APR Presents the DQ250 DSG & S tronic TCU Upgrade!
Arin@APR
GOLFMK7 Official Sponsor
APR is pleased to present the ultimate transmission control unit (TCU) upgrade for the DQ250 Exx & Fxx DSG and S tronic transmissions! APR’s TCU upgrade is available in engine and power level specific variations and is conveniently flashed to the vehicle’s factory TCU through the OBD-II port. APR’s patented DirectPort Programming Suite allows the end user to customize the TCU upgrade to their individual needs.
APR’s TCU upgrade enhances the driving experience by incorporating many of the same features typically reserved for high-end Audi Quattro GmbH RS models. Under blistering, wide-open throttle acceleration, the transmission shifts even more quickly than before with a higher rev limit. However, during normal, day-to-day driving, the TCU Upgrade delivers a smooth, more refined, driving experience.
End User Adjustability
APR’s DirectPort programming suite allows users to custom tailor the TCU upgrade to their needs at the time of installation. Users are given the following options, which they may change at an APR dealer at any time:
  • User definable APR pre-optimized shift patterns based on current stage of engine performance
  • User definable launch control RPM
  • User definable manual mode max RPM
  • User definable manual mode automatic upshift on or off
  • User definable manual mode automatic downshift on or off (Kickdown switch)
APR will adjust any mismatch between Engine Control Unit (ECU) and TCU max RPM or standing rev limters, should any conflicts arise.
Drive Mode Characteristics
Drive mode’s performance and comfort is greatly improved based upon the current stage of engine performance. Gear change upshift and downshift points occur based on engine load and throttle position, rather than hard set points, and as such occur more smoothly and less abruptly. The driver may feel more connected to the vehicle as the gear changes occur more naturally. Under part throttle driving, the transmission will stay in the current gear until the appropriate moment necessary to shift, rather than jumping to higher gears too quickly. This is especially true for calibrations geared towards larger turbocharger systems where response characteristics of the turbocharger changes the part throttle driving experience. Under wide-open throttle acceleration, shifting times are reduced and the maximum shift point RPM is set to the ECU’s rev limiter.
Sport Mode Characteristics
Sport mode’s performance and comfort is also greatly improved based upon the current stage of engine performance. Expect extremely fast gear changes as the wide-open throttle shift times are reduced. APR’s taken a two-stage approach to wide-open throttle operation as well. Shift points are optimized to deliver the fastest acceleration possible under wide-open throttle by following the torque curve of each available stage. However, with the pedal pressed far enough to hold the kickdown switch, shifts points override the torque curve and now occur at the maximum engine RPM!
Part-throttle drivability is greatly improved too. Some factory DQ250 transmission software is too aggressively geared towards holding high RPMs, and often uncomfortably downshifts when unwanted. Under low accelerator pedal position, low load driving, gearshifts occur earlier, allowing the driver to enjoy sport mode even during those moments when wide-open throttle operation is not permissible. However, should the driver request more torque with his or her right foot, the transmission comes alive in the true spirit of sport mode!
Manual Mode Characteristics
At the time of installation, the user is able to select several options that change the behavior of manual mode. The user has the ability to enable or disable either the manual mode automatic kickdown switch for automatic downshifts as well as the automatic upshift that occurs at redline. For safety and acceleration, APR’s engineers kept the automatic upshift present in first gear.
The ECU defines the maximum engine RPM possible. Using APR’s user definable max RPM settings, the end user can match the ECU’s RPM to the TCU RPM to avoid hitting the engine rev limiter should the automatic redline upshift option remain active. In the case where an APR ECU Upgrade's redline is lower than expected, APR can issue a free ECU update to correct the max engine RPM.
During manual mode shifting times are not only greatly improved, but the artificial delays between requesting a shift with the paddles and shifter are reduced as well. As soon as a shift request is made, the transmission instantly begins the shifting routine. Furthermore, the downshift lockout is removed, allowing the operator to downshift at any point, so long as the next gear does not surpass the max engine RPM.
With manual mode tailored to the end users need, they are presented with a more enjoyable driving experience that operates exactly how they choose. We call it Performance Without Compromise!
