Old 09-04-2017, 11:29 AM   #15
mikeleemk6
mikeleemk6's Avatar
Drives: Shadow Blue GTI MK6
Originally Posted by vwGOLF6 View Post
Can somebody help me please!!!
I took off the door handle and when I was fitting this back it gets stuck. So the handle doesn't work and don't get in.
Any ideas? Already tried to move the the lock in the holl but no success
Verzonden vanaf mijn iPhone met Tapatalk
You need to take the back cap off, then make sure the handle part latches on before you put the cap back on. Push the handle firmly forward to lock it on to the latch in the opening and then it will sit flush and you can then put the cap back on.
Old 09-04-2017, 11:36 AM   #16
vwGOLF6
I can't take the little cap off, I tried many times with that special tool. So....?
vwGOLF6 is offline   Reply With Quote
Old 09-04-2017, 11:38 AM   #17
mikeleemk6
mikeleemk6's Avatar
Only the driver side front door is screwed down, well the lock portion. All of them are just caps that slide on. All you have to do is look at the bottom of the cap and there is a little recess in it. Put a flat head in that cutout recess on bottom of the cap and carefully pry it off.
Old 09-04-2017, 11:51 AM   #18
vwGOLF6
Are you sure cause the first time I did it with the special tool, and now the back fits in place and I tried to take it off with a screwdriver but I stopped cause I thought I would brake. But if you think that will be the solution I'll try it again.
Old 09-04-2017, 11:53 AM   #19
mikeleemk6
mikeleemk6's Avatar
No need to have a special tool. Those caps just push on.
Old 09-04-2017, 11:54 AM   #20
vwGOLF6
But everybody is doing it with that tool? But actually you don't need it?
Old 09-13-2017, 06:21 AM   #21
vwGOLF6
I tried out what you said about the door handle but it didn't help
I tried to pry it out with a flat screw driver underneath the back cap but it is stuck
Anybody has other ideas?
