Old 12-17-2014, 04:51 AM   #57
nafljhy
Drives: 2011 UG GTI
Originally Posted by carsfeverguy View Post
No man, I am actually hitting the hay, so I will try to continue tomorrow... Since B7 was your stock setting I want to look in all the other bytes, a binary that looks like your stock one... If that makes sense. Thinking of that, since this byte does take care of the hill hold and tpms, maybe it would be good to have the binary of the byte when both are disabled, yet stock...if that makes any sense.
Not a problem and yea, that makes sense. I've added the binary for B7 in my previous post.
Old 12-17-2014, 09:27 AM   #58
aw614
Drives: 2011 CW MKVI GTI
Binary of the following. I need to check it again, but I think 3D has hill hold and tpms enabled. 39 I can't recall, but if someone can verify for me since Im at work, if it had hillhold and tpms both disabled, both had ESP disabled with a button press.
3D - 00111101
39 - 00111001
Old 12-17-2014, 10:09 AM   #59
On the 2010 mine said B5 before the change. I do have indirect TPMS and hill hold enabled using 3D.
Old 12-17-2014, 10:14 AM   #60
Jaber
Modero
Jaber's Avatar
Sub'd. For fellow member that needs this done
Member Journal
Old 12-17-2014, 11:33 AM   #61
vwgti2.0t
Drives: 2011 CW GTI
I don't know how I missed this tread, but good shit! Here is my coding info, I have the BC module. I will try this today after work and post results.
2011 GTI 6MT
Manu Date: 8/10
Address 03: ABS Brakes
Control Module Part Number: 1K0 907 379 BC
Component and/or Version: ESP MK60EC1 H30 0106
Software Coding: 114B600C49280001881206E9921A0041B70800
Old 12-17-2014, 12:04 PM   #62
I had googled 'MK60EC1 ESP OFF' to find the video, added link to original post. I was in shock when I saw it.
Old 12-17-2014, 12:21 PM   #63
aw614
http://forum.octaviaclub.pl/viewtopic.php?p=1342310
The youtube link looks like the author posted here too, hard to understand using google translate, maybe there is more information on the other links
looks like this is another similar video on a mk5
https://www.youtube.com/watch?v=aoUnXOZ87S8
Old 12-17-2014, 01:03 PM   #64
Even translated, those forums are greek to me. It looks like the Polish get some information from Russian forums, that part is interesting.
Old 12-17-2014, 03:36 PM   #65
nafljhy
Drives: 2011 UG GTI
not sure if this is normal, after coding and disabling ESP and turn off the car. once i turn back on the car, ESP is active again. This normal? Clearly, I don't turn off ESP/TCS often.
Old 12-17-2014, 03:42 PM   #66
aw614
If you hit the button, do you get the ESP deactivated instead of the old TCS deactivated message?
Old 12-17-2014, 03:46 PM   #67
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
2011 GTI 6MT
Manu Date: 8/10
I have the same one as you! What coding are you changing specifically?
Byte 16 in our string is B7 so what do we change it to?
Current string: 114B800C492600FA881301E8921A0041B70800
Proposed string? 114B800C492600FA881301E8921A0041__0800
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 12-17-2014, 03:50 PM   #68
vwgti2.0t
Drives: 2011 CW GTI
I'm assuming we change that to 3D. I'll be home in an hour or so and will report back!
Old 12-17-2014, 03:52 PM   #69
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
*****2.0t and I are in the same grouping here as well.
Originally Posted by aw614 View Post
Mine has B7 also in the coding, did you just try changing it to 3c in the new long coding instead of changing it through the long coding helper? I will have to check if I still have hill assist.
This is my abs module information from my previous post
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C492400FA880B06ED92220041B70800
Shop #: WSC 01357 011 00200
VCID: 78D131C3CB505BD8195
And the coding changes if you want to put that in the sticky.
My old coding byte 16
New Coding I put in long coding:
114B600C492400FA880B06ED922200413C0800
EDIT: I messed with it again, and I am using 3D now which keeps hill assist and the abs based TPMS. I think 39 will keep hill assist, but disable TPMS. I was doing it in a hurry, but you can probably mess with the settings and verify. My battery is weakening so I will probably wait until next week until I get the new battery before I mess with it some more. (it's cheaper at the dealer than the autoparts store so I set up an appointment lol)
Originally Posted by engineered2win View Post
I have a 2011 TDI with ABS module 1K0907379BC and it did not work. Bit 16 was originally B7. B7 changes to B3 when I uncheck the TPMS, but it will not accept the changes unless TPMS is enabled.
Edit1:
B7 = 10110111 = Hill Hold & TPMS enabled
B3 = 10110011 = Hill Hold Enabled, TPMS disabled
3C = 00111100 = ?
3D = 00111101 = Hill Hold enabled, TPMS enabled
39 = 00111001 = Hill Hold enabled, TPMS disabled
I'll try 3D when I get home and post the VCDS scan.
YouTube: HYDE16
Old 12-17-2014, 03:59 PM   #70
nafljhy
Drives: 2011 UG GTI
that is correct. I had put that information in one of my edited posts. should've made a new post. sorry about that.
i think i should clarify. after driving the car with ESP disabled, i turn off the car and get out to do some errands. I get back in the car and turn the car on, ESP is active again. Is that what normally happens? I need to push the button again to disable.
