Old 08-05-2015, 10:23 PM   #1
Goingnowherefast
Goingnowherefast's Avatar
Drives: 16 GTI S 6MT, 91 Miata
Considering buying MK6R Clutch/PP/Flywheel
Hey guys, I just went K04 and my clutch is slipping like hell. I can't get it to not slip in any gear above 3rd. 3rd, 4th, 5th, 6th in RPM it will slip like crazy. So I am looking for new clutch options and I could get my hands on a used R Clutch, Pressure Plate, and Flywheel for pennies on the dollar. So my question is are you guys experiencing bad clutch problems when tuned/bolted? What's the general consensus about MK6R clutches? Would it be a good idea to pair the TTRS pressure plate with the R clutch and flywheel? Thanks in advance
2016 GTI S 6MT//2014 Fiesta ST 6MT//1991 Miata 5MT
Turbo miata build starting here: http://www.golfmk6.com/forums/showthread.php?t=96866
Goingnowherefast is offline   Reply With Quote
Old 08-06-2015, 01:33 PM   #2
tjasko
tjasko's Avatar
Drives: 2012 CW .:R
I'm replacing the clutch in my R with a Southbend Stage II daily kit as it's starting to slip (53k miles), so I'd personally say no. I'm sure the R clutch is stronger than the GTIs, but if you have a K04, I'd upgrade the clutch. Hope some other R owners will chip in.
[My .:R IE450T Big Turbo Build Thread] | Parts from: APR, Bilstein, IE, Neuspeed, Milltek, Volk Racing, StopTech, SuperPro, USP, 42DD, BSH & more
tjasko is offline   Reply With Quote
Old 08-06-2015, 01:35 PM   #3
lilfleck
Drives: '11 GTI Autobahn, DSG
That's not a smart move man... R clutches experience slipping as well once tuned--and they are using the same turbo as a lot of the guys on the GTIs.
If you're going to spend the money, do it right the first time.
Old 08-06-2015, 01:53 PM   #4
Goingnowherefast
Thanks for the advice guys. The issue is that I'm able to pick up the clutch, pressure plate and flywheel for $150 all together. Compared to $1,000+ Kits. So it's a killer deal, just trying to figure out if its gonna be worth dropping a ton of money on it.
Old 08-06-2015, 02:01 PM   #5
jay745
jay745's Avatar
youre going to lose out paying for labor twice after the R clutch craps itself in a month.
Old 08-06-2015, 02:04 PM   #6
lilfleck
Ok, and you're going to spend ~$4-500 in labor and then have to do it all over again because its slipping again. BTW, the R clutch will have to be slightly modified to fit the TSI motor.
2x
Old 08-06-2015, 02:24 PM   #7
Goingnowherefast
I'll be doing the work myself so labor isn't a factor (Obviously I don't want to be wasting time, but it won't cost any money to do). I'm on the FSI motor so it will bolt right up. Thanks for the advice so far guys.
Old 08-06-2015, 02:40 PM   #8
project92raddoslc
project92raddoslc's Avatar
Drives: 2016 GOLF R
My clutch started slipping the day I flashed to stage 2. Go with an aftermarket kit or build the one similar to the RSR kit.
Old 08-13-2015, 01:20 PM   #9
Goingnowherefast
So little update guys. Firstly thanks for all the input so far. I got a hold of the Golf R clutch, Pressure Plate, and Flywheel yesterday. It is the Sachs version which I'm pretty sure that's the one to have. I've decided to pick one component to try to beef up the setup enough to safely hold K04 power. What I have decided to try is to use a up-rated Sachs SRE disk with the Golf R Pressure plate and Flywheel. Here is the disk in question... http://www.darksidedevelopments.co.u...-flywheel.html
Do you guys think this will work? In the end if it does fit then it will have OEM drive-ability, low noise, and good enough holding power for less than $500 total.
Old 08-13-2015, 01:28 PM   #10
rupertpupkin
rupertpupkin's Avatar
Drives: '12 CSG R
The weakest link in the Stock Golf R setup is the pressure plate. The disk was fine. You could put a sand paper disk in there and the pressure plate that came out of mine wouldn't have held.
It is the clamping force that is lacking so much. The RSR disk is nearly the same material as the stock golf r one and holds a ton more torque. because the clamping of the PP is so much greater.
rupertpupkin is offline   Reply With Quote
Old 08-13-2015, 03:10 PM   #11
Goingnowherefast
That's what I was thinking in the first place. By that basis the better move would be pressure plate. How does this look? I should be able to use that which is 390tq capable with the Golf R clutch and flywheel if I'm correct. (http://www.darksidedevelopments.co.u...-flywheel.html)
