Old 01-26-2015, 11:27 PM   #43
AccelaSX
Drives: 2012 Black GTI K04 Autobahn
Originally Posted by mattkosem View Post
I think i need to try the group 47 Intimidator then. I don't have space to spare up there. We'll see if that shop (Remmy Battery) will let me cancel or change my order.
--Matt
I replaced mine with group 48 size AGM and it fit perfectly. You have tuck right edge of the battery in first. Group size 47 is smaller and will fit easier, but it will be downsizing. Group 48 is 70AH (OEM size) and Group 47 is 60AH.
AccelaSX is offline   Reply With Quote
Old 01-26-2015, 11:27 PM   #44
There is no water in the agm batteries, and the price difference is negligible if you shop around.
Old 01-26-2015, 11:47 PM   #45
jshay
jshay's Avatar
Drives: GLI
Ah I was sure 47 was OEM size but guess not. Either way both of them work well. I went with DieHard Advanced Gold. Awesome battery.
FrankenTurbo GLI Build Thread
@qetoffmylawn
Old 01-27-2015, 08:01 AM   #46
nvturbo
nvturbo's Avatar
Originally Posted by WAP View Post
^Yea, ok. Just keep ignoring many first hand testimonials.
What...you think I replaced the stock battery because I had nothing better to do with my money? Some people sure are illiterate these days.
....used to own a MK6 GTI
Old 01-27-2015, 05:58 PM   #47
WAP
WAP's Avatar
^Indeed.
A single data point is not a trend.
Old 01-27-2015, 06:59 PM   #48
mattkosem
Drives: 2013 R
^Indeed.
I provided another as well.
'13 R - APR Stage III w/LPFP & RFD, APR RSC Exhaust, Wavetrac Differential, 034 Street Density Mounts, HPA Competition Haldex Controller, HPA Dog Bone Mount, VWR Springs
mattkosem is offline   Reply With Quote
Old 01-27-2015, 07:09 PM   #49
jshay
jshay's Avatar
Drives: GLI
As did I
@qetoffmylawn
Old 01-27-2015, 10:56 PM   #50
WAP
WAP's Avatar
oem
Originally Posted by corrado917 View Post
This^
Got mine since 09 and no issues.
Originally Posted by cbenjes View Post
OEM. Still have the original battery in my car with a build date of Oct 2010.
This. Still on my original battery and my build date is 8/10.
I kept my Mk4 OEM battery for 7 years and it was still cranking fine when I replaced it, but I just thought it was time.
I've also had luck in the (distant) past with Diehard, too.
Originally Posted by NYCSuits View Post
OEM is the way to go and apparently the dealer sells them at a price lower than aftermarket brands which is shocking. My 2010 Tiguan is using the original oem battery and hasn't skipped a beat...was actually tested about a month ago and is perfectly fine
Originally Posted by brinkmen View Post
OEM. They come with a 6 year warranty. No way you'd need anything more unless you have like $10k in stereo equipment or something.
Again, I'm not the only one who had/has good luck with oem, dude. But whatever, I (and plenty of other people) are just saying that OEM batteries aren't shit and we've had good luck with them. I'm done.
Peace.
Old 01-27-2015, 11:00 PM   #51
mattkosem
Drives: 2013 R
Whatever you say. I've had 5 VWs since 2001, and none of the factory batteries lasted more than 3 years, two (06 GTI and my current 13 R) even failed in 2. Maybe Ohio is harder on batteries than where you live? They've all been daily drivers and I haven't had big stereos in lighting or any of them either.
--Matt
Old 01-27-2015, 11:29 PM   #52
jshay
jshay's Avatar
Drives: GLI
Oh and food for thought, OEM batteries only have a 1 year replacement and 5 year prorated rate replacement. My 2nd battery died after 14 months and they reduced the price form 150 to 100. For 150 I went and bought an aftermarket one.
@qetoffmylawn
Old 01-27-2015, 11:57 PM   #53
WAP
WAP's Avatar
I'm in the Chicago suburbs so subzero winters and 90-100* summers. Maybe their QC is spotty and some are better than others?
Old 01-28-2015, 09:35 AM   #54
VR6Growl
VR6Growl's Avatar
Drives: '12 Jetta 2.5 SEL; '14 328D xDrive
"OEM" Can mean a lot of things; and I doubt VW sources their batteries from a single source. My guess would be that they have some sources better than others.
I've had numerous VWs going all the way back to an '84 Rabbit diesel. Of my more recent ones:
08 R32: Battery failed at ~3 1/2 years, replaced with OEM.
09 GTI: Battery failed at 5+ years, replaced with Diehard iirc (still in if if anyone really wants to know)
12 TDI: Battery is still solid so far; though cold starts are cranking a bit slower/longer. Battery is currently ~2 1/2 years old...
That's just my guess though, from personal experience...
-Jason G. --
2012 Jetta 2.5 SEL
2014 BMW 328D xDrive
VR6Growl is offline   Reply With Quote
Old 01-28-2015, 07:01 PM   #55
WAP
WAP's Avatar
In for pole?
Old 01-28-2015, 07:32 PM   #56
Stinger
Stinger's Avatar
Drives: stick 4d CSG '11 Mk6
My OEM battery went dead a couple of times after leaving Pandora playing 10 mn with engine off. See sig for my audio. Now I just don't play anything without my engine running!
