Old 06-14-2014, 06:45 PM   #1
2lazy4agoodname
2lazy4agoodname's Avatar
Drives: 2010 CW GTI
Question Passenger Door Handle Removal??
So i have searched up and down and cannot seem to figure out how to take out the passenger exterior door handle. I pulled the 2 grommets on the side of the door but it is not like the driver side where there are 2 bolts. Help would be much appreciated!!
10' MK6 GTI DSG/Candy White
Revo Stage 2/Eurojet Catless Down Pipe/H&R Ultralows/Volk Le37/Godspeed CBE/ APR Carbonio
09' Holden SSV Stuff and things. 9.89 @139
16' Chevy SS Sedan
2lazy4agoodname is offline   Reply With Quote
Old 06-14-2014, 07:46 PM   #2
2lazy4agoodname
Drives: 2010 CW GTI
Need to figure this out asap!!
16' Chevy SS Sedan
Old 06-15-2014, 04:18 PM   #3
yunone
Drives: 2012 CSG GTI
Might be helpful
http://www.golfmk6.com/forums/showthread.php?p=39968
Sent from my HTC One max
yunone is offline   Reply With Quote
Old 06-15-2014, 11:50 PM   #4
2lazy4agoodname
Drives: 2010 CW GTI
Still stumped.
16' Chevy SS Sedan
Old 06-16-2014, 02:30 AM   #5
trev1342
FIA Formula 1 Champion
trev1342's Avatar
Drives: '14 GTI Driver's Edition DSG
Hmm.. I'll try and look around.
DeAuto Full LED Kit w. Red Footwells - Aluminum Glove Box Handle - OEM Auto Euro Light Switch - VAG-COM - Clear Side Markers - Amber LED Side Marker Bulbs - APR Carbonio Intake - APR Stage 1 Tuned - OEM R8 Coil Packs - OEM Porsche Coolant/Oil Caps - Black Wiper Fluid Cap - ECS Carbon Fiber Engine Cover - Bright Halogen Fog Light Bulbs - OEM Golf R Euro LED Tails (R20) - DeAuto Amber Front/Rear LED Turn Signals - DeAuto LED Reverse Lights
trev1342 is offline   Reply With Quote
Old 06-16-2014, 09:26 PM   #6
Draz
Draz's Avatar
Drives: '11 Golf TDI
Only the driver side has the "locking cylinder" Here's how to remove the handles that don't have the lock:
"Remove plug -3- from rear opening.
Guide assembly tool -T10389- approx. 60 mm into door behind locking device -2- of bearing bracket.
Pull assembly tool -T10389- backwards -arrow- until hook releases."
" Pull door handle -2- in direction of -arrow a-.
Pull cover cap -1- off door -arrow b-."
This is the special assembly tool that the instructions refer to:
Here's how to install it:
Slide cover cap -1- into bearing bracket -arrow b-."
" Remove plug -5- from front opening.
Guide a screwdriver -4- onto locking device -3- of bearing bracket.
Push screwdriver inwards -arrow- until hook engages."
Here's the door lock overview (#4 is only on the driver side):
Hope this helps you out, good luck!
Draz is offline   Reply With Quote
Old 06-16-2014, 09:55 PM   #7
2lazy4agoodname
Drives: 2010 CW GTI
Figured it out. Thanks a ton guys!!!
Sent from my SCH-I545 using Tapatalk
16' Chevy SS Sedan
Old 06-17-2014, 12:21 AM   #8
trev1342
trev1342's Avatar
Great!
Old 05-13-2015, 11:33 AM   #9
cpham12
Drives: 2 dr '10 GTI
Does anyone know if this can possibly be done without the specialty tool? Could a similar tool be fashioned out of let's say a wire coat hanger? Just trying to be as cost efficient as possible before resorting to dropping $30 on a tool I'll use at most twice in my life. Thanks plenty!
cpham12 is offline   Reply With Quote
Old 05-13-2015, 11:57 AM   #10
2lazy4agoodname
Drives: 2010 CW GTI
Get a hook and pick set. That's how i took mine off. Or if you want to save some momey just pop the panel off and you will see how the mechanism works. Really easy to take apart.
16' Chevy SS Sedan
Old 05-18-2015, 02:14 PM   #11
cpham12
Thanks! I've seen your wrap work and was inspired to try it out myself but got caught up with the door handles. Hopefully, I can start making better progress.
Old 04-27-2017, 03:07 PM   #12
Hedgehodge
Cap keeps falling off (number 1, or 6 showing picture with lock cylinder). Its on my drivers side. I bought a new one, pops off after opening the door like 3 times. Really annoying, dealer has no clue either.
It seems like #4 in the last picture is a little loose, is there a way to tighten that up so the snap cover piece holds in better maybe?
They are trying to say I glued it there, i dont even know how that would work or what glue id put there lol. I got it back after having the block replaced and found the cap on the pass side floorboard when I got home I figured id snap it back in....nope. Ordered a new one and had them try to put the one they ordered on too, no luck. VW dealership.
Hedgehodge is offline   Reply With Quote
Old 05-01-2017, 02:25 PM   #13
Hedgehodge
what is part 5 in the last photo, anyone have a part number please.
Old 09-04-2017, 09:58 AM   #14
vwGOLF6
Can somebody help me please!!!
I took off the door handle and when I was fitting this back it gets stuck. So the handle doesn't work and don't get in.
Any ideas? Already tried to move the the lock in the holl but no success
Verzonden vanaf mijn iPhone met Tapatalk
vwGOLF6 is offline   Reply With Quote
