Old 09-16-2015, 02:45 PM   #43
The manual cars are easier, with a dedicated fill plug at the max level.
Old 09-20-2015, 09:09 PM   #44
PeeLo801
PeeLo801's Avatar
Drives: mk6 GLI DSG Black Pearl Metallic
HELP...i just changed the DSG fluid, and upon turning on the car, the check engine light is on. What happened? How can I fix this?
GIAC Stage 2 // Neuspeed p-flo intake // SPM Downpipe // TSW Nurburgring // DG Springs // Unibrace UB // Hotchkis Front and Rear Sway Bars // Michelin Pilot Sport A3
ipb-autosport.com: The official GIAC dealer in the Sacramento area
PeeLo801 is offline   Reply With Quote
Old 09-20-2015, 10:41 PM   #45
PRND[S]
PRND[S]'s Avatar
Do you have a way to see what the CEL is for? Are there any other lights on, such as a steering wheel symbol? It is common to have a steering wheel fault when disconnecting the battery -- that problem will go away after driving at a slow speed and turning the steering wheel lock-to-lock a few times to allow the car to relearn the steering wheel stops.
Old 09-21-2015, 11:50 PM   #46
PeeLo801
PeeLo801's Avatar
thanks. Yes the steering wheel light was on too and it went away.
Used an OBD scanner and found P025c code. But we just cleared it. Crisis averted.
Old 03-06-2016, 10:56 AM   #47
boostedmk6
boostedmk6's Avatar
For those who used the measure-refill method - did you just raise the front of the vehicle with ramps/stands?
The transmission seems to sit fairly level even when on ramps.
GTI DSG | APR K04
GTA Detailing & Paint Correction
boostedmk6 is offline   Reply With Quote
Old 03-06-2016, 02:18 PM   #48
You guys do realize that the plastic insert is for the proper fill level right? You make many assumptions measuring what comes out. Even a small leak will lose quite a bit over time. And you are assuming the last guy didn't under or over fill it as well.
Old 03-06-2016, 03:35 PM   #49
iAhhMaze
iAhhMaze's Avatar
Drives: 2010 Tornado Red GTI
Getting ready to do mine next weekend. Any tips?
2010 Tornado Red Unitronic Downpipe Unitronic Catback H&R Super Sports R8 Ignition Coils Unitronic Intake Unitronic Stage II GFB DV+ NSP Boost Gauge 20% Tint Neuspeed TBP Spulen TOP Shaved Front Bumper GSP Intercooler
iAhhMaze is offline   Reply With Quote
Old 06-18-2016, 09:53 PM   #50
SwanyD
SwanyD's Avatar
Drives: 2012 Gti Black Pearl Metallic
Easy as pie!!!
Did this a few months ago. Its a lot easier than it looks. Between this forum and the video from LastHumansGarage on youtube. I was able to get mine done in about 45 mins.
APR Stage II+ / Eibach Sportline's / VWR Intake / SPM Street Downpipe / LED Interior Lights w Red Footwells / Front Euro Lip http://www.golfmk6.com/forums/images...burnrubber.gif
SwanyD is offline   Reply With Quote
Old 06-18-2016, 10:37 PM   #51
whitewolf33
whitewolf33's Avatar
Drives: 2013 CW Wolfsburg
Im going to be doing mine in the next 2-3 months... How many people use vagcom to check the transmission temp when doing the final drain? It seems like a lot of people are measuring what comes out and refilling...
Old 06-19-2016, 06:59 AM   #52
iAhhMaze
iAhhMaze's Avatar
I used a vagcom to check temp
Sent from my SM-G930P using Tapatalk
Old 06-19-2016, 12:55 PM   #53
CarniifeX
CarniifeX's Avatar
Drives: '14 CW GTI
I'm doing this next weekend. I'm likely going to measure what came out and out that amount back in.
'14 Wolfsburg GTI CW 4-Door | BUILD THREAD
CarniifeX is offline   Reply With Quote
Old 10-03-2016, 04:07 PM   #54
MacRadiators
MacRadiators's Avatar
Drives: Leon FR
The 4.7l in after flush is fail proof.
Works perfect every time.
17$ for oem filter + 60$ for 5 liters of Motul DCTF, my dsg is perfect at 168k
MacRadiators is offline   Reply With Quote
Old 10-03-2016, 07:09 PM   #55
whitewolf33
Good to know, Ill be doing mine in 2 weeks. Im going to measure what came out for my own curiosity but Im going to put 5 litres in using the top fill method and then ill drain a little after getting the car up to temperature
Old 10-04-2016, 02:22 AM   #56
0-60Motorsports
Drives: VW Golf R MK6, 04 M3cs
I do exactly this.
0-60Motorsports is offline   Reply With Quote
