It isn't that complicated, dudes.
HYDE16 said:
how should I adjust these? Right now they are the same length as the factory end link front and rear.
Should I be adjusting these for better traction/pre-load or due to the fact that I want to adjust my ride height to have a "rake" for better front end traction?
HYDE16 said:
I’m not sure if I want pre-load or no pre-load like this person discusses in their procedure.
Generally and firstly, you want NO preload at all.
The questions are, do you want to have your car corner weighted,
should it be optimized for one single driving situation, e.g. with a
driver and 3/4 full of fuel like those do who use to drive on track?
I had this done, and that's exactly where someone needs both the
adjustable coilovers and endlinks.
If you plan to get the corner weights adjusted, the that guy surely
will know how to do the job properly.
Ok, if you don't want or don't have someone with the necessary
scales for corner weight adjustment near you, then you can do
the
endlinks on yourself quite easily.
Remember, still no preload.
To achieve this you most probably need
to adjust unequal lengths left and ride, ahh right, as most cars aren't
same weight left and right. Just see where the engine is sitting, which
is much heavier than the gearbox. I'm not exactly a small guy, but I
wasn't able to compensate for the engine's weight. The car's still heavier
on the
passenger's side (LHD, RHD will even be worse).
Here we go:
1. set tire pressures evenly, place car on
even ground (
check before)*
2. loosen one end of at least one endlink on each axle
3. adjust coilover height to your needs (same left + right
4. loosen lower bolt of rear damper, bop the rear a couple of times, then retorquen bolt**
5. adjust one endlink (the side you didn't loosen) so that it's a appr. 90° to the sway bar, torquen it***
6. then set the other side of same axle so that it fits the hole in the sway bar without force
7. do the same on the other axle
8. done
When you later check this again with slightly different weight (fuel level)
you'll notice this "adjustment" is "out". Every situation simply requires
its own adjustment.
So, don't over do it.
* place some weight on the driver seat if this is what's most relevant
** any time when you changed rear ride height; just loosen a few turns, don't remove it
*** angle will affect sway bar stiffness slightly - 90° is softest
