Old 12-16-2014, 10:35 PM   #43
carsfeverguy
Drives: 2010 Gti
Someone else's AH coding
Old 12-16-2014, 10:39 PM   #44
aw614
Drives: 2011 CW MKVI GTI
Originally Posted by engineered2win View Post
I have a 2011 TDI with ABS module 1K0907379BC and it did not work. Bit 16 was originally B7. B7 changes to B3 when I uncheck the TPMS, but it will not accept the changes.
Mine has B7 also in the coding, did you just try changing it to 3c in the new long coding instead of changing it through the long coding helper? I will have to check if I still have hill assist.
This is my abs module information from my previous post
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C492400FA880B06ED92220041B70800
Shop #: WSC 01357 011 00200
VCID: 78D131C3CB505BD8195
And the coding changes if you want to put that in the sticky.
My old coding byte 16
New Coding I put in long coding:
114B600C492400FA880B06ED922200413C0800
EDIT: I messed with it again, and I am using 3D now which keeps hill assist and the abs based TPMS. I think 39 will keep hill assist, but disable TPMS. I was doing it in a hurry, but you can probably mess with the settings and verify. My battery is weakening so I will probably wait until next week until I get the new battery before I mess with it some more. (it's cheaper at the dealer than the autoparts store so I set up an appointment lol)
Old 12-16-2014, 11:20 PM   #45
kern417
Drives: '09 Jetta
zrickety are you still on your original control module? mine is bad and i'm wondering if picking a specific replacement will let me jump on this. i was originally looking to see if a 2012+ module could be swapped in to enable the esp defeat.
do a burnout.
Old 12-16-2014, 11:33 PM   #46
Yes, the 09 is still on the original module ending in AD.
Old 12-17-2014, 01:28 AM   #47
carsfeverguy
Drives: 2010 Gti
Some long codes from various people, I really think if we compile these we can maybe get somewhere. I invite you to help you fellow enthusiasts, by posting the version of your ABS and the long code. As well as the year. It would be interesting to know why an 09 can do it but to all 10s
AH
114B800C49290001880B01E4921A0041300800
114B600C492200FF881006E492190041300800
AJ
11424012092300FC880C02E5901A0041390800
113B200D092A00FB880D04E7901E0041350000
BG
BJ
113B200D092600FB880F04E5901B0041310000
323B601609230E024C1306EC901C7042350000
AM
114B600CC9290001881406E9932000413408
AE
113B400D492400FF881202E9921B0042B100
163B600D092300FF680D06E6901D0081B500
Old 12-17-2014, 01:39 AM   #48
Pmanpop
Pmanpop's Avatar
Drives: 2011 Vw GTI
This is preety cool. I have esp deleted through the steering angle coding so it's permanently off all the time. But this would be cool for those who want the option. Does xds still work with this?
Old 12-17-2014, 02:59 AM   #49
corrado917
corrado917's Avatar
Drives: GTI CSG
Good question!
Old 12-17-2014, 03:40 AM   #50
carsfeverguy
Drives: 2010 Gti
Since the steering sensor is not disabled, XDS should work normally.
Question for you folks where the setting took.
For BYTE 16 what were the Binary codes before and after the setting took???
The binary number is a 8 number number made of 0 and 1.
I am curious to see if the binary code can give us a clue where this setting hides in the AH module.
Thank you in advance.
Old 12-17-2014, 03:53 AM   #51
nafljhy
Drives: 2011 UG GTI
So I have a BG pump and I was able to do the code change! However, I can't tell if it's fully disabled or not..
I can checkk the binary codes for you in the AM.
EDIT: I should clarify that I don't have the two stage of just TCS then ESP.
When I do disable it, I get that ESP is disabled. However, when I turn it back on, I get "TCS/ESP is active". Before changing the code, it didn't say that when re-enabling ESP/TCS.
EDIT2: OK! so the code change DID work! I know cause as I was looking up the binary codes, I decided to switch back to my original coding, but no two stage disabling.
B6 = TCS Deactivated - TCS is Active
VS
3C = ESP Disabled - TCS/ESP is Active
Old 12-17-2014, 03:55 AM   #52
carsfeverguy
Drives: 2010 Gti
Thank you
Old 12-17-2014, 04:24 AM   #53
nafljhy
Drives: 2011 UG GTI
Originally Posted by carsfeverguy View Post
Thank you
NP! I actually couldn't wait so I went ahead and got the binaries.
3C - 00111100
B6 - 10110110
B7 - 10110111
Another thing to note is that I have TPMS checked but Hillhold Assist Uninstalled. If I have Hillhold Assist installed the code goes from B6->B7
Old 12-17-2014, 04:31 AM   #54
carsfeverguy
Drives: 2010 Gti
Originally Posted by nafljhy View Post
3C - 00111100
B6 - 10110110
And what would be the binary of B7?
Old 12-17-2014, 04:36 AM   #55
nafljhy
Drives: 2011 UG GTI
haha, got any other code binaries you want me to check before I go out again?
Old 12-17-2014, 04:46 AM   #56
carsfeverguy
Drives: 2010 Gti
No man, I am actually hitting the hay, so I will try to continue tomorrow... Since B7 was your stock setting I want to look in all the other bytes, a binary that looks like your stock one... If that makes sense. Thinking of that, since this byte does take care of the hill hold and tpms, maybe it would be good to have the binary of the byte when both are disabled, yet stock...if that makes any sense.
