Old 01-23-2015, 07:50 PM   #29
ShrekSquatch
ShrekSquatch's Avatar
Drives: 2016 Oryx White Golf R DSG w/DAP
I just had to replace my OEM battery in my 2012 GTI. I'm sure leaving the lights on until the battery was almost dead (twice) accelerated its demise.. No mods that would impact battery life. Even though I'm in the "hotlanta" area, I'm north enough to where I still see less than 20 degree temps, and of course 100+ in the summer.
Replaced it with an Advance Auto Parts AutoCraft Platinum AGM for $130 after $50 off coupon, tax and core swap. Night and day difference with cranking the ignition, even when it is 50 degrees...
2016 Oryx White Golf R with DSG, DCC, DAP, and some DIY. Tint, euro tails, hardwired dash cam, JB1, euro folding mirrors, S3 resonator delete, PedalBox
ShrekSquatch is offline   Reply With Quote
Old 01-24-2015, 03:46 AM   #30
jshay
jshay's Avatar
Drives: GLI
I hate the OEM battery. Got one replaced at 10K then that one died at 32K. They wouldn't replace it again and wanted to charge me $150 for it because apparently OEM batteries only have a 1 year replacement plan.
I went and got myself DieHard Advanced Gold battery. It cost ~$150 but has a 3 year replacement warranty then a prorated 10 year warranty I believe. So far this battery has been great.
FrankenTurbo GLI Build Thread
@qetoffmylawn
Old 01-24-2015, 09:14 PM   #31
nvturbo
nvturbo's Avatar
Originally Posted by WAP View Post
See above.
I did...and the OEM battery is STILL JUNK. The one I got from Walmart is 10x better.
Old 01-25-2015, 01:11 AM   #32
WAP
WAP's Avatar
^Yea, ok. Just keep ignoring many first hand testimonials.
Old 01-25-2015, 02:35 AM   #33
dave80
dave80's Avatar
Drives: vw
still running oem battery since mid 2009...........
dave80 is offline   Reply With Quote
Old 01-25-2015, 02:37 AM   #34
WAP
WAP's Avatar
Boom. There's another one.
Old 01-25-2015, 11:36 AM   #35
finklejag
finklejag's Avatar
I replaced the battery in my 2010 with a Deka AGM.
finklejag is offline   Reply With Quote
Old 01-25-2015, 12:21 PM   #36
mattkosem
Drives: 2013 R
Ooh, that's the one I ordered (and linked a few pages back). Is the box not fitting correctly around it? I'm going to have trouble if it won't because of the proximity of the stage 3 intake elbow.
--Matt
'13 R - APR Stage III w/LPFP & RFD, APR RSC Exhaust, Wavetrac Differential, 034 Street Density Mounts, HPA Competition Haldex Controller, HPA Dog Bone Mount, VWR Springs
mattkosem is offline   Reply With Quote
Old 01-26-2015, 08:44 PM   #37
finklejag
finklejag's Avatar
It's a tad bigger then the oem. I can close the lid on the battery, but the front clip doesn't snap into place.
Old 01-26-2015, 09:45 PM   #38
mattkosem
Drives: 2013 R
Ouch. Does it cause the box to stick out any further on the side? That's my concerning area.
--Matt
Old 01-26-2015, 10:07 PM   #39
jshay
jshay's Avatar
Drives: GLI
You can fit group 47 or group 48 batteries in our cars. Group 47 is OEM size and 48 is a tad larger.
@qetoffmylawn
Old 01-26-2015, 10:34 PM   #40
AccelaSX
Drives: 2012 Black GTI K04 Autobahn
Originally Posted by mattkosem View Post
My car is a 2013, and mine is already toast. I don't have any stereo mods either. Barely starts under 20F. I've got the RFD, though, so it is a harder than usual task in all honesty.
--Matt
Same here. 2.5 year and Varta would barely crank when it was lower than 5 degrees. I installed AGM type battery by Duracell. Who knew that Duracell makes car batteries. It has been 2 weeks and it runs great so far and the fitment was perfect.
AccelaSX is offline   Reply With Quote
Old 01-26-2015, 11:01 PM   #41
brinkmen
brinkmen's Avatar
Drives: '15 Golf R DSG, '16 GTI S 6MT PP LP
A battery is a battery. Don't they all have acid and water in them?
Performance: APR Stage 1 | 034 CF intake | 034 RSB | 034 End Links | 034 Dogbone Insert | 034 Rear Subframe Inserts | Neuspeed RSe12s w/A/S3+
Looks: Euro R Brushed Side Mirror Caps | Euro Blind Spot Side Mirrors | Blue Footwells | Reverse LEDS | 3M Tint
Misc: Numerous VAG-COM tweaks | Valentine 1 | A118 Stealth Dash Cam
brinkmen is offline   Reply With Quote
Old 01-26-2015, 11:07 PM   #42
mattkosem
Drives: 2013 R
I think i need to try the group 47 Intimidator then. I don't have space to spare up there. We'll see if that shop (Remmy Battery) will let me cancel or change my order.
--Matt
