The Tire Rack
Old 07-21-2015, 10:23 PM   #1
sniper27
Formula 5000 Champion
sniper27's Avatar
Drives: 2013 GTI DE
18x8.5 et45. Rub?
I posted this on the A3 forum on vortex but figured I try here also since it's pretty much the same as a golf/gti.
Currently, I am running 15mm spacers with OEM titanium wheels on the A3, which are 18x7.5 et54. This pushes it out to the equivalent of about 18x8 et45. With Neuspeed sports and Koni orange, I get slight rubbing from the rear over large bumps. I'm wondering if 18x8.5 et45 will rub worse, or will the slightly stretched tire compare to being on 7.5 width wheel help with the rubbing? Tires are 225/40/18.
Thanks
sniper27 is offline   Reply With Quote
Old 07-21-2015, 11:33 PM   #2
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Should be good, almost everyone runs that setup on here (VMR's are typically 18x8.5, ET45) with the 225/40/18 tires
Fender screw mod should get you squared away up front. MIGHT need a slight fender roll, if still rubbing
2017 Passat VR6
2017 Passat R-line
Old 07-21-2015, 11:53 PM   #3
sniper27
sniper27's Avatar
Drives: 2013 GTI DE
This is for the A3. Front actually doesn't rub now, just the rear. It's rubbing against the fender liner, so not sure what to roll.
Old 07-22-2015, 01:34 AM   #4
CarniifeX
Formula 3000 Champion
CarniifeX's Avatar
Drives: '14 CW GTI
I ran my Miro wheels (18x8.5 on 225/40/18) at 24.5 FTG and I did not run once.
Just roll your front fenders and you should be golden.
I will note, I did run -2.5 camber in the rear when I got my alignment after I put the wheels on. It was a pretty tight fit but as I mentioned, I did not rub. Not even once.
'14 Wolfsburg GTI CW 4-Door | BUILD THREAD
CarniifeX is offline   Reply With Quote
Old 07-22-2015, 01:43 AM   #5
sniper27
sniper27's Avatar
Drives: 2013 GTI DE
The A3 is at about - 1.7 camber in the rear now and it rubs. Will slight tire stretch help?
Old 07-22-2015, 12:32 PM   #6
EvoKnvl
Rally Car Champion
EvoKnvl's Avatar
Drives: VO 1 Series M; Prev: RB Mk6 R Stg3
Slight stretch might. When I had VMR's, I was running 225s and was running about a -2.5 in the rear as well. That's probably your best bet depending on your ride height.
EvoKnvl is offline   Reply With Quote
