Old 08-09-2015, 07:40 AM   #197
reshwitz
What's different about the CCTA vs. CBFA water pump? Have the bulk of the failures been on the CBFA engine?
I understand that the CBFA engine is designed for states with stricter emissions requirements, but I'm a bit confused why that would require a different water pump design.
It appears this service action excludes the CCTA engine based on everyone with a CCTA engine not seeing their vehicle show up in the database.
Unitronic Stage II+ (K04) | Unitronic Stage II DSG | Carbonio Intake | CTS Turbo Downpipe | Michelin PS AS/3 | HPA red puck | Focal PnP speakers | Kenwood head unit | VCDS Micro-CAN (inquire for availability)
reshwitz is offline   Reply With Quote
Old 08-09-2015, 07:49 AM   #198
Mantz921
Drives: 12 DSG CSG Autobahn 2dr
2011-2014 Water Pump Recall Incoming
My pump went at 71k on my 2012 CBFA DSG.. Last weekend!
Look at the date.. 8/4 in. 8/6 mine came back positive on the vin check. Hopefully they refund me.
2012 Autobahn GTI DSG / GIAC ECU S2 / AWE DP / AWE DV1 / BSH Throttle Pipe, Intake, DV relocate / Neuspeed rse52 / H&R rsb
Mantz921 is offline   Reply With Quote
Old 08-09-2015, 09:00 AM   #199
whitewolf33
whitewolf33's Avatar
Drives: 2013 CW Wolfsburg
still nothing for my 2013 wolsfberg ccta
Old 08-09-2015, 11:17 AM   #200
VgRt6
At least one difference is an extra sensor in the housing, I assume for measuring coolant temp. The CBFA pump has it, but the CCTA pump doesn't. Not sure if there are any other differences.
VgRt6 is offline   Reply With Quote
Old 08-09-2015, 01:32 PM   #201
MoNaH_GTI
Drives: 2013 VW GTI
My 2013 GTI came up with the 19K5, and it already had its pump replaced at about 12k. (40k now)
MoNaH_GTI is offline   Reply With Quote
Old 08-09-2015, 05:39 PM   #202
BroMoney
BroMoney's Avatar
Drives: 2014 GTI Wolfsburg Edition
2014 DSG Wolfsburg w/ 8.8k miles, no issues with the pump yet. Plugged my VIN into the recall page and it popped up. Will probably see what revision they're using to replace the pumps with and if its newer then BG or the metal one I'll probably bite the bullet. Better to be proactive then let it blow up on me at 3am on my way home from work.
2014 CSG 4-Door DSG | CF Wrapped Modshack Intake | Interior & License Plate LEDs | 65W OSRAM Rallye low beams | Yellow Lamin-X Fogs | Plaid Insert Everything | Nokya Hyper Yellow Fogs
BroMoney is offline   Reply With Quote
Old 08-09-2015, 06:53 PM   #203
gti925
gti925's Avatar
Drives: 2012 GTI 6MT
I've had mine replaced at 12k and 30k. 14k on the "BB" pump, so I'm gonna wait and see.
Sonny
2012 Tornado Red 6MT 4dr
APR K04 v3.1 | APR DP | ARM FMIC | GFB DV+ | Neuspeed P-Flo Intake | R8 Coils + NGK BKR8EIX | HST RSR Clutch
gti925 is offline   Reply With Quote
Old 08-09-2015, 09:47 PM   #204
ProV1x
Drives: 11 GTI DSG
19K5 campaign is coming up on my VIN now.
Had one replaced last year @ 45k miles with "BB" pump.
Do i still bring it in for inspection/new pump??
ProV1x is offline   Reply With Quote
Old 08-10-2015, 12:04 AM   #205
Jhayesvw
Drives: 12' GTI shadow blue 6MT
I just had mine replaced about 2 weeks ago. I'll have to check if my car is still on the recall list.
I doubt it and that's ok with me. Unless the newest pump isn't the one that ends in bG or whatever I got.
Jhayesvw is offline   Reply With Quote
Old 08-10-2015, 08:17 AM   #206
dmarsh15
dmarsh15's Avatar
Drives: Prius Killer
My car is now on the list!
2014 Wolfsburg MT - CSG
Instagram - @dmarsh15
APR Stage 1 / Continental DW / PIAA White Plus / PIAA Yellow Fogs / DG SS /
Unitronic CAI / GFB DV+ / Eibach RSB / JPM Shift Boot / Color Matched Markers / R8 Coils /
dmarsh15 is offline   Reply With Quote
Old 08-10-2015, 09:14 AM   #207
miles69
Mine is still not on the list, 2013 DSG. Build 7/12
2013 CW GTI DSG / KONI COILOVERS / UNITRONICS INTAKE / CTS DOWNPIPE / EURODYNE STG 2 / APR STG 1 DSG
miles69 is offline   Reply With Quote
Old 08-10-2015, 03:26 PM   #208
stucky
stucky's Avatar
Drives: 12' 4 dr 6sp Man Autobahn. BUH LAK
are there any CCTA motors on this SERVICE LIST?
Mine is ccta, and I'm not on the list.
stucky is offline   Reply With Quote
Old 08-10-2015, 04:00 PM   #209
realcyberbob
realcyberbob's Avatar
I would also like to know this, I have CCTA and it's not on service list as well.
Old 08-10-2015, 04:47 PM   #210
stucky
stucky's Avatar
hmmmmmmmm
