Old 12-21-2014, 05:36 PM   #15
kern417
Drives: '09 Jetta
he's going off of a different manual
do a burnout.
Old 12-21-2014, 07:01 PM   #16
Jeffs2013GTI
Jeffs2013GTI's Avatar
Drives: 2013 SB GTI
Originally Posted by maxtdi View Post
But this doesn't help me to bitch about how I'm going to dump vw because it is an unreliable pos.
Seriously thanks for the post ! Looks pretty damn easy.
MaxTDI do the TDI's have the same issue?
I was on the fence about trading in my GTI. Im on its 3rd WP in 22K miles. I just cant afford the loss right now.
One thing that does suck is VW Only provides Roadside Assistance for 3 yrs or 36k miles, even though the WP is covered for 5yrs or 60k miles. SSSOOO Does this mean I am paying for the 100+ mile tow to the nearest VW dealer if the next one fails after 36k?
If it happens to me again? I am getting an attorney and filing Lemon Law.
Jeff
Old 12-22-2014, 09:20 AM   #17
v.b
Drives: K04 rocketship
A leaking waterpump doesn't require towing. All it requires is some distilled water until you can reach the dealership.
v.b is offline   Reply With Quote
Old 12-22-2014, 10:01 AM   #18
Jaber
Modero
Jaber's Avatar
Sub'd.
Member Journal
Old 12-22-2014, 10:18 PM   #19
DBESTGTI
DBESTGTI's Avatar
Drives: 2011 Stage 2 GTI
Originally Posted by zrickety View Post
Not necessary to replace the throttle body gasket or bolts?
No.
Why do the water pump bolts get replaced? The blue loctite or gasket sealer on the end?
They come with dried loctite applied and the new ones always thread better then the reused ones.
Bentley manual doesn't list them to be replaced.
I don't care what the Bentley manual says
Old 12-22-2014, 10:35 PM   #20
Ok, thanks for the clarification. I just take the bolts to the wire wheel and add new loctite.
zrickety is online now   Reply With Quote
Old 12-23-2014, 03:05 PM   #21
Jeffs2013GTI
Drives: 2013 SB GTI
How bad mine was leaking and the fact the closest Dealer was over 100 miles away? Nah Its getting towed. Especially if its on VW's Dime. LEAST THEY CAN DO!!
Jeff
Old 12-23-2014, 03:31 PM   #22
v.b
ive driven longer with a leaking waterpump. just stop by a pharmacy and get a gallon of distilled water. should last long enough easily..
Old 01-07-2015, 07:06 PM   #23
I am literally in the middle of this right now. I have the new pump and oil cooler union o-rings, but have somehow overlooked the o-ring on that plastic pipe. ECS website doesn't list it under the water pump or lines. Do you have a part number or idea where to find it??
Edit- ECS live help says it's N90365302 (ES#3683). Listed for FSI only but he cross referenced the part number on the pipe. Just a heads up for anybody doing this job.
Looks like this pipe o-ring is 20x3mm, advance auto carries one (dorman) I am going to check it out tomorrow.
Old 01-07-2015, 07:55 PM   #24
maxtdi
GolfMK6 Elite
maxtdi's Avatar
Jeff
Some had issues... mine is fine at 4 years 46k miles for now... But the engine is different to the waterpump is likely to be slightly different as well.
Do note that if you wanted something reliable you should likely go with a japanese car.
Old 01-08-2015, 03:41 PM   #25
Don't forget the torque wrench, I could see how the pump might be easily cracked. 6 ft lbs for the bolts. The 20 mm o-ring from Advance does work for the plastic pipe. Set aside more than a couple hours, this was a pain in the ass!! Half of the bolts you can't see and that belt really sucks. Everything is assembled in layers so attention to detail is a must. I could see how this might be a breeze after you've done it a few times.
Old 01-10-2015, 10:01 AM   #26
I would like to add that I didn't use any kind of vacuum tool. I could hear air escaping as I filled and let it idle as DBEST said. I squeezed the radiator hoses for good measure. Monitored coolant temp via software and it was steady to 208 degrees. After a couple days of driving it took maybe another 1/4" from the reservoir and all is well.
I think where installs go wrong is not cleaning the mating surface on the block or over tightening the bolts.
Old 08-17-2015, 08:57 AM   #27
Kingkong
Drives: CSG MK6 GTI
This DIY helped me out quite a bit when I replaced my water pump a couple weeks ago. I would also like to add that I also did not use the vacuum tool to replace the coolant and have had no problems so far.
2012 GTI CSG 6MT 2DR KingKong's Build Thread
3sdm 0.06 Wheels FK Streetlines DIY LED Interior Lighting LED Tails
Kingkong is offline   Reply With Quote
Old 01-16-2016, 07:32 PM   #28
slowgti
Drives: 2012 Autobahn
How much coolant should I expect on my garage floor once I disconnect hoses from the pump? Or should I drain all coolant first?
Thanks
k04
slowgti is offline   Reply With Quote
