Old 08-02-2014, 03:39 PM   #29
FastersBetter
FastersBetter's Avatar
Drives: 2009 GTI TSI DSG
I'm trying to change plugs (for the first time myself) and attempted to adjust down from 28 to 26 as per APR. My adjuster didn't seem to have the strength to lower the strap and it also marked up the strap.
How do I close the gap and also, can I still use the plug
APR TBE (Stealth) | K04 | LaBonte Water/Meth | Hotchkis F/R Sway Bars | Eibach ProStreet S Coilovers | Dunlop Direzza | Carbonio Intake | APR K04 Software | Enkei PF01 | Euro Sport X-Brace | H2Sport Sperical Bearings | HPA 85D Lower Engine Mount | TyrolSport Deadset Subframe Bolts
FastersBetter is offline   Reply With Quote
Old 08-02-2014, 03:41 PM   #30
jay745
jay745's Avatar
fantastic thread. Hyde is the man!
Old 08-02-2014, 04:09 PM   #31
Speeddemon69
Drives: 2012 MK6 GTI
Tap it down lightly on a piece of wood or smooth surface. Also you might have been doing it wrong if you messed up your tool. You have to find the right angle and you'll bend it with little effort.
Old 08-02-2014, 04:38 PM   #32
FastersBetter
Hmm... Tapping down works.. Thanks! I re-read Ryan's first page and it seems if the plug is "marred" it's risky to use. So I went out and bought another plug.. Hate wasting money like that!
Old 08-07-2014, 10:20 PM   #33
GlfSprtCT1
GlfSprtCT1's Avatar
Drives: 2011 csg 2dr 6mt
13k since my 3+ install last fall, 2 mths of hunting a boost issue (was tune related, thank you Arin), a cold winter, clogged catchcan and 4 qts of oil later...
2011 GTI / APR Stage 3+ Carbonio stg1 intake-APR catted dp-Magnaflow catback-APR intercooler-Audi S3 shifter-Podi /boost gauge-034 Motorsports engine/trans mounts (street density)-CatchcanDXD stg2 daily-H&R coilovers-APR 27mm rear swaybar/Whiteline adj. end links-vcds coding tweeks-Tinted oem tails-HPA 6 piston bbk/80a subframe mount
Follow on instagram @glfsprtct1 :wave:
GlfSprtCT1 is offline   Reply With Quote
Old 09-07-2014, 02:41 PM   #34
TheCastle
Drives: MK6 GTI rip. BMW 335d
You need new plugs, your cathodes are eroded.
TheCastle is offline   Reply With Quote
Old 10-16-2014, 11:41 PM   #35
mark 8
Drives: MK 6 , White, Stock
Lol vagcom sucks balls I heard
mark 8 is offline   Reply With Quote
Old 10-17-2014, 06:53 AM   #36
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Really? I bust my ass to create this guide and that's your input to make this forum better?
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 10-17-2014, 07:19 AM   #37
Torito77
Torito77's Avatar
Drives: VW Scirocco
This is a fantastic thread with a lot of time put in it. Thank you.
Can't wait to share some logs with my new w/m kit set up.
Scirocco K04 APR 3.1
Torito77 is offline   Reply With Quote
Old 10-17-2014, 08:45 AM   #38
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
I will help you review your logs, let me know when you start running them.
YouTube: HYDE16
Old 10-17-2014, 08:58 AM   #39
Torito77
Torito77's Avatar
Drives: VW Scirocco
Enviado desde mi iPhone utilizando Tapatalk
Old 10-22-2014, 10:57 AM   #40
Torito77
Torito77's Avatar
Drives: VW Scirocco
OK, Hyde. Finish my w/m set up. As I anticipated it consists of a two phase AEM kit with one nozzle installed before the TB and after the MAP. The nozzle is 500 cc/m flow (alternatives in the kit are 250 and 1000).
My goal is to try to get the best of the 98 RON (safety for track days) and 102 RON tunes (some racing here and there) with my current w/m set up.
I bought meth this morning and filled the tank without water. Was too anxious too buy water and make the mix and made a a couple of pulls with 100% on my way home.
Session 15 is 98 RON tune with start psi at 8 and full at 15
Session 16 is 102RON tune with start psi at 6 and full at 15
Note: Iridiums 8 gap 0.24" and 30 degress celsius (86 farenheit) outside
I know I should re test with w/m 60 meth 40 water by volume but I'd like to hear from you after this logs in 4th gear and read your thoughts.
https://www.dropbox.com/s/tjii8jzik3...n.15.xlsx?dl=0
https://www.dropbox.com/s/h7gf9qmo77...n.16.xlsx?dl=0
Old 10-22-2014, 11:02 AM   #41
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
I can't access these can you email them to me at RJacobs1@gmail.com?
YouTube: HYDE16
Old 10-22-2014, 11:02 AM   #42
Torito77
Torito77's Avatar
Drives: VW Scirocco
Certainly !
