Old 05-18-2015, 02:08 AM   #43
gjas18
Drives: 2012 Golf TDI Tech Package
Originally Posted by chips View Post
Hi,
One question, after you codify your car using VCDS to enable LPA 2.0, the OPS in the radio shows the 360 sensors, all the 12 sensors or just the 8 sensors (front and rear)?
Like this:
I'm waiting to my kit to upgrade to LPA 2.0 comes.
Thanks a lot.
Yes it will display just like that picture and the one in my diy. the sides sensor will not show up until the car moves past an object, I think it uses the wheel speed sensors and the side sensors to create that view.
gjas18 is offline   Reply With Quote
Old 06-09-2015, 12:27 AM   #44
chips
Drives: GTI MK6
Hi,
Today I received my upgrade kit to PLA 2.0.
My GTI comes with 8 OPS sensors from factory and I buy the kit to upgrade to PLA 2.0 in carsystems. This one:
http://www.carsystems.pl/vw-golf-6-p...75l,id696.html
Do you have a manual or diagram to connect all the wiring? I'm a little lost with that, I really appreciate if you have one in detail that guides me on how to connect the 4 extra sensors.
My kit comes with the module 3AA 919 475 L, my question is, this modules that comes with the kit replaces the modules that comes from factory that controlls the 8 OPS sensors? or it works together?
Thanks a lot for your help.
I attach the things that I received in the package.
chips is offline   Reply With Quote
Old 06-09-2015, 10:58 AM   #45
gjas18
Hi,
In your images the cables are labeled with the connectors and pins the loose wires need to be placed in on the PDC module. Yes the new module will just replace your current one. If you look at the connectors when you replace the module with the new one the pins will be labeled with really tiny numbers. Just be sure to run the cables to the bumpers before you insert these wires; it will be much easier to fit them through the rubber grommets as loose wires.
Old 06-09-2015, 12:06 PM   #46
chips
Drives: GTI MK6
Thanks a lot for the reply.
Your right, I found in vortex forum some diagrams on how to connect all the wires with the pins in the PDC Module, and with the labels on each wire that came in the kit, now I know how to connect it all.
Luck that my GTI allready came with the 8 sensors, I just have to add 4 more, change the PDC module, install the ABS Sensors and the switch to activate.
Today I'll start the installation, i'll let you all know my progress.
Here are the diagram I found.
Also it help me this document:
https://dl.dropboxusercontent.com/u/...golf%20pdc.pdf
Old 12-01-2015, 07:56 PM   #47
Mcr
Drives: MK6 Golf GTI 2012
Pla 2.0 12 sensor kit ground and databus faults
Dear all.
I have a bit of a problem.
My Golf is a MK6 GTI 2012. No parking sensors. So I bought the 2.0 12 sensor kit with alibaba link as suggested.
I painted the sensors with spray paint with correct paint code etc and fitted into canbus cigarette lighter and rear reg lights as sugggested. Not sure why i need to fit rear sensor loom into rear reg lights as the rear sensors already were getting 12 volts?
Anyhow i have coded etc but not done the abs sensors just yet as i want to test the sensors so i connected all and powered on. When pressing the sensor button or go in reverse the lights for the button beeps long for a bit then just flashes so i got my vcds out and ran a scan. I see 2 faults on address 10 park/steer assist:
Control module part number 3aa 919 475 s
Parkhilfe pla h06 0043
1079828 supply voltage for parking aid sensor(s)
B107a 14 [009] open or short to ground
The other is
12658720 databus
U1121 00 [009] missing message
Confirmed tested since memory clear
If anyone has any clue on what is going on it would really help. Have spent 3 nights trying to resolve this and getting nowhere so far.
Thank you
Mcr is offline   Reply With Quote
Old 01-06-2016, 05:03 PM   #48
chips
Drives: GTI MK6
So I figured it out with the help of a electric diagram that I found.
So this is the answer to my own question LOL.
The left and right rear side sensors that use the LPA 2.0 has to be connect in PIN 6 (right rear side sensor) and 10 (left rear side sensor).
For the left and right front side sensors that use the LPA 2.0 has to be connect in PIN 9 (left front side sensor) and 10 (right front side sensor).
Now it works just fine, all the 12 sensors !!! I'm so excited, i want to park everywhere jajajajaa
Old 04-02-2016, 10:41 AM   #49
Mcr
Hello,
Still having issues with mine I'm afraid.
It's PLA 2.0
And these are the only fault codes:
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56231203401265
Coding: 141001
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000_SE36.rod
VCID: 44A9A290CF4BC01E15-8010
4 Faults Found:
1080580 - Side Rear Left Parking Aid Sensor
B107D 04 [009] - Internal System Fault
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 52556 km
Date: 2016.04.02
Time: 15:14:56
1080836 - Side Rear Right Parking Aid Sensors
B107E 04 [009] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 52556 km
Date: 2016.04.02
Time: 15:14:56
1111556 - Side Front Left Parking Aid Sensor
B10F6 04 [009] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 52556 km
Date: 2016.04.02
Time: 15:14:56
1112836 - Side Front Right Parking Aid Sensor
B10FB 04 [009] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 52556 km
Date: 2016.04.02
Time: 15:14:56
So some issue with the PLA2 side sensors only. Any ideas?
Old 05-25-2016, 12:32 AM   #50
kahuna
kahuna's Avatar
I just got my 2011 GTI - never had a VW before. Was wondering how I would run the wires for a license place mounted rear view camera then I found your post. Now I'm pondering, go with the $60 license plate mount and spend a day (?) removing and replacing the rear bumper, or $300 for the VW Badge rear view camera and spend less time...
kahuna is offline   Reply With Quote
Old 01-09-2018, 06:58 PM   #51
Cal2000
Drives: 13' GTI 4DR AUTOBAHN
Reviving this thread w/ hope that OP or someone can answer this question.
Does this kit from Carsystems have "angled sensor holders" that OP was referring to?
I wonder those grey holders in the pic are the ones that OP was referring to;
http://www.carsystems.pl/vw-golf-6-5...ar,id1395.html
Old 01-26-2018, 02:52 PM   #52
spopinski
Drives: Golf MK6 1.4 TSi
Yes it's correct, and not just the holders, I think the sensors is different between the normal and the sides. THe module will also be different
spopinski is offline   Reply With Quote
Old 01-26-2018, 10:27 PM   #53
Cal2000
Cool. Thx!
