Old 10-04-2015, 10:36 PM   #1
91a2jettavr6
Drives: 2012 Golf R
12 Golf R w/ stock downpipe...does this limit boost capability?
I'll be adding both an APR downpipe and intake in a week or so. In the meantime, my question is this: will having a stock downpipe prevent boost from building beyond a certain level? If so, what would that level be (roughly)? I set my stage 2 loaded tune to 28 (I do have a HPFP installed) as I am experimenting and my boost gauge, which does work properly, shows 24-25 max at WOT and 20 vacuum at idle, just as it should. Anyway, is the restrictive nature of the stock downpipe preventing boost from building beyond this point? Can I expect an automatic increase once I've installed the aforementioned APR goodies? Thanks guys .
91a2jettavr6 is offline   Reply With Quote
Old 10-04-2015, 10:43 PM   #2
R_313
Drives: 2013 Golf R, 2009 GLI
What I was explained at the performance shop here that did my car was, once the downpipe is installed you can expect your power band to start at a lower rpm and an increase in torque. 15-20 hp gain to be expected, but not necessarily pushing any more boost than what you are currently reporting.
R_313 is offline   Reply With Quote
Old 10-04-2015, 10:47 PM   #3
91a2jettavr6
Drives: 2012 Golf R
Ok, thanks for the response. So...if my boost gauge (South Performance) appears to be working normally and the car runs well and pulls HARD, what else would explain the 3-4lb deviation from the 28lb set point of my tune?
Old 10-05-2015, 10:16 AM   #4
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Altitude plays a role in boast numbers
Old 10-05-2015, 05:59 PM   #5
keihin
Drives: 2000 VW GTI VR6
You've got both stock intake and outlet restrictions, and likely a fuel restriction as well. It sounds like your software may be pulling you back from a potential overboost/lean condition.
keihin is offline   Reply With Quote
Old 10-05-2015, 11:30 PM   #6
91a2jettavr6
Drives: 2012 Golf R
Why would I have a fuel restriction with an APR HPFP given that it is all that is required (from a fueling standpoint) to run my stage 2 tune?
Old 10-06-2015, 11:00 AM   #7
vizzlebizzle
Drives: 2013 R
stage 1+ requires JUST the HPFP upgrade. you shouldn't have stage 2+ software until you have the downpipe/exhaust/whatever you're doing. and it's a gain of 25whp and 43tq, according to the APR website (going from 1+ to 2+)
TRAP LORD
My 2013 R journal - EVOMS - 42DD - Neuspeed - APR Stage Dos
Memories: 2005 Evolution VIII, 1997 240SX, 1993 240SX
vizzlebizzle is offline   Reply With Quote
Old 10-06-2015, 06:43 PM   #8
thegave
Drives: Golf R
Boost pressure is simply a measure of restriction. Higher boost doesn't necessarily mean higher power.
thegave is offline   Reply With Quote
Old 10-06-2015, 10:04 PM   #9
91a2jettavr6
Drives: 2012 Golf R
Actually, stage 2 (** United Motorsports) is comprised of their stage 2 tune and an HPFP...nothing else. Stage 1 didn't require the pump upgrade...only the stage 1 tune. There was no stage 1+ option. Stage 2+ (from what I understand) will be after I've installed the APR downpipe.
Old 10-06-2015, 10:12 PM   #10
vizzlebizzle
Drives: 2013 R
oh true. yeah, i don't know anything about UM tunes. i hear they're nice though. saw you using APR parts and thought you had the tune, too. my b. i didn't know UM had any tunes beyond stage 2 (other than bt stage 3)
TRAP LORD
Old 10-06-2015, 10:55 PM   #11
91a2jettavr6
Drives: 2012 Golf R
They really don't but I've decided to tell myself I'll have a stage 2+. Ahhh...I love denial.
