Old 01-13-2015, 01:09 PM   #1
GTI2.0
Drives: 2010 GTI 6SM
Rough idle
Lately my car has been running rough, but no cel. It seems to hesitate on acceleration too. I have about 60k on the car now. I haven't done a tune up yet, because a local VW dealership told me that it is a 60k service, but from what I see online is that a lot of people do it at 40k. I was thinking about replacing my coil packs when doing the tune up. Do you guys think the tune up will help and if I should replace the coil packs as well? They are the original ones.
GTI2.0 is offline   Reply With Quote
Old 01-13-2015, 01:16 PM   #2
RGTI13
Drives: 2013 D.E. DSG GTI
Replace the coilpacks! While you're doing it, you might as well switch to Audi R8 packs if you're tuned (or not).
For now, check if the coilpacks are seated properly. Just gently push down on them.
Old 01-13-2015, 01:27 PM   #3
GTI2.0
Thanks, I do want the R8s. I am not tuned, but hope to do stage I eventually. Is 60k a world record for the longest lasting VW coil packs ?
Is 40k the correct mileage for a tune-up? I'll check the coilpacks for now.
Old 01-13-2015, 01:29 PM   #4
RGTI13
I'm not quite sure on the mileage stuff... But "technically" stock coil packs should last pretty long... But you never know. That's a general failure point for stage one cars, so that would probably be the first place you look.
What about spark plugs? Change those recently? 60k on plugs would be a lot.
Good spot to pick up coils.. Price recently went up though: http://www.amazon.com/Genuine-Volksw.../dp/B008QXZ5UI
Sign up for Amazon prime and get next day air shipping for cheap! (;
Old 01-13-2015, 01:59 PM   #5
robeeeerob
robeeeerob's Avatar
Drives: 2013 CW GTI (DSG)
Yeah, it sounds like it's either the spark plugs or the coil packs. You should probably change out both. And yes, do the R8 coilpacks. For spark plugs, you have several options, but I'd recommend either the NGK BKR7EIX or the NGK PFR7S8EG.
http://www.hstuning.com/index.php?vp...89&cPath=24_32
http://www.ecstuning.com/Volkswagen-...gine/Ignition/
A WOT a day, keeps the carbon away
robeeeerob's Build
Need an install or auto service done?RobzAuto
robeeeerob is offline   Reply With Quote
Old 01-13-2015, 02:06 PM   #6
GTI2.0
Thanks guys! I am going with the NGK plugs.
Old 01-13-2015, 02:12 PM   #7
Rcode
Rcode's Avatar
Drives: 2016 Golf R
If the spark plugs and coil packs don't fix it, scan for random cylinder misfires. They don't always throw a CEL. Could be carbon buildup at that mileage.
Stockish
Rcode is offline   Reply With Quote
Old 01-13-2015, 02:14 PM   #8
RGTI13
This is a great point. Very likely it could be carbon buildup...
Old 01-13-2015, 02:14 PM   #9
robeeeerob
robeeeerob's Avatar
NP! Also, here's additional info on both coilpacks and sparkplugs, in case you're curious or want more guidance on your options:
http://www.golfmk6.com/forums/showthread.php?t=37818
robeeeerob's Build
Old 01-13-2015, 02:15 PM   #10
GTI2.0
Thanks, and will do I had the carbon build up cleaning done at 40k. Would you say its possible that I could need it again?
Old 01-13-2015, 02:16 PM   #11
GTI2.0
Thanks
Old 01-13-2015, 02:20 PM   #12
Rcode
Rcode's Avatar
Drives: 2016 Golf R
The real cleaning or sea foam? If the real cleaning, I would doubt carbon then. I know I have a carbon issue right now. I have to clear a CEL weekly. So many misfires with brand new plugs and coils.
Stockish
Old 01-13-2015, 02:33 PM   #13
GTI2.0
The real cleaning at the dealership. I heard sea foam doesn't do crap. I didn't have any problems, but I did it for a piece of mind. It only cost me $174 so well worth it IMO. The tune up I will be doing myself.
Old 01-13-2015, 02:39 PM   #14
RGTI13
They only charged you 174? Wow...... I would confirm that it was a true cleaning. That price sounds too good to be true, no?
