Old 10-05-2016, 04:58 PM   #57
jay745
jay745's Avatar
What prompted you to remove the clutch delay valve from the master cylinder? I don't see many doing that. Do you have any more info on it? Also how difficult was it to do so?
Old 10-05-2016, 06:04 PM   #58
brobst
brobst's Avatar
Drives: CSG mk6 6MT
It wasn't the original intention. We were trying to just remove the bleeder block restrictor.
My thought process was if there is a delay at the beginning of the line, simply widening the line at the end can only have so much effect.
So I took it out as an experiment. It is very easy to remove. Has the same nipple end like the clutch line. Just something extra to plug into.
No real info in it and what it looks like on its interior.
This is just my thought process: removing the restrictor allows more fluid flow, removing the delay valve allows fluid response to be faster. So then both methods achieve the same end result: slowing the clutch pedal.
Not sure if related, but my clutch pedal started squeaking lately on engagement. I have a new clutch coming in next week, so I will see if the squeak is fixed.
Sent from phone Tapa
Old 10-06-2016, 03:28 PM   #59
Paytrose
Paytrose's Avatar
Drives: 2014 GTI Drivers Edition
2014 Black Pearl Metallic GTI Driver's Edition | Serron Wheels | HS Tuning RSR Clutch | 42DD TBE | APR Stage 2 (93 Oct V2.4) | Conti DWS06 | DEPO LED Tail Lights (Dark Cherry) w/ DeAutoKey Reverse LEDs | Neuspeed P-Flo CAI w/ AEM Filter | R8 Coils | Raceseng Ashiko Shift Knob | 25% Tint | RokBlokz Mud Flaps | S3 Short Shifter | I Need More...
Paytrose is offline   Reply With Quote
Old 10-14-2016, 10:00 AM   #60
brobst
brobst's Avatar
Drives: CSG mk6 6MT
I'm just going to dump photos here from hs tuning while they do the clutch job.
Nice waiting area for me to sleep.
Trans is off, nice view of the clutch on the car.
Clutch oem
Transmission case opened for the differential install.
Trans all apart
Measuring the preload for the proper shim. About 0.9
Shift forks just chillin
Extra clearance needed for this mfactory brand diff
Pictures of the old clutch. Meh, I guess it was bad.
Close ups
Other part
Old 10-14-2016, 11:57 AM   #61
ncsugray90
ncsugray90's Avatar
Drives: 2011 GTI 2 door 6MT
If you havent picked up a K04 yet, I have one for sale
http://www.golfmk6.com/forums/showth...46#post2477246
UNI Stage 1+ | H&R SS Springs | 35% Tint | GFB DV+ | Ground Control Adjustable Camber Plates
ncsugray90 is offline   Reply With Quote
Old 10-14-2016, 02:46 PM   #62
brobst
brobst's Avatar
Drives: CSG mk6 6MT
It looks really good. But its not in the budget until next year unfortunately.
Old 10-14-2016, 03:12 PM   #63
ncsugray90
ncsugray90's Avatar
I inderstand, hopefully I won't still have it then, haha
Sent from my SAMSUNG-SM-G900A using Tapatalk
Old 11-05-2016, 09:35 PM   #64
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Just got some Continental Extreme Contact DWS 06 225/40/18 installed 37.1k miles. These tires feel good. Got into a little second gear boost and no problem with traction at all. Looking forward to these tires.
Now I am due for an oil change.
Alignment Spec Sheet courtesy of Belle Tire.
Old 11-12-2016, 10:43 PM   #65
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Apr intercooler installed today and oil change done with liquid moly at 37.4k miles.
Thanks for the help install team. We even had one less screw left over so something is extra secure lol.
Pictures of what I remembered to snap.
Also need to look into a catch can. Oil all the way on the other side of my intercooler. Yikes
Oem
Oil in the pipes
New one.
Actually, this is taking it apart.
Old 11-21-2016, 08:25 PM   #66
DASVDUB
DASVDUB's Avatar
Nice build! Sub'd.
Old 11-22-2016, 03:16 PM   #67
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Nice build! Sub'd.
Thanks man. It's been a fun journey. I think I am done modding for 2016. Next year has the turbo swap on the list.
12/29/16
Narrowing it down to an ATP kit or a port and polished K04. Last month or so has just been adjusting to the new clutch. After break in period, the clutch engagement from stop became much more abrupt. I am getting better though.
Car is running well though. Tires balanced and pulling nicely.
Old 01-14-2017, 06:43 PM   #68
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Wheels re balanced to get rid of some highway speed vibration.
Random VCDS tweaks done today.
ESC defeat, teardrop wipers front and rear, coming home and leaving home lights, drl off when turn signal. Just little fun stuff.
Note: doing esc defeat causes some fault code on abs module.
Also got my dv+ code popping up.
Lastly, decided on the port and polished k04. The extra hp from the gtx was not worth almost 3x the price.
Old 01-17-2017, 02:51 AM   #69
brobst
brobst's Avatar
Drives: CSG mk6 6MT
https://r.tapatalk.com/shareLink?url...3&share_type=t
Brobst DIY & review- Raceseng Contour shift knob
Shiftknob installed. Mote details to come.
Teaser pic.
Old 02-25-2017, 02:49 AM   #70
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Replaced a bent fuijin. Was pretty mad about it because I'm not sure when it happened.
Just taking away from the mod fund lol.
In other news, awe top came in the week.
Also just hit 40k miles recently, so going to do fuel filter soon. Rotated the tires, 40,300 miles. Maybe a fluidampr in march. So far on track this year for ko4.
