Old 04-21-2015, 09:51 AM   #1
kakluote
Drives: Audt TT 2.0 TFSI
Anyone use Toluene to mix with 91 gas to get 104 ?
APR K04, HPFP ,RFD,APR downpipe, Milktec Cat-back, APR DSG Stg K04, S3 OEM FMIC,NSP P-flo,OZ 18 Wheel
kakluote is offline   Reply With Quote
Old 04-21-2015, 10:14 AM   #2
RGTI13
Drives: 2013 D.E. DSG GTI
I am almost certain there are pollution laws in the US against doing this but probably not in China. Also, you would need like a 50% tank of toluene to get 104 from 91. Furthermore, it's very hard to ignite toluene and if it's not well-mixed you will have some major issues.
I advise against using any additives other than actual fuel (SS100, MS109, GTX, etc) to raise octane in order to run higher performance maps. I do not even use W/M to run a 100 map with 93.
Old 04-21-2015, 11:09 AM   #3
kakluote
it is also not allowed here.
my only options are troco acc or toluene.... which one is better?
Old 04-21-2015, 11:14 AM   #4
RGTI13
Neither of them. I wouldn't use either to go from 91 to above 100.. No way.
Old 04-21-2015, 11:23 AM   #5
GIACUser
GIACUser's Avatar
Drives: 2008 MKV EFR7163
Toulene is actually a by-product of gasoline productionion and contains exactly the same ingredients as regular gasoline. It is an excellent anti-knock fuel at 114. It is also has greater density than gasoline and contains more energy per unit volume. It is very effective in turbo motors as it degrades more slowly than 100oct gas or Methanol when under load. Recommended not to use more than 30% Toulene in a gas mix.
Toulene was actually used as a fuel in F1 cars. They ran 84% Toulene and it was so effective at suppressing ignition they actually had to heat the fuel before injecting it.
Yes it works, but it seems impractical unless you have no access to race fuel. I use water meth to reach higher octane levels and find it convenient and you only use it when you really need it.
It is also a REAL health hazard if not handled properly.
Old 04-21-2015, 11:26 AM   #6
bmllr8
bmllr8's Avatar
Drives: Wagon Queen Family Truckster
You won't find many people who have access to this in the US. It is a regulated inhalant here.
bmllr8 is offline   Reply With Quote
Old 04-21-2015, 11:33 AM   #7
RGTI13
This.
Old 04-24-2015, 01:07 PM   #8
Calkulin
Calkulin's Avatar
Drives: '13 GLI Nav
I use to run Toluene on my 450+whp SRT-4 for years when I would go racing(1/4 mile, street, etc). It was great at preventing knock and the car felt like a beast running it when compared to 100 octane fuel, heck, I could always tell when the mixture hit the injectors as the engine idled so smooth on it. I use to buy it in 5 gal drums at the paint store but the per gal price is too high now to keep using it
Calkulin is offline   Reply With Quote
Old 04-27-2015, 10:25 AM   #9
kakluote
what is the mixture rate?
Old 04-27-2015, 11:37 AM   #10
Calkulin
Calkulin's Avatar
Drives: '13 GLI Nav
I used 3:1 to get 98 octane
Old 04-27-2015, 12:02 PM   #11
socal87
socal87's Avatar
Drives: Black '12 GTI Sun/Nav 4dr 6MT
http://www.motorsportsracingfuels.com/OctaneCalculator.html
Toluene has an octane rating of 114; there is a gas station near here that sells 101 at the pump for nearly $10/gal. Toluene is generally more expensive but I'm not sure how much 114 gas is...
Favorite Color: EXPLOSIONS
Likes: EXPLOSIONS
Dislikes: Not-EXPLOSIONS
Jubblies. That is all.
socal87 is offline   Reply With Quote
Old 04-27-2015, 01:16 PM   #12
charrigan
Drives: 2013 GLI
A friend of mine use to use Xylene in is Mazdaspeed as a shortcut to race fuel.
Toluene and Xylene are the most common ingredients in off the shelf octane boosters. you have to use quite a bit to get to 100oct though. MTBE is also commonly used as a home brew octane booster.
Xylene can be purchased at home depot and lowes for the same price a Toluene. IIRC Xylene was 116 or 117oct vs Toluene being 114oct.
You would need about 4.5 gallons to hit 100oct if you had 93oct.
You would need about 5 gallons to hit 100oct if you mixed with 91oct.
charrigan is offline   Reply With Quote
Old 04-27-2015, 01:28 PM   #13
svickstc
svickstc's Avatar
Drives: Nike 6.0
I did and pulled -12 timing
|Nikon|
Old 04-28-2015, 06:54 PM   #14
charrigan
Drives: 2013 GLI
How much did you use and what octane tune were you using?
