Old 07-07-2015, 09:05 AM   #1
bosa
Drives: Golf SW TDI 2011 comfortline with m
Unhappy " whom whom " noise while turning and vibrations
Hi,
1st problem : since a few months my GSW is making some "whom whom" noises while cornering at very low speed, especially when going uphill and when playing with the clutch at startup of a red light for example. While in its last month of warranty, my dealer tried to find the problem but did not succeed saying that everything was normal, even after changing the front suspension bushings under warranty !
2nd problem : the day my dealer change the front suspension bushings I originally asked for an alignement. Since then (which also was a few days after winter/summer tires switch) I can feel a "butt" vibration while in 2 to 4 gear (around 2000 rpm, so mainly 50-60 km/h and 70-80 km/h). No vibration on steering wheel or gear stick. The problem is less, but still, present if I put in neutral or shut down the engine while driving (on a safe road for this last one !). I have change the rear disk brakes and all 4 summer tires, but this did not resolve the problem.
So are both problems linked ?
What should I be looking for to resolve both problems ?
Gear box ?
Flywheel ?
Wheel bearing ?
Drive shaft ?
Front disk brakes ?
Bent alloy wheel ?
GSW TDI 2011, 58 000 km
Thanks for any help...
bosa is offline   Reply With Quote
Old 07-07-2015, 12:18 PM   #2
gliitch
Drives: 2011 Golf TDI 6m
jack up the front of the car, sit on the ground next to the front wheel, grab the bottom of the wheel and push it in towards the car and back towards you. does it move at all? if so, wheel bearing.
gliitch is offline   Reply With Quote
Old 07-07-2015, 12:39 PM   #3
thedude4bides
thedude4bides's Avatar
Drives: '12 Golf R
Is problem #1 a bad throw out bearing?
Old 07-07-2015, 08:10 PM   #4
bosa
Thank you for your advises, I will jack up my car tomorrow... thedude4bides, I have search about your suggestion and found this (see TSB http://forums.vwvortex.com/showthrea...rowout-Bearing) which basically may explain both problems with a clutch hub springs that may be faulty... If so, I will have to fight with VW so they can cover all or part of the repair !!!