Launch Control
APR’s TCU upgrade enables launch control on all vehicles. At the time of installation, the user is able to select their desired launch RPM, as they see fit! Launch control activates quickly, with a wider operating window, by limiting some of the stubborn activation criteria some models face during activation. The end user will notice launches now occur more rapidly with less delay between releasing the brake and forward momentum. The clutches fully grab quickly off the line and shift times are reduced. This directly translates into faster acceleration!
APR will adjust any mismatch between Engine Control Unit (ECU) and TCU standing rev limters, should any conflicts arise.
*Please Note, the vehicle must be equipped with a traction control button to enable launch control.*
Gear display indicator
APR’s TCU upgrade enables the gear display indicator for Drive and Sport mode in the vehicle's multi function display.
Torque Limits
All too often TCU upgrades are sold as a solution to “torque limiters” in which many companies charge extra to raise. While some companies may have trouble with torque interventions from the transmission, even at stage I power and torque levels, APR ECU upgrades do not require a TCU upgrade to meet advertised peak torque levels. APR does not charge extra to “raise the limits.” Raising the limits does not increase performance and does not increase the transmission’s ability to hold more torque. The maximum torque limiters are simply removed, allowing customers unrestricted operation. In the event torque is limited by the factory clutches, upgraded units may be installed and torque may be increased without TCU intervention.
DSG Temperature Management
Temperature management is an important part of the DQ250 transmission. While some software may simply remove temperature protection routines all together and claim increased cooling performance, APR’s TCU upgrade only allows the maximum safe temperature levels before intervention. Unlike the factory intervention routine, which simply allows for nearly no torque to be transmitted through the transmission at all, APR’s over temp intervention allows for a very limited amount of torque, enough so the vehicle can be safely driven off the track or pulled to the side of the road. In keeping the vehicle moving, airflow continues across the radiator, which in turn keeps coolant temps low and aids in removing heat from the factory DQ250 water to oil cooler to restore full operation.
Typical Max ECU Rev Limits
  • Naturally Aspirated Engines (ex, 3.6L FSI) - 6,800 RPM
  • 2.0T TDI CR Engines - TBD
  • 2.0T EA113 K03 Turbo Engines - 6,800 RPM
  • 2.0T EA113 K04 Turbo Engines - 7,100 RPM
  • 1.8T & 2.0T EA888 Gen 1 IHI Turbo Engines - 6,800 RPM
  • 2.0T EA888 Gen 2 IHI Turbo Engines - 6,800 RPM
  • 2.0T EA888 Gen 3 Honeywell Turbo Engines - 6,800 RPM
  • 1.8T EA888 Gen 3 IHI Turbo Engines - 6,800 RPM
  • 2.0T EA888 Gen 3 IHI Turbo Engines - 7,100 RPM
  • K04, Stage III and III+ Upgraded Engines - 7,100 RPM
Any mismatches in APR ECU/TCU redline can be altered upon request.
The APR Difference
Please note APR’s TCU upgrade is for the Temic Tricore based Exx and Fxx transmissions. Earlier Power PC based Cxx transmissions as found in vehicles such as early K03 based EA113 2.0T’s and older 3.2L VR6’s greatly differ in their features, capabilities and TCU complexity.
APR TCU Upgrade Creation
APR’s engineers have taken a direct and custom approach to calibrating the TCU. All too often others create a generic calibration that is forced across a wide range of different vehicles and transmission versions. Unfortunately this generic method of copy and paste tuning can result in some undesirable effects, such as slow up shifts and downshifts, torque interventions, stumbling and immobility. In some extreme cases, damage to the transmission can occur. With hundreds of factory TCU variations available for the DQ250, APR’s engineers have painstakingly ensured every TCU upgrade is created using the transmission’s original file to ensure the ultimate experience!
APR DirectPort Programming
APR’s patented DirectPort Programming is now available for the Temic Tricore Exx and Fxx DQ250 transmissions. Any APR Dealer in the world, connected to the Internet, has direct access to APR’s latest TCU upgrades for installation directly over the vehicle's OBD-II port. This completely eliminates the need to remove and open the TCU and can be uninstalled at any time!
