pertains to the intermediate pipe being pushed to far into the connection which in turn causes a preloaded scenario. After the exhaust system goes through it's first heat cycle it will naturally twist. This will cause the one side to stick out further.
The Solution:
1. Loosen the muffler and tailpipe connections.
2. Loosen the Intermediate pipe going to the muffler inlet.
3. Check the overlapping joints. Each pipe should only be inserted 50% of the way into the pipe and not bottomed out all the way. Each expansion joint has a slit in it. Use this as a reference and only go slightly beyond.
4. Square up the muffler by twisting it from underneath the car. This part helps to have a person twisting and another person checking the appearance.
5. Once aligned, retighten the clamps to 45ft-lbs.
Thank you! Let me know how it all works out!
-Arin
Old 07-16-2010, 11:27 PM   #12
Kiev
Kiev's Avatar
Drives: MKVI 2010 CW
http://www.golfmkv.com/forums/showthread.php?t=117840
Kiev is offline   Reply With Quote
Old 07-24-2010, 02:54 PM   #13
04yllwTJ
04yllwTJ's Avatar
Drives: CG MKVI GTI
The Issue:
The Solution:
-Arin
Thanks! I'll try that out once I get back home in a couple of weeks.
2005 Suzuki LTZ400
Old 10-23-2010, 09:44 AM   #14
drunknfoo
Drives: 2010 GTI 5dr CW DSG Loaded
posted this on vwvortex but figured it'll help here as well...
Back from the dead. But I had my exhaust installed awhile back now, went in once to get the tips aligned using the previous adjustments given, (still stuck out an inch or so). Today I found this on APR's site and think it should help with alignment.. Gonna attempt the alignment again later this week and see how it goes.
http://www.goapr.com/support/mk6-rsc-adjustment.pdf
2010 CW GTI APR Stage2
APR RSC TBE + S2 CAI
H&R Street Performance Coilovers + Sways
18 BBS RGRs + Dunlop Z1
Euro LED Tails + Others
drunknfoo is offline   Reply With Quote
