Old 01-06-2015, 12:16 PM   #1
///Audience
///Audience's Avatar
Drives: 2013 GTI Autobahn
Can I run a GFB DV+ with a Uni DV Relocate?
I already have a GFB DV+ installed in my car and am wondering if this will interfere with any of the parts involved in the Unitronic DV relocate kit?
Thanks/
The worst thing about this particular signature is that by the time you realize it doesn't say anything, it's to late to stop reading it.
///Audience is offline   Reply With Quote
Old 01-06-2015, 12:18 PM   #2
Mensurpj
Drives: Golf R
yes you can, im currently running it with no issues
Stage 2+ Golf R
Mensurpj is offline   Reply With Quote
Old 01-06-2015, 06:23 PM   #3
kwmk6
Drives: 2011 MKVI GTI
I have been running this with no problems as well for almost a year
APR K04, Uni Stage 2+, Uni Intake, HFS-4 DPI W/M, APR Intercooler, HPA Subframe 75A, 034 Engine & Trans Mounts, APR TBE, AWE Boost Gauge, AEM Oil Psi Gauge Sigma-6 Shifter, SB Stage 2 End Clutch, H&R TouR Cup Kit, APR Rear Sway Bar, Neuspeed RE12's, R8 Coils, NGK Plugs. Uni DV Relocate Kit, CTS BOV, BSH Throttle Pipe, Neuspeed TOP. Hawk HPS Pads with EBC rotors.
kwmk6 is offline   Reply With Quote
Old 01-08-2015, 10:19 PM   #4
John@Unitronic
GolfMK6 Official Vendor
John@Unitronic's Avatar
Drives: MK3 TTRS
Our DV Relocation Kit is designed for the stock diverter valve and included machined DV adapter to be connected to the re-route leg of the throttle body hose only. I wouldn't recommend adding anything additional.
UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
Web: GetUNITRONIC.com | Tel: (866) 341-2447
Follow us on: Facebook | Instagram | Twitter
John@Unitronic is offline   Reply With Quote
Old 01-08-2015, 11:34 PM   #5
initiala4
Drives: VW Golf 2.0 TSI
Yes it will work!
initiala4 is offline   Reply With Quote
Old 01-09-2015, 03:56 AM   #6
///Audience
Thanks for the reply! Can you please clue me in as to what issues could arise from running the DV+ along with your relocate kit?
Old 01-09-2015, 08:25 AM   #7
U-20T
Drives: BT GTI4Motion
I wouldn't recommend the dv+ in general....
Old 01-09-2015, 09:38 AM   #8
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Why?
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Mustache rash is online now   Reply With Quote
Old 01-09-2015, 09:46 AM   #9
ZiggyMKVI
ZiggyMKVI's Avatar
Drives: 2010 Black GTI
Yes i also would like to know why not
2010 GTI _ mods: Magnaflow-Catback, DG short shifter, BSH catch can, Neuspeed Throttle body and Discharge Pipe, ESC intake, R8 Coilpacks, Forge Motosports coilovers, Rotiform TMB 18 x 8.5, SPM Catless DP, Stage 2 Unitronic, ARM front mount
IG: Scottziggs
ZiggyMKVI is offline   Reply With Quote
Old 01-09-2015, 09:47 AM   #10
shdwblugti
GolfMK6 Elite
shdwblugti's Avatar
Drives: 2016 non DSGhey R
car meets: helping awkward dorks get over their anxiety of meeting new people one thursday at a time.
Originally Posted by jgarcia1925 View Post
The elite and smart ones don't get fucked. Us plebeians do........... Thanks Obama!
shdwblugti is offline   Reply With Quote
Old 01-09-2015, 10:03 AM   #11
jay745
jay745's Avatar
also curious. I love mine, as well as so many others on this site. I've never heard anything bad about it.
What say you U-20T?
Old 01-09-2015, 10:17 AM   #12
vwgti2.0t
Drives: 2011 CW GTI
Some people are against it for no apparent reason. Even if you don't use the extra spring, it operates exactly like the OEM valve, but with a metal piston that doesn't leak and won't fail. I use the extra spring. Been on my car for over a year and a half with no issues. Same with a million other people.
Old 01-09-2015, 10:36 AM   #13
U-20T
Its not "for no apparent reason" its because it does not operate like a true dv valve with the extra spring nor as intended.
You want your dv to react as fast as possible with the way the dv+ with the spring its not the case. It relies on boost to physically open thus its slow (its like no hooking up vacuum lines to a pneumatic dv in a sense or putting to heavy springs in it). Then because of that 100% of excess does not pass through it. Both situations is why there is a DV in the first place....
My DV is adjust just enough so that it holds boost and therefore its instant blowoff, it will blow off before the TB is fully closed.
Everyone is free to do what you want Im just putting it out there, I wouldn't use it. If you must use it take the extra spring out so its like a normal dv, but at that point its pointless anyway.
To me a vacuum valve is a better solution which you could use on a relocate situation. At least its fast and will act like a dv should. You will loose the overboost safeguard the oem has but it operates better.
I believe there is a better solution out there if you don't want it to "leak" (maybe a loss of a few hp) but I wont spend the money to figure it out since I don't use electronic anymore anyway.
Old 01-09-2015, 10:55 AM   #14
John@Unitronic
Drives: MK3 TTRS
Our multi-ply reinforced silicone throttle body hose is designed to support the supplied billet machined DV adapter and OEM DV only. Any additional weight on the re-reroute leg of the throttle body hose may cause adverse effects.
