Old 09-27-2017, 11:19 PM   #6483
wndwsdwngti860
Drives: gti
have an audi s4 throttle body for sale if anyones interested. same one ive been using on my car for over 2 years. customer of mine totaled his car and its going to junk. $200 takes it.
wndwsdwngti860 is offline   Reply With Quote
Old 09-28-2017, 08:48 AM   #6484
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
I'll shoot you a text. plug and play no changes needed in Eurodyne? Larger TB opening by how many mm?
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
HYDE16 is online now   Reply With Quote
Old 10-02-2017, 09:33 PM   #6485
A3Scott20
A3Scott20's Avatar
Drives: 2013 A3 DSG
Very pleased with the dyno result I got last weekend
503WHP
657NM
Boost 34-30PSI
Timing Adv 11-12Deg.
Zero timing pull and I'm so excited once timing adv goes up to 17Deg. since there is ton of fueling left.
NOTE: Second column is BOOST, third column is AFR.
A3Scott20 is offline   Reply With Quote
Old 10-02-2017, 10:03 PM   #6486
mk6'12gti
Drives: 2012 4dr Black Gti
That tb is about 75mm outter diameter is 74.98mm
mk6'12gti is online now   Reply With Quote
Old 10-02-2017, 11:14 PM   #6487
mk6'12gti
Also since that throttle body has been out they have come out with a revised version 06E 133 062 H not sure what the difference is.
Old 10-03-2017, 12:21 AM   #6488
mostic
mostic's Avatar
Drives: VW
503WHP
657NM
Boost 34-30PSI
Attachment 56239
Very nice
This is PagParts kit, right?
Old 10-03-2017, 03:19 AM   #6489
A3Scott20
A3Scott20's Avatar
Drives: 2013 A3 DSG
Originally Posted by mostic View Post
Very nice
Correct, EFR7163 turbo kit built by Arnold@PagParts
Old 10-15-2017, 09:30 AM   #6490
GTR_Killer
GTR_Killer's Avatar
Drives: Burnout Machine
Cool
GTR_Killer is offline   Reply With Quote
Old 10-15-2017, 08:32 PM   #6491
A3Scott20
A3Scott20's Avatar
Drives: 2013 A3 DSG
PagParts' EFR7163 TURBO KIT
UPDATE:
530 WHP
487 LB-FT
Boost 34-30PSI
Timing Adv 16-17Deg
ROW EA888 98RON + Aquamist DPI
NOTE: Second column is BOOST in PSI, third column is AFR
Old 10-16-2017, 05:20 AM   #6492
mostic
mostic's Avatar
Drives: VW
UPDATE:
530 WHP
487 LB-FT
Boost 34-30PSI
Timing Adv 16-17Deg
Attachment 56312
Very strong numbers
Old 10-17-2017, 12:01 AM   #6493
A3Scott20
A3Scott20's Avatar
Drives: 2013 A3 DSG
Very strong numbers
will add some octane additive on next run to see if I can gain a little more HP
Old 10-18-2017, 12:04 AM   #6494
wndwsdwngti860
Drives: gti
Big Turbo Discussion Thread #2
Whats everyones take on doing an aux in tank pump?
already have a ttrs lpfp with pm3 and zzp injectors.
GIAC sells a kit with a pressure switch that basically Ts into the feed line to the hpfp.
is this just overkill rn? or will it only help?
link to kit: http://www.giacusa.com/news_and_medi...ews.php?id=208
Old 10-18-2017, 03:20 AM   #6495
mostic
mostic's Avatar
Drives: VW
I am using the USP one in my GTX28 setup and I have 3 friends running it in their BT cars (EFR7163, GTX3076R, GTX3071 Gen2), we have the 4 running perfectly without any issue for more than 4 years now.
https://www.uspmotorsports.com/Engin...el-System.html
Old 10-18-2017, 05:02 AM   #6496
mars2
Drives: VW T6 EA888 Gen2
Some dyno number of the Turbozentrum EFR-6758:
http://www.audizine.com/forum/showth...EFR-6758-Build
not EA888 GEN1 but Gen2 from an Audi
mars2 is offline   Reply With Quote
addicted to torture, blow up ur volkswagen, breaking your trans 101, failwheeldrive anonymous, fireball lives!, james'partout
