Old 04-23-2014, 08:43 PM   #1
03SVTCobra
S3 shifter help. Cant get stock shifter off.
I have everything apart. The stock will not come off. Any tips?
03SVTCobra is offline   Reply With Quote
Old 04-23-2014, 08:50 PM   #2
gti_kev
gti_kev's Avatar
Drives: A freaking Prius. #PriusGang
you have to pull up pretty hard... mine was stuck too but just keep prying it off.
be careful wit it doeee
here's reference. your almost done, but just in case..
http://www.golfmk6.com/forums/showthread.php?t=33087
2012 6MT CW GTi- not-so-Functional | REVO Stage 2. Bunch of shits and giggles, literally. RIP little stormtrooper.
gti_kev is offline   Reply With Quote
Old 04-23-2014, 08:52 PM   #3
RaV$
RaV$'s Avatar
Drives: 2011 Gti
there will be a metal bracket i believe put a flat head in between to loosen it it should pull right off. you will have to use the same bracket after tighten with pliers
2011 Gti // APR IC // SPM Street TBE // Uni Intake // 18" F14's // Stage 2+
RaV$ is offline   Reply With Quote
Old 04-23-2014, 09:05 PM   #4
03SVTCobra
Ill give it a go tomorrow. I was prying pretty damn hard and it wouldn't budge.
Old 04-23-2014, 09:05 PM   #5
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
the more you are able to loosen the metal clamp the easier it will be.
Old 04-23-2014, 09:07 PM   #6
RaV$
RaV$'s Avatar
Drives: 2011 Gti
its hard to get off to begin with you have to bend that metal piece to open more it will come out eventually
Old 04-23-2014, 09:22 PM   #7
GreasyGinzo
GreasyGinzo's Avatar
i would assume he is talking about the f to b shift arm on top of the trans if so you have to put it in neutral where it freely moves up and down and just keep yanking up using your arms as a slap hammer mine came right off after about 7 or 8 slaps
Build Thread / Life Story
Old 04-23-2014, 10:05 PM   #8
Jerseynoob
Drives: 2010 Jetta Wolfsburg
get one of those tools for battery terminals, similar concept as a corkscrew
Jerseynoob is offline   Reply With Quote
Old 04-23-2014, 10:48 PM   #9
blue2.8
Drives: 2010 6MT
a quick shot of wd40 and mine came right off after struggling with it for a few minutes
blue2.8 is offline   Reply With Quote
Old 04-24-2014, 12:51 PM   #10
DDKing13
DDKing13's Avatar
Drives: 2012 GTI 6MT
Yeah definitely make sure it's in neutral and locked in the home position. If not, it WILL NOT come off.
Founder/Designer of Homegrwn.
RIP GTI.
My new DD: E30 Build Thread
DDKing13 is offline   Reply With Quote
Old 04-24-2014, 01:04 PM   #11
mg_90
mg_90's Avatar
Drives: 11 GTI
^^This
A bit of WD40 and mine came out efortless.
mg_90 is offline   Reply With Quote
Old 04-24-2014, 01:29 PM   #12
GreasyGinzo
You don't want it locked because you need the movement to help you get it off
Old 04-24-2014, 01:32 PM   #13
mamock116
mamock116's Avatar
Drives: 2013 GTI MT
As others have said, make sure it is in neutral and then pull hard.
mamock116 is offline   Reply With Quote
Old 04-24-2014, 02:00 PM   #14
Jordanka
Drives: Passat 6MT
Gonna second Ginzo here and say that you DO NOT want to lock the transmission. Put the car in neutral, engage handbrake, remove the nut locking the shifter in place then push down on the lever and pull up firmly - similar to compressing a spring and releasing. On the fourth try it came right off, no need for WD40.
When re-installing your new shifter, make sure you mark the larger groove with a marker so that it's easy to re-install.
Good luck!
Jordanka is offline   Reply With Quote
