Old 06-24-2015, 12:57 PM   #1
damagi123
damagi123's Avatar
Drives: 2012 GTI DSG
"Mini Cat" o2 sensor spacer alternative
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
does anyone know if this kinda thing really works? Someone said it kept their chk light off but I'd never seen anything like it before on here and ive been researching catless dps for months.
seems like a great idea in theory.
Old 06-24-2015, 01:12 PM   #2
jay745
jay745's Avatar
this basically is a cheap looking spacer. At more money than the 42DD o2 spacer I'd say just get the 42DD
Old 06-24-2015, 03:00 PM   #3
realcyberbob
realcyberbob's Avatar
I don't get the point of it, just get a 42DD spacer and done.
Old 06-24-2015, 04:09 PM   #4
lilfleck
Drives: '11 GTI Autobahn, DSG
I have one in. I don't have any CEL codes. It does come on every now and then in cold weather when the motor is cold.
Old 06-24-2015, 04:53 PM   #5
jian3979
Drives: 2011 Manual Candy White GTI
i am using Rai J spacer on my APR DP, it works well.
http://www.raimotorsport.com/Threade...p/11619vib.htm
2011 Candy White GTI
APR Stage 2 +
APR DP
APR intake
jian3979 is offline   Reply With Quote
Old 06-24-2015, 06:22 PM   #6
nafljhy
Drives: 2011 UG GTI
interesting. there is a vendor on vwvortex, audizine, that sells another brand uh.. griffins motorworkes
they also offer a similar solution. slightly cheaper but i dunno. both have people saying they work. i'll give them a try when i get my dp on.
Old 06-25-2015, 12:16 AM   #7
ArcsandSparks
ArcsandSparks's Avatar
Drives: Mk6 UG Gti
Just use a RAI J-Spacer or a 42DD spacer. Rarely get a CEL and if I do it goes off in a few hundred miles.
Sold my MK6 and bought a MK7 R
ArcsandSparks is offline   Reply With Quote
Old 06-25-2015, 12:34 AM   #8
NLeo
Drives: 2010 gti
I use a right angle one from ebay passes inspection no problem catless. Think it was like $15 shipped its actually been on there for a month and still no cel. I usually take it off after I get an inspection and then put it back in stage 2 mode, but I wanted to see how long I could make it before stock mode threw the cel and it still hasnt come on. Without the spacer the cel would come on the next day.
NLeo is offline   Reply With Quote
Old 06-25-2015, 02:29 AM   #9
nafljhy
Drives: 2011 UG GTI
are you CBFA or CCTA?
Old 06-25-2015, 06:22 AM   #10
nvturbo
nvturbo's Avatar
Originally Posted by realcyberbob View Post
I don't get the point of it, you are on stage2 APR and still enquiring about this spacer???
FTFY
Old 06-25-2015, 10:02 AM   #11
vracerw
Drives: 2012 beetle
could also go with this for a little less $$. Same concept
http://roc-euro.com/shop-by-vehicle/...or-spacer.html
vracerw is offline   Reply With Quote
Old 06-25-2015, 10:28 AM   #12
damagi123
damagi123's Avatar
Originally Posted by nvturbo View Post
FTFY
i dont get what your point is at all. In NY they do emissions checks and you have to beat the CEL to pass em
thanks alot. Id like to try one of these
yeah im CBFA with a full catless lol so i know i have alot of work ahead of me trying to fuck with 2 spacers instead of one. O well, life is good.
I actually called APR and had them make me a stg2 file that has 02 readiness on every program so I dont have to drive around in stock mode just to check if my cel is gonna come back or not
Old 06-25-2015, 11:31 AM   #13
nafljhy
Drives: 2011 UG GTI
it's nice that they do that. I thought eurodyne would do it too but they don't :/ i'll need to stay in stage 1 for awhile to make sure i don't have a cel then flash to stage 2
Old 06-25-2015, 11:57 AM   #14
nvturbo
nvturbo's Avatar
You mean OBD2 readiness that you can set via VagCom prior to inspection. That's my point.
