Old 08-26-2014, 10:53 PM   #15
brinkmen
brinkmen's Avatar
Drives: '15 Golf R DSG, '16 GTI S 6MT PP LP
Originally Posted by brobst View Post
Color matched emblems. After much removal hassle and primer coats.
Pic on car?
Performance: APR Stage 1 | 034 CF intake | 034 RSB | 034 End Links | 034 Dogbone Insert | 034 Rear Subframe Inserts | Neuspeed RSe12s w/A/S3+
Looks: Euro R Brushed Side Mirror Caps | Euro Blind Spot Side Mirrors | Blue Footwells | Reverse LEDS | 3M Tint
Misc: Numerous VAG-COM tweaks | Valentine 1 | A118 Stealth Dash Cam
brinkmen is offline   Reply With Quote
Old 08-26-2014, 11:04 PM   #16
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Originally Posted by brinkmen View Post
Pic on car?
Car dirty, just got back from road trip. Doesn't do it justice yet to take dirty pic.
Should be cleaned this weekend.
Old 08-27-2014, 01:26 PM   #17
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Pardon my dust. Color may be just a hair darker. That's either me spraying too close or car just has more sun days than the emblem.
Old 09-17-2014, 09:48 PM   #18
brobst
brobst's Avatar
Drives: CSG mk6 6MT
New Ramzz
Enkei Fujin 18x8 19lbs each
Old 09-17-2014, 09:56 PM   #19
jay745
jay745's Avatar
dig the car and ramz.
Did you ever get your HPA dogbone mount in? It's one of the best things I've done to my car.
Old 09-17-2014, 09:59 PM   #20
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Thanks.
Not yet on the dogbone. been kinda busy. Excited about it though.
Old 09-28-2014, 10:20 PM   #21
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Moar low, but dirty
Old 10-05-2014, 11:15 PM   #22
brobst
brobst's Avatar
Drives: CSG mk6 6MT
HPA 75a red dogbone mount installed.
First impressions- Vibrations on engagement from stop. Vibrations on reverse. I could see this being annoying in stop and go traffic. But the thing about the vibrations, they are not bad. Rather it is vibrations connecting you to the car if that makes sense. I get a better sense of the engine and what it is doing.
For shifting, it has shown immediate effects by removing that jerky feeling from 1st to 2nd. I think it is worth it just for that reason. Shifts feel smoother. I would also say I can feel clutch engagement more due to the connected feeling.
Overall- if those major vibrations go away after the 500 miles break in period, then I will be very satisfied with this mod.
It has not gone through the wife test yet though, so we will see if she notices or not the vibrations.
Old 10-10-2014, 10:25 PM   #23
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Re-torqued to 50nm and a 1/4 and the vibrations are easily half as much. Mod feels much better to me now and I am more confident the roughness will go away more over time.
Old 10-10-2014, 10:55 PM   #24
Squashdaddy
Squashdaddy's Avatar
Drives: 6MT 2011 GTI
I used a torque wrench when installing mine and followed instructions exactly. Mount has definitely loosened up but there is still some vibe at idle and when talking off in first gear. Not bad , but noticeable. Shifts are incredibly smooth now.
Old 11-05-2014, 03:55 PM   #25
brobst
brobst's Avatar
Drives: CSG mk6 6MT
It has been about 500miles since I had it re torqued to the proper setting. I would say that vibrations are very settled down. Nothing that upsets the gf. Basically only notice it in reverse. I wonder if 500 miles of reverse will fix that .
The shifts are smoother and I do not experience the first to second lock out anymore that would happen under hard acceleration.
Old 12-19-2014, 12:54 PM   #26
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Washed.
Sent from my SM-G900V
Old 04-29-2015, 02:38 AM   #27
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Finally got the solid shifter bracket bushings, 42dd shifter bushings, and the VF engineering Short shifter installed on 20%. Shifter feels more connected. Definitely like the improvement. Total mod cost under $200, it is worth it.
Was not looking for side to side reduction, or something too beyond OEM. So this was a good fit for me.
Old 07-10-2015, 03:03 PM   #28
brobst
brobst's Avatar
Drives: CSG mk6 6MT
We are LED now. OEM to the rescue.
