Old 02-23-2017, 09:01 AM   #743
kern417
Drives: '09 Jetta
that is way cleaner than mine. i literally just removed the baffle and ran all my wiring through the big open hole. i may try something similar next winter just to clean it all up.
do a burnout.
Old 05-09-2017, 08:02 AM   #744
U-20T
Drives: BT GTI4Motion
Updates since I have been really terrible at this -
Installed -
1. I'Abed oil cooler plate and using a tstat for a true divorced oil cooler
2. FFE Racing vacuum pump delete installed
3. I'Abed coolant flange modified to fit cbfa
4. Converting to AN for heater core, oem fittings melted
5. Rubber driveshaft joint replaced
6. Progress on wiring harness, firewall bulkhead is complete and body harness is done next ecu to body and the ecu to engine harnesses
Old 05-09-2017, 07:35 PM   #745
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Love the wiring work.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 05-11-2017, 08:59 AM   #746
U-20T
Engine is in!!!!
And very beginning of the ecu harness 61 wires for now, then the engine will get another 61 and a 21 and set of connectors -
Old 06-14-2017, 07:46 PM   #747
cosmo10292
cosmo10292's Avatar
Drives: 2013 vw mk6 gti Wolfsburg edition
So what can you do to beef up the DSG? Or will you do something different like a 7speed dsg from a rs3? Thats one of the reasons why HPA's 700hp R's use em is because of the power they can handle. Very interested because im also on the fence about awd swapping and wondering how much the dsg, haldex, etc can handle
Too many mods to list. Check out my build
http://www.golfmk6.com/forums/showthread.php?t=77578
cosmo10292 is offline   Reply With Quote
Old 06-14-2017, 07:50 PM   #748
U-20T
Dsg will do 600 no issue on a 4cyl all day long
Old 06-14-2017, 08:30 PM   #749
cosmo10292
cosmo10292's Avatar
Good to know! Debating on building the tsi or building a 2.5. I know it won't make as much as the 2.0 can but the noises it makes... 💦
Sent from my LG-H910 using Tapatalk
Old 02-09-2018, 09:12 AM   #750
U-20T
All good projects come to a head at some point, would be willing to part my full car. There are a few items I may hold onto for a few but just about everything is up for grabs. Including fueling parts also have a set of cams currently in for a regrind so if someone wants lets talk and we can work out a change of hands on that.
I will need to have committed buyers for a certain dollar mount with deposits before I go into a full part. but basically if engine, trans and turbo kit go (or any combo of the 2 it will happen).
Or just buy the whole car done and working and cheaper than you can do it lol.
PM me for details please, more you buy we can work out packages
Engine - Proven to over 550tq and over 600hp, 50k on it, 180 compression all across (1-2 psi deviation that's it!), Iabed rear main seal, IE Rods, Farrea +1mm valves, Farrea TI springs and retainers, Vacuum pump delete. Complete long block would come with a brand new timing refresh kit all guides and chains and tensioners and tool kit to install, no oil cooler, no oil pan, no pcv, no fueling all will be separate.
Turbo kit - Complete 6062 gen2 twin scroll kit, all piping, IC and intake, Synapse DV valve w/ boost tap and AN lines to fit, down pipe, Twin MVS Tial gates and Swain Tech coated. Clears all awd and fwd setups. Turbo is new less that 4k on it and maybe 15 passes on the track. Oil lines includes and steel oil pan. Includes AN boost controller lines also.
Trans - Full DQ500 AWD swap with external cooling, Trans, axles, engine bracket, starter, flywheel for 8 bolt (if you have 6 bolt I can get you a flywheel that will work) Mocal external pump with AN lines and temp controlled relay for turn on and off, and shifter. This is the shorter gearing, TTRS is longer this trans is faster. We still hit over 200mph on the dyno in 6th. DQ500 also has real LC. Tune will be OEM, we can talk upon purchase and setup with a UNI tune if desired.
Fuel - Uni injectors with Uni beta HPFP and line and modified fuel rail, hard line across engine included
Catch can with pcv
Divorced oil cooler kit
Fluidamper
Billet machined oil pan
Vacuum pump
Harness you would need to work it out but ill provide what I have for diagram/list.
Water meth kit aquamist HFS-4 with DPI and intake manifold
Bigger TB - $100 buy that right away
AWD swap interior and more
Old 02-09-2018, 10:54 AM   #751
ZiggyMKVI
ZiggyMKVI's Avatar
Drives: 2010 Black GTI
Say it isn't so... On to something big and better I hope
2010 GTI _ mods: Magnaflow-Catback, DG short shifter, BSH catch can, Neuspeed Throttle body and Discharge Pipe, ESC intake, R8 Coilpacks, Forge Motosports coilovers, Rotiform TMB 18 x 8.5, SPM Catless DP, Stage 2 Unitronic, ARM front mount
IG: Scottziggs
ZiggyMKVI is offline   Reply With Quote
Old 02-09-2018, 12:56 PM   #752
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
In for TB
YouTube: HYDE16
awd swap, big money, big turbo, mk6 gti, u-20t, unitronic
