:: ECS Tuning :: VW MKVI 2.0T ECS Angled Vent Pod Boost Gauge Kit - New Item !!!
Status
Not open for further replies.
ECS Tuning
Click HERE to order or for more information.
Most aftermarket boost gauges look like add-ons. The dial numbers and lighting don't match the factory gauges and many use a poorly-thought out mounting system that appears out of place.
ECS believes your boost gauge should be easy to see, and blend with your interior. That's why we've developed all-new boost gauge kits for your VW MKVI 2.0T.
The gauge design and lighting blend with other dash gauges to give it a sophisticated, factory-installed look.
We've even prepared a detailed photo tutorial outlining the installation, so the fun can start as soon as you open the box.
For our install PDF please click - Here
ECS Tuning
VW MKVI GTI Boost Gauge Options -
The performance of your turbocharger is an excellent indicator of overall engine health and your car's ability to make power. Manfiold boost pressure is a metric that should always be at the center of your attention.
ECS supplies an excellent range of boost monitoring options for your VW MKVI GTI, from analog vent-mounted boost gauges, to digital interfaces that display an unprecedented level of vehicle metrics.
Take a look at the ECS options and weigh them against your particular needs - you'll likely find a superb product that perfectly suits your VW.
ECS Tuning
New Prosport Digital Gauges For Your VW -
The EVO Series by Prosport Performance is the four time award winning, industry first, dual color digital gauge product line. These gauges feature a black bezel and completely blacked out screen when turned off.
Quick glance accuracy is achieved thanks to the 270° dial sweep. All EVO Series gauges perform a dramatic full digital sweep and self-check on start-up.
Available in dimmable red/blue or green/white backlighting, these gauges not only look good but also give a precise digital read-out that allows you to monitor the performance of your VW.
Status
