Old 09-11-2014, 10:05 PM   #1
07STitoR
Drives: 07 STi, 13 R
Clicking when turning steering wheel
So I've been getting a click on the steering wheel when turning lock to lock. It used to have a thump in it that you can hear and feel in the cabin coming from the center console in the transmission tunnel. Anyone know what this is? I don't want to bring it back to the dealer again since they already replaced my whole power steering rack, They said it would've cost 4 grand if I wasn't under warranty. You can hear the click at 14 and 27 seconds and turn your volume up to hear. I guess the sound is similar to the sound of the AC clutch turning on.
http://youtu.be/RSvUv2-KskY
07STitoR is offline   Reply With Quote
Old 09-11-2014, 10:16 PM   #2
wbean
wbean's Avatar
Drives: DSG Golf R
1) axle
2) heatshield from bad downpipe
3) endlinks.
'11 Golf R. Shadow Blue. |Unitronic S2hpfp| Unitronic S2* DSG | Brembo 6p BBK | SPM dp | Scorpion SS Catback | BSH PR1 Intake | H&R Sport Springs | Superpro aluminum control arm set | H&R Fr&rr sway bar |HPA Comp Haldex | BC Forged RS43 Forged Brushed black | Dunlop Z2 | OEM Recaro | SRS-tec fenders | P3car display | 0 - 60 in 4.02 seconds |
wbean is offline   Reply With Quote
Old 09-11-2014, 11:08 PM   #3
07STitoR
1) Can axles make clicking sounds when I'm not in motion?
2) Does not sound like heat shields
3) Dealer tightened endlinks but maybe they're over tightened? They tightened a couple of other things too.
Old 09-17-2014, 07:53 PM   #4
JT64
Drives: Everything
I used to get it But not since I installed the Dead Set Kit from Tyrol Sport http://www.tyrolsport.com/volkswagen...r%20bolt%20kit
sounds like what I used to have. The dealer may not have replaced the subframe bolts when they replaced the R&P.
JT64 is offline   Reply With Quote
Old 09-18-2014, 07:55 AM   #5
07STitoR
Holy hell $210 for some bolts!? What the rape. Can it be subframe bolts? I only have 17k miles and it only clicks once when I turn it to lock turning left.
Old 09-18-2014, 07:59 AM   #6
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
clearly subframe shifting. especially since you just had a rack installed and they were messing with everything.
2015 Subaru Forester XT
LastHumansGarage
Old 09-18-2014, 08:52 AM   #7
JT64
Drives: Everything
There's a saying "You Get What You Pay For" If you look at it you'll see that it's more than just some bolts, The ARP Bolts along with those "Specially Machined Retainers" are what holds the subframe securely in place. If you search you'll realize how good of a product it is & Also that the Subframe bolts should be replaced each time you drop the subframe.
Look at this and you'll see exactly what it does http://www.golfmk6.com/forums/showth...ht=Tyrol+Sport
Old 09-18-2014, 03:23 PM   #8
bebersol
bebersol's Avatar
So the click I hear when stepping on the brakes in reverse, is this also the sub-frame shifting? I though I had a loose caliper bolt
Bunch O'Stuff :-)
Old 09-19-2014, 03:38 AM   #9
07STitoR
Thats just the pads reseating.
For the sub frame would it be bad if I leave it? How do I go about telling the dealer to change my sub frame bolts? Say to look up a TSB for sub frame bolts or something? Did you guys notice anything with the Tyrol bolts? Besides from no more clunking.
Old 09-19-2014, 07:38 AM   #10
dopoz
Drives: Golf R
The Tyrolsport kit locks the subframe in place, which prevents it being shifted to the sides to adjust cross-camber in the front -- this is the only front camber adjustment available in our cars. This only matters if your suspension is a little bent and imperfect, since minor corrections aren't possible any more.
dopoz is offline   Reply With Quote
Old 09-25-2014, 06:01 AM   #11
07STitoR
I guess I'll give tyrol a call to get these installed I mean it can't hurt right? Hopefully its my subframe clicking and I can get this resolved as my dealer has no idea. Can it be anything else clicking under there?
Old 09-26-2014, 04:35 PM   #12
JT64
Drives: Everything
There's no guarantee this will do it, But it most likely will & also you'll want to replace all of the subframe stretch bolts as well (always do this each time you remove the subframe)
http://www.ecstuning.com/Volkswagen-...ont/ES2594692/
Old 10-10-2014, 04:16 PM   #13
07STitoR
Thank the car gods! It's fixed! Also that ecs kit doesn't have all the bolts and some you don't need.
Old 10-10-2014, 04:18 PM   #14
2013R
2013R's Avatar
it'll come back over time.. those bolts have no centering ability. only way to solve that is the Tyrolsport collar kit.
LastHumansGarage
