Old 01-23-2016, 06:55 PM   #43
slowgti
Drives: 2012 Autobahn
Finished this job thanks to the great write up by dbest. Prob took eight hrs but I think I could get through it again in three knowing everything. I feel like a dumbass because ECS has the OE BG pump but I didn't see it when buying... I'm not too worried because the old pump made it 94k miles. I also checked the VW campaign/recall site and found nothing related to my car for a water pump swap.
k04
slowgti is offline   Reply With Quote
Old 01-23-2016, 07:18 PM   #44
kern417
Drives: '09 Jetta
Originally Posted by CustomZ02 View Post
Not sure how I have a BA pump Im guessing thats not the original pump? If so maybe the dealer replaced it before I bought the car. But the service part guy got all worked up when I asked him what the part number was on the bad pumps, so much so that he walked away from the counter and someone else had to help me out.
On the plus side I got the new pump in and no more leak, just gonna keep an eye on the levels and make sure im good.
BA is one of the later revisions. i don't know when it was officially released, but i doubt it came from the factory on a 2011. When i bought my replacement pump in March 2014 the latest revision was AT.
do a burnout.
Old 01-23-2016, 07:52 PM   #45
I see the plastic chunk now that I'm at the computer. I wonder if the bolts were over tightened. Tell me you guys are using a torque wrench...
Old 01-23-2016, 11:14 PM   #46
VgRt6
My 2012 came with the BA version pump. Manufactured in Sept 2011. CCTA engine. It's still in the car at 75k miles.
VgRt6 is offline   Reply With Quote
Old 01-24-2016, 05:08 PM   #47
kern417
Drives: '09 Jetta
well now that's really confusing.
do a burnout.
Old 01-25-2016, 08:37 PM   #48
VgRt6
The confusion is probably due to the BA pump being for the CCTA and the AT pump being for the CBFA engine. The revisions are alphabetical for the pumps for the same engine, but not necessarily for both engines. The latest pump for the CBFA is revision BG. The CCTA pump is up to revision DD, and CQ came before that.
Old 01-08-2017, 03:40 PM   #49
ferrariF60
ferrariF60's Avatar
Drives: 2010 TR 2DR GTI
so can a CBFA revision BG pump be installed in a CCTA engine?? what is the actual difference between a CBFA and a CCTA waterpump???
is there a BIG difference between them that it won't work in a CCTA engine?? OR maybe will work, does anybody know this??
ferrariF60 is offline   Reply With Quote
Old 03-27-2017, 11:18 AM   #50
Clutch
Drives: Black 2010 GTI 6mt
Another whole hearted "thank you" here.
Had to remove the radiator fan, and i had the extra noise pipe to disconnect, but otherwise spot on.
APR Stg 2 | Carbonio Stg 1 | SPM Street DP | Stern Mid Brace | SuperPro LCA Rear Bracket | SB Stg 2 Endurance (4 spring) | StopTech SP pads | TyrolSport Caliper Stiffening Kit | Dust Shield delete | R8 Coilpacks | Super Sports on Denvers
Clutch is offline   Reply With Quote
Old 04-13-2017, 11:39 PM   #51
Sachz71
Sachz71's Avatar
Drives: Mk6 GTI APR STAGE 1
great !
Sachz71 is offline   Reply With Quote
Old 08-19-2017, 03:18 PM   #52
Joveen
Pics need to be updated smh
Sent from my Life One X2 using Tapatalk
BONE STOCK!
Joveen is offline   Reply With Quote
