Old 07-23-2014, 12:07 AM   #15
As I recall, the plastic drain plug insert is the level to fill. It's easier than you guys make it out to be. Whether you measure or not, it will start to come out and then stabilize at that level. If it's in the ballpark it's probably fine.
Old 07-23-2014, 07:23 AM   #16
DSGVW
DSGVW's Avatar
Drives: 2012 CSG GTI DSG
Originally Posted by FocalPoint View Post
What DIY did you follow, OP? I dig the tips and tricks, but this isn't exactly a DIY.
See tip/trick #7. "lasthumansgarage" youtube video is all you need.
Old 07-28-2014, 02:18 PM   #17
Candymaker
Drives: 2010 Golf TDI DSG
would this apply to the TDI as well?
Candymaker is offline   Reply With Quote
Old 07-28-2014, 02:28 PM   #18
maxtdi
GolfMK6 Elite
maxtdi's Avatar
Yes, same exact procedure.
Old 07-30-2014, 09:46 AM   #19
dishwater63
Drives: MK6 GTI
Ok, first off, thank you so much for this! I've been going round in circles over this DSG service, but I don't think I could sleep at night knowing that I dropped $400+ on a fluid drain that I could do myself in front of my house. Problem is, I have no tools and have very little experience under the hood, haha (hey man, everybody gotta start somewhere).
So, between this DIY and the video posted, do you think I can do this by myself and not blow up my car? The most I've ever done under the hood is an oil filter change and...replace my tires (if that counts). Is the allen wrenches and the funnel all I need (aside from a jack and blocks)?
Originally Posted by Tourenwagen View Post
while youre at it, route your exhaust directly into your turbo for perpetual motion power.
dishwater63 is offline   Reply With Quote
Old 07-30-2014, 10:07 AM   #20
lilfleck
Drives: '11 GTI Autobahn, DSG
torque wrench to make sure everything is torqued properly. Torx (t30) to remove your intake.
Old 07-30-2014, 11:34 AM   #21
DSGVW
DSGVW's Avatar
The allen wrench for the transmission plug is HUGE!! Special order online or autozone has them too.
Old 07-30-2014, 11:50 AM   #22
lilfleck
Good point...
Old 07-30-2014, 01:47 PM   #23
dishwater63
Drives: MK6 GTI
Fantastic! Thanks for the response, I'm gonna try and knock this out in the next week or two. I gotta order the parts and tools, but other than that, I think I got the confidence now to tackle it.
Old 07-30-2014, 01:53 PM   #24
lilfleck
I would add that you should put the car on jack stands (four of them) and measure how much comes out.
Old 07-30-2014, 07:50 PM   #25
Jet08
Drives: Jetta TFSI
I used a 14mm socket mount allen rather than the standard L allen key and I am glad I did as the dealer service department decided that the plug needed to be torqued to over 100 newton metres at the last DSG service.
Jet08 is offline   Reply With Quote
Old 10-04-2014, 12:03 PM   #26
barnes93cb
barnes93cb's Avatar
Drives: '11 BMP 2Dr DSG GTI
Okay I must be a little special. I cannot seem to find where to monitor DSG temps in VCDS. Where do I need to go.
APR Stage 2 / CTS Intake / Twintercooler / Godspeed Downpipe / MagnaFlow Catback / H&R Springs
APR Stage 2/ Lowered Build Thread
Instagram: barnes93_vw
barnes93cb is offline   Reply With Quote
Old 10-04-2014, 12:25 PM   #27
DSGVW
DSGVW's Avatar
With the drain and refill method I saw no need to check temps via vagcom.
Old 11-01-2014, 02:35 PM   #28
ManWellmk6
ManWellmk6's Avatar
Is vagcom really needed? Or can you just drive around the block then drain the excess?
ManWellmk6 is online now   Reply With Quote
