Old 05-07-2015, 02:45 PM   #1
#madrussian
Drives: 2013 Golf R 4 Door
End of Warranty - oil Change
So the end of my manufacturer warranty is coming, and i don't much care, as i am very comfortable doing my own car maintenance.
I do however have a question for the users here as to the ECS oil change kit, with the aluminum oil filter housing and also considering getting a fumoto valve to make the entire process as easy/clean as possible.
Does anyone on here have experience with the ECS stuff; fumoto valve?
Is there perhaps another brand/type of equivalent equipment i should be looking at?
Thanks,
#madRussian
#madrussian is offline   Reply With Quote
Old 05-09-2015, 12:24 AM   #2
xpystchrisx
Drives: 2013 Golf R
I'm new here but I'll chime in on the Fumoto valve.
Skip it.
It's a cool idea, but if you're like me you'll like knowing that you've got as much of the dirty oil out of your engine as possible. This is with the understanding that you'll never get it all.
With my previous car, a Mazdaspeed 3, I had the valve installed and it never quite finished draining during a change. I figure it raises the oil drain level up approximately 2mm. This is just enough to leave the build up that you want out of the oil pan, behind. On my last change I found myself pouring 1/2 a quart of cheap dyno oil through the motor to flush out the remaining garbage in the oil pan.
Save yourself the 30 to 40 that it'll cost you and use normal drain plugs with new crush washers.
'13 Golf R
- Eurodyne Maestro - EvoMS Intake - Autotech HPFP - Scorpion Catless DP -ARM FMIC - 034 MS Street Density Mounts - H&R 26mm RSB - H&R RSS Clubsports - PowerFlex Rear LCA Bushings - 034MotorSports Front Subframe Lock Kit - 235/40 Potenza S-04 -
xpystchrisx is offline   Reply With Quote
Old 05-09-2015, 04:56 PM   #3
ibid
Drives: 2012 Golf R 4dr Base w/2010 TDIsold
+1 on the valve being a bad idea... got rid of it on a miata we got.. total POS that leaked too
ibid is offline   Reply With Quote
Old 05-09-2015, 05:30 PM   #4
Bozz
Bozz's Avatar
I have the ECS aluminum filter housing. It fits fine. The only gripe I have is that its drain plug torque is higher than the torque of the housing itself, which may explain why I can't loosen the drain. I suggest being mindful of that if you buy it.
I also have a Fumoto, the nipple version. I have no complaints with it. I am not aware of it sitting 2mm higher than the OEM plug -- that seems unlikely to me. If one is that concerned about it, they can buy a MityVac or similar.
Old 05-09-2015, 08:59 PM   #5
xpystchrisx
Drives: 2013 Golf R
This was my experience on my MS3, not sure how the drain plug is situated on the R. I've not yet done my first oil change as I just got it Tuesday.
'13 Golf R
Old 05-10-2015, 03:15 AM   #6
TooFunky
Drives: 2L tdi
Bozz, chris didn't say the plug sat higher than the oem one.
He said it raises the oil drain level by 2mm, as in, it sticks out the other side slightly.
Where as when you do a change using the oem one you remove the plug so there is no thread sticking out inside.
TooFunky is offline   Reply With Quote
Old 05-10-2015, 04:57 PM   #7
Bozz
Bozz's Avatar
"Sticks out the other side slightly" ?? What does that mean?
I fail to see the point made on the 2mm.
Old 05-11-2015, 12:41 AM   #8
07STitoR
Drives: 07 STi, 13 R
I think what he is trying to say is the drain hole in the fumoto valve sits higher than the OEM drain hole. Look at the pictures of the Fumoto valve and you'll understand why.
07STitoR is offline   Reply With Quote
Old 05-11-2015, 09:13 AM   #9
The valve is just something else to leak or break. I like the stock drain plug or magnetic plug with aluminum washers. I haven't had any issues for years.
Old 05-11-2015, 09:33 AM   #10
ToucanLife
Drives: 12' R
Agreed - adding another failure point to the system. Is it really that hard / messy to unscrew a bolt?
F23 / Maestro / Bags
ToucanLife is offline   Reply With Quote
Old 05-11-2015, 10:38 AM   #11
#madrussian
Thanks for all the input. I'm going to just get the aluminum housing and the magnetic bolt and call it a day. at the end of the day its not THAT messy unscrewing a bolt.
on a side note, the dealer has used castrol full synth for the oil changes, but personally i'm not a huge fan on that oil brand... is there one thats more widely used in the community?
#madRussian
Old 05-11-2015, 11:32 AM   #12
bebersol
bebersol's Avatar
Thanks,
#madRussian
I have the ECStuning Billet Aluminum Oil Filter Housing, I'll sell it to you for $50. I used it for 1 oil change 5,000 mi.
Bunch O'Stuff :-)
Old 05-11-2015, 04:08 PM   #13
robotvoice
Drives: '13 Golf R
Even using the normal drain plug you'll never get 100% of the oil out of your engine during an oil change. I've used the Fumoto valve in the past and it works great, never leaked or broke off. People who over-torque the valve or forget to put the supplied gasket on usually have problems with leaks. If the couple of MM of the valve protruding into the pan bother you that much, just file the valve down some.
robotvoice is offline   Reply With Quote
Old 05-11-2015, 06:38 PM   #14
fatvdub
Drives: 2012 Golf R
I got the Fumoto valve on my R, oil changes are very slow!!! but the valve works as described, no leaks. It might leave some oil in the pan I could see that. Personally I won't install another one. just my thoughts.
fatvdub is offline   Reply With Quote
oil change, oil plug
