Old 07-30-2014, 02:50 PM   #29
aw614
Drives: 2011 CW MKVI GTI
Originally Posted by Merkle View Post
Wow, I have never seen this on a modern vehicle, <10 years old.
Only VW would have this problem and not bother fixing it even though it was known on the mk4 and mk5 cars. Pathetic. For all the vehicle testing VW does in Florida, they sure can't seem to design a car to hold up to this weather...
Originally Posted by mcgti6 View Post
diy took me and a friend who is experienced with re-doin mk4 headliners. but u hafta take off or at least unclip all the plastic trim on sides (order a buncha those airbag tabs that insert into the trim because they will all snap coming out. mk4 b pillar tabs are the exact same if u go to a junkyard instead of ordering em), remove visors, handles, and disconnect all the lighting. pulling the panel from the trunk = no problem. but, putting it back in, u hafta be very careful not to scrape it on all the plastic trim, unless u fully remove it. i jus unclipped it halfway and let it hang, lookin back tho i shouldve jus removed it completely. will take an hour or so to remove the panel.
overall took us like 6 hrs cuz we kept running into lil issues with plastic clips n whatnot. hadda get a new passenger side a pillar cuz the plastic vent was so brittle it broke when removing the pillar. so beware if ur car has been out in the sun for yrs.
did mine with like a sorta alcanterra type material, color black. looks nicer than oem i think but not to extreme to standout if i sell later.
I didn't realize yours started sagging. Almost every mkv owner in the area has had theirs begin to sag. Actually now that I noticed, most have been dark colored cars with the issue, with a TR MK6 in the mix...
Old 07-30-2014, 08:12 PM   #30
FocalPoint
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
So I got a call back from my service adviser today, telling me that they dropped the old headliner and discovered the wiring harnesses for the lights/switches were damaged. Keep in mind that I suspected originally that this was all due to humidity and heat, but it looks more and more like my sunroof has an irrigation problem, causing the issues. That said, they are having to order new wiring harnesses for me as well.
Keep in mind that I've never taken apart any portion of the roof ever, for anything. Not the sunroof, the lighting domes, nothing.
Old 08-02-2014, 11:47 AM   #31
NoPants
NoPants's Avatar
Drives: MK6 2010
Mines a Golf Base model, 2010 and it began to peel of the headliner, it's gotten much worst to the point that it's sagging just as the picture of the threat starter. Of course I'm out of warranty and VWoA wont cover it, called a local headliner place that was well aware of the issue and explained as to the material used and depth. According to him, it's called prizm material, most places just use aftermarket so the problem will be persistent. It's going to cost me $385 installed. Never again VW never again.
srlybro.
NoPants is offline   Reply With Quote
Old 08-03-2014, 01:22 AM   #32
FocalPoint
FocalPoint's Avatar
They should cover it. I spoke to Amber at VWOA. Said she has seen this a lot on cars roughly 3+ years old.
Old 08-03-2014, 03:37 AM   #33
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
This just happened to my 2010 GTI at 62k miles, on the same spot.
I put some cloth like tape around it to hold it up for now.
Will see shops and do an alcantara headliner.
Like this..
SOLD -> MK7 R
Old 08-03-2014, 10:15 AM   #34
Boosted_2.0
Drives: Mkvi GTI
My sunvisor light never worked on my MK6, and I found the wire was CUT in the roof from the factory. I never fixed that before I got rid of it. So it does happen from the factory no doubt.
Boosted_2.0 is offline   Reply With Quote
Old 10-10-2014, 04:25 PM   #35
tavorh
Drives: 2010 Golf GTI
My dad has a 1975 dodge charger sitting in his driveway, under a car cover of course, but has the original interior and headliner still in place. No droops or sags anywhere. He lives a total of 90 miles SOUTH (so hotter and more moist) of me. I made sure I told VW this as a near 40 year old car has held up in the Florida heat better than their 3 year old "superior interior" quality GTI tiers.
No fuq u quid.
