Old 12-16-2014, 08:53 PM   #29
ThatGTI
ThatGTI's Avatar
Drives: 2010 Volkswagen GTI
Okay, I did the coding again and it worked and so did the cruise control. I don't know what happened there. And before anyone asks yes I did turn the cruise control switch on and off to see if it works.
2010 Volkswagen GTI
Instagram - ThatGTI
Need VAG-COM/VCDS? PM me!
ThatGTI is offline   Reply With Quote
Old 12-16-2014, 09:03 PM   #30
carsfeverguy
Drives: 2010 Gti
I have the AH version and it doesn't work... I want to cry...
Old 12-16-2014, 09:06 PM   #31
carsfeverguy
Drives: 2010 Gti
Size:  328.4 KBName:  ImageUploadedByTapatalk1418778372.243244.jpg
Size:  321.5 KBName:  ImageUploadedByTapatalk1418778379.804573.jpg
Size:  332.6 KBName:  ImageUploadedByTapatalk1418778387.462538.jpg
tire pressure monitor gets enabled....
Old 12-16-2014, 09:10 PM   #32
recognized1
recognized1's Avatar
Drives: 2011 VW GTI
Holy crap I have to try this.
recognized1 is offline   Reply With Quote
Old 12-16-2014, 09:10 PM   #33
ThatGTI
ThatGTI's Avatar
Bummer. Maybe there is a different set of coding for the AH version.
2010 Volkswagen GTI
Instagram - ThatGTI
Old 12-16-2014, 09:12 PM   #34
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Subbed
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 12-16-2014, 09:13 PM   #35
ThatGTI
ThatGTI's Avatar
I'll have a video tutorial up in a bit on my 2010 that has the AM version.
2010 Volkswagen GTI
Instagram - ThatGTI
Old 12-16-2014, 09:39 PM   #36
ThatGTI
ThatGTI's Avatar
Here is a quick video on how to do the ESP defeat. I'm doing this on a 2010 manual GTI with the AM version. It should be the same process for 2010s and 2011s, but the AH isn't the same. I'm not responsible if anything occurs while you change anything on VCDS.
2010 Volkswagen GTI
Instagram - ThatGTI
Old 12-16-2014, 09:50 PM   #37
Mustache rash
Sweet. Thanks man!
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 12-16-2014, 09:57 PM   #38
He told me pumps ending in AH and AJ have a different function. I can confirm this works on the 10 GTI.
ABS Brakes, coding, long coding helper, change byte 16 to 3C. Our DSG car had hill assist enabled, so I checked that back and it changed to 3D. So I hit 'DO IT!' and it worked. Previously showed B5 for that byte. I will also have to attend autox to see the difference.
Old 12-16-2014, 10:02 PM   #39
aw614
Drives: 2011 CW MKVI GTI
hmm I guess I can play with the long coding to see if I can get two stage esc
Old 12-16-2014, 10:10 PM   #40
I had a feeling it was a simple change, had no idea it would be this easy. He told me a colleague figured it out and they are testing other pumps. If people can post their year and pump version that works, I can update the first post.
Old 12-16-2014, 10:22 PM   #41
carsfeverguy
Drives: 2010 Gti
Please have them look at the AH ones... I can be a test subject if they need it.
April 2010 mk6 manual gti
114B800C49290001880B01E4921A0041300800
Old 12-16-2014, 10:24 PM   #42
engineered2win
engineered2win's Avatar
Drives: Subaru WRX, Multistrada DVT
I have a 2011 TDI with ABS module 1K0907379BC and it did not work. Bit 16 was originally B7. B7 changes to B3 when I uncheck the TPMS, but it will not accept the changes unless TPMS is enabled.
Edit1:
B7 = 10110111 = Hill Hold & TPMS enabled
B3 = 10110011 = Hill Hold Enabled, TPMS disabled
3C = 00111100 = ?
3D = 00111101 = Hill Hold enabled, TPMS enabled
39 = 00111001 = Hill Hold enabled, TPMS disabled
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: 114B400C492300FF881102E492190042B70800
Shop #: WSC 12345 123 12345
VCID: 74C1F090D759B1817B3-8021
Edit2:
I changed byte 16 from B7 to 3D. It isn't a 2 stage TCS/ESP button; it changed the button to ESP disabled or ESP/TCS Active. I really have no use for disabling TCS, so atleast I have a functional button now. I got a rather strange ABS fault after flashing it to 3D:
02186 - Engine <-> ADR Interface
004 - No Signal/Communication - Intermittent
I can't find much info on ADR interface, but I cleared it. We shall see if it returns.
engineered2win is offline   Reply With Quote
