Old 11-01-2015, 11:45 PM   #43
victor247
Drives: 2011 GTI 2004 BMW 545i
Is there a fix for this other than getting a new radiator? A resistor fix?
victor247 is offline   Reply With Quote
Old 12-13-2015, 10:26 PM   #44
Aphix
Aphix's Avatar
Drives: 2011 2dr 6MT GTI
sub'd for this. I have this issue too, same conditions as everyone else describes. The code comes and goes on it's own. I have to pass CA emissions this year so having this replaced under parts warranty. Otherwise I'd be tempted to leave it since I cringe bringing my car into the dealership.
APR Stage II v2.0 | RSR clutch | Sigma Six SS | TWM Big Type-R | Unitronic CAI | GFB DV+ | Golf R IC | Unitronic TBE | Neuspeed Pulley / TOP / TBP | Soundaktor Delete | HPA (75A) | SuperPro ALK / LCA / RCA | BILSTEIN PSS10 | 034 Strut / Trans / Motor Mounts | H&R 26mm (S) / 24mm (S) | Tyrolsport Subframe Collar / Brake Stiffening Kit / Stage II Aluminum Hatch Brace | R8 coil packs | NGK PFR7B | Modshack trim | OZ Alleggerita | Hawks HPS 5.0 | Michelin PSS
Aphix is offline   Reply With Quote
Old 12-13-2015, 10:51 PM   #45
wndwsdwngti860
Drives: gti
Direct Ozone Reduction Catalyst Temperature Sensor///// Radiator Identificati...
isnt there some way we can have this replaced regardless of warranty? they cant possibly have a monopoly over having to replace a part due to emissions! yes, now you will all say we replace our o2 sensors. BUT we can get aftermarket sensors. NO ONE sells the radiator WITH the sensor EXCEPT VW. annnddd we cant replace JUST the sensor.
wndwsdwngti860 is offline   Reply With Quote
Old 12-14-2015, 09:58 AM   #46
vwgti2.0t
Drives: 2011 CW GTI
I have Eurodyne now. Deleted the code with Maestro and still pass all readiness!
Old 12-14-2015, 01:02 PM   #47
Aphix
Aphix's Avatar
glad to hear it worked out for you and awesome to hear you can delete the code (is it permanent?) and pass emissions.
Radiator #2 and #3 (current) seem to enjoy throwing the P2568 code, not convinced getting a new one under warranty will fix the issue.
I'll write APR as they may have a solution too.
Old 12-14-2015, 01:21 PM   #48
vwgti2.0t
Drives: 2011 CW GTI
I just turned the code off so it doesn't throw a CEL (same thing tuners do for non cat files so you don't get the CEL). Usually that would mean that you don't pass emissions do to not setting readiness, but thats not the case. I have no cat, and the cat and radiator sensor CEL's turned off and still set all readiness. I don't get it, but I'm not complaining. LOL.
FYI, APR won't do anything for you to get rid of the code. Which I find stupid since less than half of MK6's have that sensor.
Old 12-14-2015, 01:56 PM   #49
v.b
Drives: K04 rocketship
I forgot to mention I started getting this code only after my last waterpump replacement last summer. Anyone else notice a similar correlation? Is there a temp sensor in the waterpump housing that may be causing this issue?
v.b is offline   Reply With Quote
Old 12-14-2015, 07:25 PM   #50
Aphix
Aphix's Avatar
that is awesome, glad it worked for you. CA emissions may be stricter than in PA, so I think Im at the mercy of VW to replace this with a radiator that works. Radiator #1 failed due to leaks, #2 failed because of the p2568 code, and #3 is getting the code too. If radiator #4 fails, I may have to get a lawyer and make VW buy this back as it won't pass emissions.
Old 12-15-2015, 10:37 AM   #51
Zonaglxy
Drives: 2011 MKVI GTI
I just took my car to VW for a new intake manifold. It had both the p2015 and p2568 fault codes. I was getting the p2568 intermittently over the past couple months. They also swapped out my water pump for the revised version due to the recall. The tech related the p2568 fault code to "small coolant leak which could have created air pocket in cooling system."
I've had 4 water pumps now and each time the p2568 code appeared a couple months beforehand... Definitely a correlation between the two.
2011 GTI 6MT / APR K04 #66 / Neuspeed FMIC / BB Stealth TBE / Carbonio Intake / Smoked OEM R Tail lights / Neuspeed Sofsport Springs
Zonaglxy is offline   Reply With Quote
Old 12-15-2015, 10:47 AM   #52
Aphix
Aphix's Avatar
Im not saying you are wrong, but I find it hard to believe there is something wrong with my waterpump #4. after all, VW replaced it with a new one that works.
Old 01-01-2016, 04:14 PM   #53
50cool50
Drives: audi a3
Thumbs up
I just got a brilliant fucking idea. Since in theory this sensor references the actual coolant temp sensor, I wonder if I just tap into the coolant temp sensor wiring and attach the Direct Ozone Temp sensor wiring into that if it would solve the issue...
Probably not, but I'm going to do some investigating tonight.
I also got this stupid sensor in my 8p.
I replaced the rad with an aftermarket (no sensor model), but then as I was taking the old rad out, that stupid sensor broke off. So I been playing around with it for days now. Its has a little copper wire coming out of the black box which then connects into a resin nipple, and all that nipple does it slot inside an alloy tab in the rad. The copper wire and nipple can't be sending much information to the computer? Just temp readings?
I cut the alloy tab out of the old radiator with a grinder, soldered the wire back from the box to the tab, then strapped the whole thing to the top of my new rad, but its still throwing the code.
Does anyone have any ideas how to do a fix for this yet? Anyone?
Is there any software/reader to delete the code.?
I got arizona emissions coming up in a couple of weeks. (its originally a California car) Would be cool to get past emissions without shelling out mega $$$ to VW
thanks everyone
50cool50 is offline   Reply With Quote
Old 01-11-2016, 12:49 PM   #54
50cool50
Drives: audi a3
anyone?
Old 01-11-2016, 05:48 PM   #55
v.b
Originally Posted by 50cool50 View Post
anyone?
Clear the codes the day before you go to get inspected, drive long enough to set readiness, then go get your inspection.
The MIL will only turn on after the code is detected twice.
Old 01-11-2016, 06:26 PM   #56
Aphix
Aphix's Avatar
also, I would think this would be covered under emissions warranty. I'll call a mod friendly VW dealer to confirm.