I know of a few shops nearby, but I'd just go for the stock material. The entire headliner had to be dropped in my MKV when replaced because the material apparently stretches out. If they can make it look new and just re-glue it, fine, but they might wanna drop and re-glue the entire thing because I'll be back at their door if it happens in a different spot later on.
Hey man I just got this problem too and I am located in Fort Laud too. Did you find any good shops to do this work? How much did they charge? My car is not under warranty so Gunther most likely will charge me a lot. Any suggestions are appreciated.
tavorh is offline   Reply With Quote
Old 10-10-2014, 04:43 PM   #36
FocalPoint
FocalPoint's Avatar
In all honesty, I would send a message to VWOA via their e-mail on their website. Tell them you are aware of several MK6 GTIs that have had sagging headliners replaced inside and outside of the bumper to bumper warranty in your region. You are looking to be treated just as fairly being a Volkswagen customer. You can also disclose a potential mounting class-action in efforts to force a recall or TSB/warranty extension on said item as this is a weak point in their interior design. They should know that by now since it has been problematic since the MKIVs, but they still can't get it right. It's a pretty expensive fix with OEM material, so you really want them to cover it for you unless you go with aftermarket stuff, which isn't my cup of tea.
Old 10-10-2014, 05:07 PM   #37
willnando
willnando's Avatar
Drives: MK6 GTI (Evee) B7 S4 (Sonya)
Damn mine started doing the same around the front dome lights, where the sunlight holder thing is.. If getting it fixed though VW with the OEM stuff is going to be crazy expensive I'm going to duct tape that shit .. Don't got money for that right now honestly.
willnando is offline   Reply With Quote
Old 10-10-2014, 05:46 PM   #38
mattttt
mattttt's Avatar
Drives: 2011 CW GTI
I blame Florida. It's always Florida's fault.
Build Thread
IG: @mk6matt
mattttt is offline   Reply With Quote
Old 10-17-2014, 07:40 PM   #39
bequietanddrive
bequietanddrive's Avatar
I'm here in Tampa guys and had this exact same issue in my 2010 GTI. VW was useless and basically told me that I was on my own, and wouldn't help me at all with the repair (I had 70k miles). I found a local auto upholstery shop with a great reputation here and had them replace the headliner with black suede. It would have been $225 for an aftermarket match to OEM, and only $300 to upgrade to suede. It was a no brainer to me! Here's the results:
It looks slightly grey in this photo but it is indeed black. I would recommend this route to anyone rather than taking it to VW (unless it's on their dime, of course) but to me it was totally worth it.
bequietanddrive is offline   Reply With Quote
Old 07-02-2015, 08:35 PM   #40
stradovinski
Drives: 2010 GTI 4dr DSG
This just happened to me as well. That pic from OP might as well be from my car. Granted my car is almost 6 years old now and I also live in FL, but I've been in plenty of cars in my 20 years since moving here, and I can say I'm the first amongst my friends to have a headliner issue.
Same thing happened in my diesel Rabbit back in the 80's. Sad they haven't made any progress with this in all those years.
Any recommendations where to go in the Fort Myers/Naples area? Thanks
stradovinski is offline   Reply With Quote
Old 04-12-2016, 08:43 AM   #41
Speeddemon69
Drives: 2012 MK6 GTI
Hey focal point same thing just happened to my 2012 Gti with only 32,000 and its parked under a carport during most of the day.
What dealer replaced yours and did they do a good job? They break or scratch anything in the process? How long did it take them to do? Thanks.
Old 11-30-2016, 11:33 PM   #42
Waiting281
Drives: 2010 Golf 2.5 MKVI 2dr Manual
geez, are you me? Golf Base 5mt, black, sagging headliner just like in OP's pictures...
$385??? Oh no, I can't afford that, is there no way to do a temporary spot repair? It doesn't need to look perfect, but I'd like to enjoy FL's winter weather while it lasts with the windows down...
Waiting281 is offline   Reply With Quote