APR TCU Composer
APR’s proprietary TCU Composer is used for altering the transmission management system. With full access to every table, map and variable within every TCU, APR’s Calibration Engineers are not limited to the handful of pre-defined maps as is common for most tuning companies.
APR TCU Assembly
APR’s Electrical Engineers have the ability to alter the code structure of the TCU. Through code levels changes, APR's Engineers are able to add future features to the TCU otherwise impossible through calibration changes alone.
Application Guides
For best results, APR advises against mixing and matching non APR TCU and ECU Upgrades. APR cannot guarantee complete compatibility with non APR ECU upgrades. Please read our 30 day money back guarantee section for more details.
Transmission Types
DQ250 - Exx & Fxx - Temic Tricore - 6 Speed DSG & S tronic
Stages
Stage I - For use with the stock turbo and naturally aspirated engines
Stage II - For use on vehicles with an upgraded K04 Turbocharger
Stage III (COMING SOON!) - For use on vehicles with an upgraded Stage III/III+ or larger Turbocharger
Each stage is specifically tailored for each individual application
Price
Removed per Golf MK6 Rules
Please note changing options or switching between stages I and II is free!
Supported Vehicles / Engines
2.0 TDI CR - Transverse - Coming Soon
2.0T - EA113 - Transverse - Exx and Fxx only. Early Cxx models not available.
1.8T - EA888 Gen 1 - Transverse
2.0T - EA888 Gen 1 - Transverse
2.0T - EA888 Gen 2 - Transverse - (Late model TT)
2.0T - EA888 Gen 3 - Transverse - 2013.5+ Jetta/GLI, Beetle & Passat
2.0T - EA888 Gen 3 - Transverse - New MQB GTI, R, A3, S3, Octavia Etc Coming Soon!
3.6L FSI VR6 - Transverse - Exx and Fxx only. Early Cxx models not available.
How to Purchase
Locate an APR Dealer
Use the APR Dealer Locator Tool to find an APR Dealer near you. The APR Dealer will have the ability to upgrade your TCU while you wait!
Security, Warranty and Money Back Guarentee
30 Day Money Back Guarantee
All APR TCU Upgrades include a 30-day money back guarantee with no questions asked. If for any reason you are dissatisfied with the APR TCU Upgrade, return to your place of purchase for a full refund, provided you are within the 30 day period from the time of your initial purchase. Labor or shipping charges are not included in the guarantee and are at the discretion of the place of install.
Limited Lifetime Warranty
All APR TCU Upgrades include a limited lifetime warranty against defects in the software, and to provide free updates and reflashes as they become available. Labor or shipping charges are not included in the warranty and are at the discretion of the place of install.
shdwblugti
:thumbup:
dhk.00
Finally :D
rs999
Why oh why must I be in the Big Turbo camp. :mad0259:
But great news on this DSG release nonetheless, now I can keep everything in the APR family :thumbup:
KO7
I said wow. :O
Tempting even at stock power levels.
Lodi
Definitely nice to see this has finally arrived. Must go look at prices.
Too bad it's exactly 1 day after my first track day of the the season...
I do like the idea of a 30 day money back guarantee though. Gives us the chance to see if this software is somth we really want/need. :thumbsup:
ViR
The Russian
Called my APR dealer, they didnt hear about this yet.. lol I'm too impatient...
Arin@APR
Yup! Try it out. If you don't like something, tell us, and we may be able to make it better. If you just want a refund, no biggie, you have 30 days to get one. : ) :thumbsup:
2017GTI4me
Awesome news! I have been nothing but pleased with the new V3 K04 update. It almost seemed to smooth out a lot of the DSG issues I had on its own, but I have a feeling the DSG tune will completely change the way the car drives!
bmc333
I started beta testing this past Saturday and so far I'm loving it. Really makes a big difference in spirited driving and maintains the daily drivability. Downshifts are SO much smoother/faster now - its like butter.
ROOSTER1050
Arin --- would this (final) version, be any different from a beta version that someone may have received in March? (25th to be exact) :rolleyes:
