HYDE16 Reviews - deAutoKey 1800 Lumen CREE LED Fog Light Kit
HYDE161
UPDATE: Just a reminder NOT to mount the resistors anywhere near or on the ballasts, this is a prime example of what NOT to do.
808bahn
So, did you screw the resistor onto metal in the engine bay?
808bahn
Understood. Thanks!
I actually have mine in a secured "free-float" configuration for the most surrounding air, it does not come in contact with anything around it while driving.
deAutoLED.com
GolfMK6 Official Vendor
Understood. Thanks!
:thumbsup: Thanks for the info, we get asked this a lot, we normally suggest drilling it to metal, but if this method works, we will let our customers know.
dyeguy
New member
Has anyone used these as your low beams in the halogen housings? Curious to see how bright they are. Thanks
deAutoLED.com
Yes, many customers have installed these as low beams in a halogen housing, they look good. Perfect beam pattern, bright and will look classier than an HID kit as it will not be blinding or cause a glare for oncoming traffic.
Please note that the MK6 GTI requires modification to your holder to work, they are not going to fit as the MK6 GTI has their own adapters and NOT a regular H7 adapter.
Thank you for the question :thumbsup:
rpandresen
Can you go into a little more detail about this? What do we have to modify and what is required?
deAutoLED.com
Can you message me that info as well? Is it the same for the golf?
Ok, you have to tap into your wires, and you have to cut your adapter to get the LED headlights to work.
However, we have an H7RC HID Kit, this is made for your reflector housings:
http://deautokey.com/product/new-h7...-35w-slim-digital-ballast-with-canbus-adapter
With this, you only have to tap into your wires, but you DO NOT have to cut your adapters as these will come with adapters.
We hope this makes sense, please let us know if it did not.
Thank you:thumbsup:
