Old 07-10-2015, 08:45 PM   #29
Squashdaddy
Squashdaddy's Avatar
Drives: 6MT 2011 GTI
Nice!
Old 12-13-2015, 07:52 PM   #30
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Euro switch installed
Alignment and Oil change done at 26k miles.
brobst is online now   Reply With Quote
Old 01-05-2016, 07:17 PM   #31
brobst
brobst's Avatar
Drives: CSG mk6 6MT
LED reverse lights installed. They are pretty bright. Pictures to come later.
Old 01-05-2016, 09:56 PM   #32
Squashdaddy
I have them as well. Very nice.
Old 03-02-2016, 09:45 PM   #33
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Just went stage 2 Eurodyne tonight. All I can say is holy crap. I thought my boost gauge was broken the way the needle swung. Needless to say, I am happy with my purchase.
I need some new tires.
Tune done at 28700 miles
Red tops and NGK IX spark plugs installed at 28750 miles for preventive maintenance.
Neuspeed filter cleaned and oiled at 28780 miles march 1st approximately.
Wipers done all around at 29k around 3/15/2016.
Old 03-09-2016, 10:13 PM   #34
brobst
brobst's Avatar
Drives: CSG mk6 6MT
LED turn signals installed.
Color changing footlights installed.
Driver:
Passenger:
Old 04-19-2016, 09:05 PM   #35
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Neuspeed 25mm fsb installed at 29k miles
TyrolSport deadset installed at 29k miles.
Post Tyrolsport install alignment within 75 miles.
Old 05-02-2016, 05:46 PM   #36
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Did my first log set in April. Seems reasonable for stage 2. I will probably redo this sometime so I can see the boost in psi for easier reading.
Old 05-05-2016, 09:59 PM   #37
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Installed Stage 2 pipe and trigger wire for city lights today (31k miles).
Had to trim the pipe a little to get it to mate up properly. But it ain't going no where so that's good.
I know my bay dirty doe. Weather sucks for cars.
Old 05-11-2016, 10:07 PM   #38
brobst
brobst's Avatar
Drives: CSG mk6 6MT
These guys came in today.
Old 05-25-2016, 12:04 AM   #39
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Install soon...
Super pro Alk kit
034 engine and trans mounts
034 pendulum mount
Old 05-25-2016, 10:05 PM   #40
brobst
brobst's Avatar
Drives: CSG mk6 6MT
We did it boyz. All mounts installed. Walk kit as well. 31.6k miles. Feels so good. Yeah there are more vibrations at idle.
A/c at idle sucks too. But it should go down over time. The first 30 miles have been a blast.
Update Edit: 100 miles down on these mounts.
Take off vibrations are pretty strong. To explain the intensity, you can watch the turn signal stalk shake as you are engaging the clutch. However, the vibration seems pretty exclusive to like 900-1200 rpm. Outside of that range, you would not know I have uprated mounts.
Now outside of vibrations, the engine idle noises are amplified. You can hear the ticking and chugga chugga noises, especially if your windows are up.
A/c amplifies vibes and due to added engine load, also amplifies engine sounds.
Basically you will only notice this combo at 900-1200 rpm and sitting at a red light. Shifts are butter smooth for me now.
Old 05-26-2016, 12:03 AM   #41
Drives: 10 GTI CSG DSG K04 4DR 130k+
Congrats! I'll be right behind you in a few weeks. Did you get an alignment at the dealer?
Old 05-26-2016, 01:03 AM   #42
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Idk why all my pics post sideways.
I need to do that now. The miles were just from driving back home after install
Edit: alignment and tire rotation / balance done at 31.7k miles.
Closest my camber has been in a while lol
Loving these mounts. Went with a/c on today to test vibes. Take off vibes amplified, idle vibes as well.
You can really hear the engine ticking along with the windows up.
Due for oil change next.
