Old 05-04-2014, 10:46 AM   #43
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
thank god the rim isnt touched.
2015 Subaru Forester XT - Satge 1
www.lasthumansgarage.com
Old 05-04-2014, 10:50 AM   #44
Mindfields
Mindfields's Avatar
Drives: 2012 .:R
DUDE!! Ouch is right !
Mindfields is offline   Reply With Quote
Old 05-04-2014, 10:52 AM   #45
Mindfields
Mindfields's Avatar
Drives: 2012 .:R
Is the squeak up front ?, mine was the strut mount bearing, squeak stopped after I changed it out on my old GTI
Old 05-04-2014, 10:53 AM   #46
thedude4bides
thedude4bides's Avatar
Drives: '12 Golf R
It was so loud that I would have bet my life the wheel was bent but it doesn't even have a scratch. Guess I'll count my blessings
I'm probably going to bust out the trusty widow maker and throw the stock talledegas back on so I can get around until I can get a new tire. I'll probably need at least 2 because the Michilin PSS have about 15-20k on them.
Yep. It's up front. Thanks for the suggestion. I hope it'll get sorted out once I change out struts/springs and put in the bearings and mounts.
Old 05-04-2014, 11:44 AM   #47
Perpetuus
Drives: K04 GTI
It's not hard to spend $15K in mods. They really add up very quickly, and sometimes the car still looks stock
How do you like the VWR swaybars? It seems APR no longer sells them. I picked up a set for my Mk5 GTI and am waiting for some time to install them. Previously had H&R swaybars but I found them too stiff.
Perpetuus is offline   Reply With Quote
Old 05-04-2014, 11:49 AM   #48
Perpetuus
Drives: K04 GTI
Originally Posted by thedude4bides View Post
I've been thinking about holding off on trying to put these in... I've honestly been loving my stock suspension lately. The whole reason I picked these up was a squeak started manifesting going over bumps in the freezing temps. I don't know if it was the strut mounts, or the VWR sways, or what the hell was squeaking but it's not happening at al now.
So do I A.) sell these and use the money for other mods B.) hang onto them and install after my stock components take another beating this winter or C.) just have them put in.
The Koni FSDs are good dampers and work as advertised. I had the Pro-Kit version with Eibach springs bundled. Problem is, the left front damper was shot after 2 years. I've heard that they are only really designed for damping with stock springs at stock height.
I've had a chance to ride in an APR Stage 3 Golf R with 400hp and 400tq. Amazing. The AWD really is a great platform for extra power. Wish I could say that about my Mk5
Old 05-04-2014, 12:23 PM   #49
thedude4bides
Drives: '12 Golf R
How much drop did your eibach's have? The VWR are between 1/2 inch and 3/4 inch.
Edit- just saw your other post. I like the VWR sways. They are adjustable so I have soft up front and stiff in the rear. Soft is still like 15% stiffer than stock iirc. If the H&R's were not adjustable then VWR might be god for you.
Old 05-04-2014, 01:25 PM   #50
thedude4bides
Drives: '12 Golf R
After I removed the wheel, I saw that the inside of the wheel is bent a little
Old 05-04-2014, 01:35 PM   #51
Perpetuus
Drives: K04 GTI
I believe the Eibach dropped 1.25" from stock height, or 0.25" lower than Euro MkV height.
The H&R bars were adjustable, but both adjustments were too stiff in my opinnion. Can't wait to put these VWR swaybars on!
Íhlins | H2 Sport | Wagner Tuning | APR | AWE | Dieselgeek | VF Engineering | BBS | Wavetrac | VW Racing | H&R |
Old 05-06-2014, 01:03 PM   #52
thedude4bides
Drives: '12 Golf R
Ouch!
I just ordered 2 new Michilin PSS. My tread was at 5/32 so I couldn't just replace 1. I have the wheel-tire insurance so after mounting/balancing I owe $96. Not bad
Old 05-09-2014, 12:50 PM   #53
thedude4bides
Drives: '12 Golf R
Took the wheel to a wheel shop and it's bent enough to cause a wobble. I'm getting it straightened for $180. Seems steep but I don't really know because I've never had to repair a wheel before. The only other time I hit a pothole hard enough to damage the wheel was in 2003 with my mk4 and that was unrepairable... I guess all in all I've had pretty good luck with wheels.
Old 05-12-2014, 04:59 PM   #54
jp0319
jp0319's Avatar
Drives: 2015 Golf TDI SEL
I had the FSD / H&R Sports on my GTI for about 3ish years with no problem. This could have been different however given my current road conditions. I just installed Bilstein PSS coils and I am wondering if I should have kept stock suspension. The roads here in IA are so horrible, I get nervous every day driving, dodging the huge holes and cracks in the pavement . I dont know how long the FSDs would last under the current torture my car is enduring.
jp0319 is offline   Reply With Quote
Old 05-13-2014, 05:30 PM   #55
thedude4bides
Drives: '12 Golf R
Roads here ain't so pretty either... I'm still debating staying stock. Would the FSD's wear quicker than stock?
Old 05-18-2014, 06:48 AM   #56
thedude4bides
Drives: '12 Golf R
I tried to DIY the springs/struts and now my R is ruined. All kinds of squeeking, clucking, and knocking. What an absolute disaster.
Stock suspension was perfect. Absolutely perfect. I remember thinking on the last drive I took before the job that could be the last time I'll be happy with the suspension. FML.
