Old 08-26-2014, 12:01 PM   #15
Utah Beast Mode
Utah Beast Mode's Avatar
Drives: 2014 CW MK6 GTI - DSG WOLF
Just stick it back in and put some silicone around it to hold it there. There'e enough room, you just have to space to radiator back with some washers. You can even keep it tight by using less washers and use the intercooler to kind of hold it in place. I found a PN# for the sensor itself, but nobody sells it anymore. It's supposed to be a one use thing as a set with the radiator. I've read about them being brazed into the radiator, but our's has clips and seems to be easily removable so I doubt ours is brazed/soldered in.
Well I tell you that this is creating a headache! Lol. Just talked to VW and they said the Sensor comes on the Radiator which cost like $400-$500. Helll NO! Lol. I broke the plastic clips off my sensor, but what you're saying is that it will still work if I attached it back on with some high temp adhesive?
Also, just called SPM to figure this all out. As the intercooler is NOT a direct fit with the CBFA engine. So this is a whole other issue I'm trying to deal with.
2014 CW DSG GTI
Traded in 2012 Civic Si..Traded in 2005 BMW 3 Series..Traded in 2002 Subaru WRX..Traded in 1996 Acura GSR
Utah Beast Mode is offline   Reply With Quote
Old 08-26-2014, 12:16 PM   #16
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
correct..
The temperature sensor is made of cast polyurethane
resin and is non-removable once attached. If, however, an
attempt is made to remove the temperature sensor, the
sensor spigot will break away from the housing causing
it to become irreparably damaged, both electrically and
mechanically.
2015 Subaru Forester XT
LastHumansGarage
Old 08-26-2014, 12:25 PM   #17
vwgti2.0t
Drives: 2011 CW GTI
Originally Posted by 2013R View Post
correct..
mechanically.
As much as I've read this, the guy on the other thread just re-installed his and the light hasn't come back on. And that thread is a few months old.
Old 08-26-2014, 12:58 PM   #18
Utah Beast Mode
I'll keep you guys posted on how I resolve this Ozone Sensor CEL issue. SPM is being cool and we are working on how to solve this. There has to be a workaround for that freaking sensor.
2014 CW DSG GTI
Old 09-11-2014, 10:31 PM   #19
ka_killuh
Drives: 2013 CSG GTI Autobahn
Anyone with this sensor running a Neuspeed throttle body pipe? I installed an APR intercooler tonight and spaced the radiator back to fit. When I installed the bigger pipe, it was rubbing on the radiator fan just a little. I figure when the engine rocks under acceleration it will probably hit pretty hard though. I put the stock pipe back in to get the car home and it fits fine, plenty of room.
ka_killuh is offline   Reply With Quote
Old 09-12-2014, 09:47 AM   #20
Bcon
Bcon's Avatar
Drives: 2012 GTI 4dr CW DSG CBFA
I'm that guy. I took it out and zip tied it aside - CEL thrown, I cleared it, CEL thrown again.
So, I put it back, spaced the IC back a bit for clearance - no CEL, ever (and it's been quite a while).
Yes, the plastic clips break when you remove it. But, it fit in snugly when I put it back. I didn't use adhesive, and it hasn't moved.
My thought is (and I can't confirm this at all), it's a temperature sensor. I have no idea if it works by resistance or some other method. I think it senses the radiator temperature and references something else, like the coolant temp. If they don't jive, it assumes it's been tampered with and throws a code.
As for a simple fix (like a resistor) - that depends on how "smart" the coding is. It could easily be coded to not be "fooled" by a constant hot signal, and therefore not fooled by a resistor. However, that's pure speculation on my part........
In the end, putting it back worked, so I'm not messing with it any further.
APR K04, APR v3.1 Tune, APR DSG Tune, APR Downpipe, APR Intercooler, BSH Intake, R8 Coilpacks, Koni Coilovers, Neuspeed RSe12 Wheels, Stoptech Street Performance Brake Pads
Bcon is offline   Reply With Quote
Old 09-12-2014, 09:57 AM   #21
vwgti2.0t
Drives: 2011 CW GTI
Nice! Pretty sure mine is beat. It's been in for a while, aka since 2011, being smashed by the intercooler. Just spaced it back a few weeks ago when I started getting the codes. It did stay off for a while but now it came back again. I'm going to dig more into it at some point, but since it usually stays away in the winter I'm just leaving it along for now.
Old 12-15-2014, 02:03 PM   #22
rossman869
Drives: 2011 GTI MkVI Black 6 spd snrf/nav
Same issue here. Dealer has now replaced radiator 4 times under warranty because of this sensor. They have involved regional tech support and I called VWoA the last time. After 6 months, light came on again last week and has now shut off 5 days later. When I checked the reason, it was the sensor again! So frustrated. The dealer's mechanic who has worked for VW for 16 years and is a GTI enthusiast himself is at a loss. He suggests asking them to buy back my baby! Anyone gone down that path before??
rossman869 is offline   Reply With Quote
Old 12-15-2014, 02:24 PM   #23
vwgti2.0t
Drives: 2011 CW GTI
I haven't had mine come on in a while. After clearing the codes every time I got a CEL, I got pissed and just left it on. A few days later the CEL shut itself off (code still stored in vag-com, but no CEL) and it hasen't came back yet. I'm totally fine with this and am just rolling with it. As long as the car runs fine and I have no CEl I'm happy.
Old 12-15-2014, 02:59 PM   #24
XGC75
XGC75's Avatar
Drives: into shit
I have a '12 CBFA manufactured 11/2011. I don't have this sensor. Whatever it is, there MUST be a way to code it in or out.
Old 12-15-2014, 03:41 PM   #25
vwgti2.0t
Drives: 2011 CW GTI
I'm sure there is. I talked to a friend that works for one of the tuning companies and he said they won't do it because it's an emissions device. Which doesn't make sense since it's the same place that gets rid of the light for the cat, but who knows.
Either way, it seems like if you leave the light on it turns itself off after a few days and stays off. That's good enough for me.
Old 01-08-2015, 12:37 AM   #26
Stinger
Stinger's Avatar
Drives: stick 4d CSG '11 Mk6
This fkg sensor is getting on my nerves... Just had a cel, took it to VW and learned the sensor is fried and it, as well as the radiator, need to be replaced.
It's all under warranty still, so not too much of an issue. But this is the 3rd sensor/radiator being replaced, the last one was only 3 months ago! WTF?!?
Can anyone enlighten me as to what causes repeated sensor failures? I'm getting a little paranoid that my stage 1 or other mod is an active contributor... btw, my water pump was also replaced twice... and my manifold once, and my fuel pump...
Old 01-08-2015, 08:32 AM   #27
vwgti2.0t
Drives: 2011 CW GTI
Stock intercooler? I would get it fixed again if it's under warranty. If not, leave the light on and it will go out itself and not come back.
Old 01-08-2015, 04:51 PM   #28
Stinger
Stinger's Avatar
Sounds like a good solution. I suppose I will see the temp rise if the issue was not just the sensor...
