Old 07-24-2014, 09:31 AM   #15
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Start your WOT pull at 2,000 RPM in the highest gear you normally use under full load (3rd or 4th gear). 4th gear is preferred as it's a longer pull and when using TURBO! mode in VagCom, the sampling rate is much better for more overall data to review. 4th gear requires a long stretch to safely run through 6,000rpm.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 07-24-2014, 09:33 AM   #16
Mensurpj
Drives: Golf R
4th gear it is.....route 80 just got a fresh coat of asphault
Stage 2+ Golf R
Mensurpj is offline   Reply With Quote
Old 07-24-2014, 09:35 AM   #17
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Nice, I run mine on 287S and 287N.
YouTube: HYDE16
Old 07-24-2014, 12:16 PM   #18
R0bL0gic
Drives: 2013 VW GLI APR K04
You are welcome but there are many others to thank as well for the information they shared through the years.
How much do you need to fly out to AZ and help me out with my problems..?
APR K04 - CTS Turbo CAI -APR RSC TBE - APR DSG Stage 2 - Snow Performance Stage 2 w/ Aquamist distribution block - Innovative Motorsports AFR gauge - HPA motor mount - H&R RSS Club Sport CoiloverZ - CTS IC - IE Manifold - Mahle 83mm pistons - IE Connecting Rods - Supertech valve springs
R0bL0gic is offline   Reply With Quote
Old 07-24-2014, 12:24 PM   #19
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
cover my flights and food.
YouTube: HYDE16
Old 07-24-2014, 03:22 PM   #20
GlowstickNinja21
GlowstickNinja21's Avatar
Drives: MKVI GTI 2DR SBM Autobahn
Haha but he can sleep on the Lawn hahaha
JK
That guide is awesome though. Looking forward to using it once everything is installed.
Beer is the answer!!!.....now what was the question?
Check my BUILD THREAD
GlowstickNinja21 is offline   Reply With Quote
Old 07-24-2014, 03:50 PM   #21
R0bL0gic
I just logged with this, super easy but hopefully the logs turned out ok. I won't clutter them here but I posted links to them in my thread..
http://golfmk6.com/forums/newreply.p...te=1&p=1867983
Old 07-24-2014, 03:56 PM   #22
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Boost and Misfires look good, what spark plug and what spark plug gap?
Your misfire log is way short, did you monitor 5 min at cold start, 10 minutes of cruising, 5 min at warm idle and then a full throttle (WOT) pull or two?
Your timing log was from 3,200 rpm to 4,300 rpm. What gear were you in? Re-try from 2,000 rpm to 6,500 rpm using the turbo mode on VagCom. In these logs you only show correction factor up to -3.8 degrees from 3,400 rpm to 3,800 rpm.
YouTube: HYDE16
Old 07-24-2014, 03:57 PM   #23
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
What file is this and which gasoline used?
YouTube: HYDE16
Old 07-24-2014, 05:14 PM   #24
R0bL0gic
I tried to log again but had some weird shiz going on, I loaded the misfires file and when it was running it went into and infinite loop of "please wait" messages.
I ran those on the 91 octane on the 91 file with meth, pump was replaced yesterday. The plugs are stock w/ 0.28 gap. I have new BKR8EIX's on the way should have them tomorrow.
I had to return the cable but I will borrow it again tomorrow and run logs on 91 and 93 with the new plugs with a 0.26 gap
Old 07-24-2014, 06:51 PM   #25
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Holy amazing thread Ryan!
I just swapped out my 1000 mile old pfr7b for the bkr8s
Look how hot the 7s got. The ground strap changes color almost at the base ring!
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 07-24-2014, 07:13 PM   #26
Mustache rash
My logs after the bkr8 swap
https://www.dropbox.com/s/s8re99rktu1fyv5/session.7.csv
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 07-24-2014, 11:46 PM   #27
dhockey11
dhockey11's Avatar
Drives: '12 GTI (CSG, DSG)
Did a couple of logs as well. I'm no expert, but everything looks good to me as far as boost goes.
I have no idea what the airflow is supposed to look like with a good after-market intake, but the airflow logs look smooth and consistent with my custom one.
In my timing log, I have a couple of points where timing is pulled, not sure if I should be concerned or not.
Take a look if time allows, I appreciate the input. All logs were done on the same road, 3rd gear, ~2000rpm to redline, 83 F Ambient T. I was struggling with the dsg "helping" me downshift from 2k rpm, so I had to ease onto the throttle from 2k-2.5k rpm to stop it.
https://www.dropbox.com/s/qcfp1iydwz...2024JUL14.xlsx
https://www.dropbox.com/s/ff04slhidm...2024JUL14.xlsx
https://www.dropbox.com/s/ia9aejg3k1...2024JUL14.xlsx
'12 GTI - DSG - Custom Intake - Catted Godspeed DP - Driver Motorsport Stage 2 - NewSouth Redline Boost Gauge & Vent Pod
dhockey11 is offline   Reply With Quote
Old 07-27-2014, 12:30 PM   #28
R0bL0gic
Ok, these should be better.
91 octane on 93 file with Meth
BKR8EIX AT 0.026
85 degrees - if that matters.
One thing I just noticed was I consumed almost 3/4 of a gallon of Meth, my guess the start and stop times might be F'd up right now.
93file-Boost
https://drive.google.com/file/d/0B71...it?usp=sharing
93file-Misfires
93file-Timing 1st pull
93file-Timing 2nd pull
